Originally Posted by StevieC
I'll mix the two in a clear jar as I have some and take a picture. Then I'll heat it to 220F in the jar and show you. Nothing will happen chemically.
That proves nothing in a cooling system. Try mixing it in lets say a 2011-2016 Chrysler that came with an OAT or HOAT factory fill in the cooling system and driving it. That is a valid real world test when telling people the mix won't do any harm. Then tell those who had a problem that they didn't have a problem. The TSB I pasted advises against it, sorry to say I'll believe that.
It will prove that the coolant was fine to be mixed chemically however I never said it would be fine in terms of corrosion protection in a cooling system. This corrosion can lead to things like sludge etc. if this mixture was in great amounts in a OAT cooling system for prolong periods of time because what is in the HOAT isn't compatible with the materials used in the cooling system in OAT filled vehicles. It would also prove that using OAT in a HOAT system is perfectly fine because HOAT contains OAT anyway and if they don't react chemically during the test then it would be fine in a HOAT system.
Isn't protecting a Chrysler cooling system what we're after here? The mix has caused countless Jeep owners problems, a few years back the forums were littered with horror stories of mixing the two. I'd hate to see the OP or anyone else walk away from here thinking mix away OAT/HOAT in a Mopar...........
