Green coolant, future availability ?
by rubberchicken - 11/16/19 06:11 PM
Weird tire wear
by ledslinger - 11/16/19 04:50 PM
Why does Ford resell lemons?
by avacado11 - 11/16/19 04:07 PM
Slow initial response to loading web pages
by JHZR2 - 11/16/19 04:06 PM
Motorcraft FL-910S
by PW01 - 11/16/19 03:54 PM
Walmart ammo clearance
by redbone3 - 11/16/19 03:35 PM
GENERAL Q regarding SPX snow plow
by Kira - 11/16/19 03:13 PM
78 C10 at show
by WiskyBadger - 11/16/19 03:00 PM
300blk ammo?
by buck91 - 11/16/19 02:52 PM
The Rock is still alive!
by Char Baby - 11/16/19 02:48 PM
Weird fuel leak
by BeerCan - 11/16/19 01:02 PM
Sinopec 75w-90 Synthetic
by jdw1222 - 11/16/19 12:51 PM
Honda Oil Filter
by miden851 - 11/16/19 12:28 PM
VOA for QSAD 10w-40?
by natas - 11/16/19 12:02 PM
Ford v Ferrari - anyone seen the movie yet?
by Oro_O - 11/16/19 12:01 PM
who made this??
by ted s - 11/16/19 11:41 AM
Drill Bits
by MasterSolenoid - 11/16/19 11:32 AM
2000 Honda Insight Crunchy 1st & 2nd
by Rmay635703 - 11/16/19 09:32 AM
Update Site to VerticalScope Inc board?
by CB900F2 - 11/16/19 09:27 AM
billad67, aka_Claus, Diverdown, natas, matt3540
69886 Registered Users
105 registered members (4WD, 2003f7, Astro14, Aichiguy, Al, 12 invisible), 2,102 guests, and 21 spiders.
Topics297,515
Posts5,117,176
Members69,886
Most Online3,589
Nov 2nd, 2019
Recycling fluids #4966857 01/01/19 11:07 AM
F
Fitter30 Offline OP
F
In a very rural area 20 miles from a small town and walmart will only recycle motor oil. Emailed the EPA twice asking for help in what to do about trans, brake and hydraulic fluids with no response. Since on well water and septic I'm concerned. Where should i go from here.
Re: Recycling fluids [Re: Fitter30] #4966874 01/01/19 11:25 AM
6
65f100 Offline
6
Many shops use waste oil heaters. Check with shops that repair heavy equipment.
Re: Recycling fluids [Re: Fitter30] #4966880 01/01/19 11:32 AM
W
Warstud Offline
W
Trans, brake, hydraulic fluid, gear, and power steering fluid can be mixed with motor oil.
Re: Recycling fluids [Re: Fitter30] #4966905 01/01/19 12:03 PM
M
MasterSolenoid Offline
M
It's good your concerned. Not everybody thinks like you.
1) Transmission Fluid
2) Hydraulic Fluids
3) Power Steering Fluid
4) Differential Oil
ALL are petroleum base and can be mixed with Motor Oil.
A) Coolant / Anti Freeze
B) Brake Fluid
I would not be mixing with Oils.
Start asking your neighbors or Indy Mechanics.
2002 Ford Ranger
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Recycling fluids [Re: Fitter30] #4966919 01/01/19 12:18 PM
M
mclasser Offline
M
Ask nearby repair shops if they'll take your waste oil. I had a Sunoco service station take 10 jugs of used oil/ATF off my hands.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Recycling fluids [Re: Fitter30] #4966943 01/01/19 12:50 PM
B
beanoil Offline
B
Trans, hydraulic, used motor oil, power steering fluid, all variations of the same stuff. All gets mixed, goes to recycle.
Brake fluid is a glycol, it does not go in with recycle.
Coolant goes down the toilet.
Re: Recycling fluids [Re: Fitter30] #4966944 01/01/19 12:50 PM
69GTX Offline
My local town recycling center takes all types of automotive oils in the same tank...including brake fluid. A separate tank is for antifreeze/coolants.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Recycling fluids [Re: Warstud] #4966945 01/01/19 12:54 PM
Snagglefoot Online Content
Online Content
+1. Mix the above with your motor oil. Most of it gets burned anyway. Very little motor oil actually gets turned into other products.
If you want the job done right......do it yourself.
Re: Recycling fluids [Re: Fitter30] #4966957 01/01/19 01:13 PM
K
kwijibo Offline
K
Coolant no longer goes down the toilet at least in my area. All the other fluids go into the same waste container at our recycling center. We also have a special container at the waste recycling center for oil filters. Used oil containers go into the regular trash not the home recycling container.
Re: Recycling fluids [Re: Fitter30] #4966963 01/01/19 01:17 PM
B
bmwpowere36m3 Offline
B
We dump all oils and solvents into the same waste stream... only coolant is seperated.
Re: Recycling fluids [Re: Fitter30] #4966966 01/01/19 01:20 PM
R
Rat407 Offline
R
I know Advance Auto, AutoZone, and O'Riley's take used oil as well as the filters. Do you have any of them near you. Some even take engine coolant.
Earth911
Earth911.com is a good source to find your closest recycle center.
2002 Silverado 5.3 0w-20 AMSOIL
Re: Recycling fluids [Re: Rat407] #4966977 01/01/19 01:40 PM
H
Highboy Offline
H
Do they ask if you buy your oil there or do they care?
2006 Scion tC PP/Denso
2008 Scion tC Pen Ultra/Fu
2008 Toyota Highlander Pennzoil Ultra/ Oem filter
2019 Subaru WRX
Re: Recycling fluids [Re: Highboy] #4966991 01/01/19 01:53 PM
L
laserred96gt Offline
L
They don't ask but I have noticed that when I go to auto zone they always hint about you purchasing something, AAP didn't even care.
2017 4Runner Limited, 50k
04 E-150, 4.6, 240K, Synblend 5w20.
11 Camry 2.5, 70K, PU 5w20.
Re: Recycling fluids [Re: Fitter30] #4967022 01/01/19 02:19 PM
Driz Offline
I save mine mixed with all the years motor oils tranny fluids ect I change for the year. It’s about 10 - 15 gallons a year. It goes to special garage. The guy who helps me get through the crappy NeuYorkistan inspections rather than instead of using it to rob me blind. A couple years back I gave him well over 100 gallons . I’d much rather see it used to heat some hard working guys shop than hand over for free to some guy who’s going to sell it afterwards.
Re: Recycling fluids [Re: Fitter30] #4967031 01/01/19 02:35 PM
Sonic Offline
I’ve taken used transmission fluid to Walmart at least 4-5 times. They’ve taken it. If yours says that they don’t, just mix the fluids in with used engine oil. It’s not like they check.
