So with this substantial weight loss journey I'm going through I have had to buy new clothes a few times already to compensate for the shrinking body.
I have found dress pants with elastic in the waistline so they will shrink with me to a certain point without looking frumpy.
The problem I ran into was belts and finding one that would hold my pants up as I drop down in size as I can be between the belt-loop holes where one is too tight and the other is a bit too loose.
Grip-6 belts to the rescue and they are great. It gives you an infinite range of snugness that is just right and not confined to the nearest belt loop hole.
Anyway, just thought I would share because it's an excellent belt that is comfortable. https://grip6.com/
