2001 Camry. 2.2L engine. 120k miles. Previously posted - a family member drove the car for an hour with a stuck thermostat. replaced the thermostat, radiator (the cap seat was damaged from the heat!!), head gasket, water pump, overflow bottle inlet was clogged. the head was sent to a machine shop, .006 was removed . my fault: I never checked the block for flatness.
currently it is using a little bit of coolant (I presume the block is warped and I still have a head gasket issue) and, after I noticed that, it blew another water pump.
two questions:
- am I just unlucky on the water pump or is something causing it to blow the seal?
- what is the absolute, best, and quickest path to a running and reliable car?
Yes, my fault for the improper replacement of the head gasket.
The car is very serviceable; no rust, nice all around. I NEED it to be reliable. I figure a reman'd engine at this point. or the scrap yard.
two questions:
