Originally Posted by wallyuwl
The reflector halogens on the F150 are awful. You need to go to 502A Lariat package to get LED from factory.
Replacing with LED bulbs is a big improvement. I would like to see them go back to offering projector housings on XLT trim.
How did they improve? My 18' F150 has lousy headlamps but it's the reflectors. I can't see how changing the bulb source would improve that?
My '18 also came with horrible vertical alignment new. None of the light was on the ground - was all in everyones faces. I took a couple of weeks to aim them lower then tweak to get it right. With the light on the road, it's too far rightward and there's no adjustment for that. The distribution is also splotchy, like an accident. I'm guessing the engineers probably modeled the shape about right, but the molding process was lame - the smaller the lamps get, and the size of those reflectors is pretty cramped, the more precision is required. Best selling truck? The economy of scale should have really helped them here.
