Hello fellas. I have a problem getting my ac compressor pulley off. The pulley is making a loud whining noise, and I read that people have changed their pulleys and the sound went away. Bad bearing issue. The compressor still works fine and blows cold air.
The problem is most shafts have a hex end, so you use a 7mm socket to hold it in place and twist the pulley off. My shaf as an odd shapped end, it's flat on both sides, supposedly takes a special Mercedes tool but I can't find it for sale. A gator grip cannot fit down there. What do you guys suggest.?
Car is a 2003 Mercedes clk500
