105 registered members (2009Edge, Aichiguy, 1978elcamino, 2015_PSD, 77GrandPrix, 8 invisible),
1,999
guests, and 40
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,538
Posts5,137,427
Members70,087
Most Online3,589 Nov 2nd, 2019
Shell Rotella T6 0W-40 CJ4 VOA
#4892139
10/09/18 05:42 PM
SubaJew
OP
OP
Posts: 12 |
I couldn't find a VOA for this so I had one done. I'm going to be using this in my Carrier APU (Kubota engine) on my truck and wanted a baseline. I'll be switching between this for winters and T6 5W-40 CK4 for summers.
2005 SUBARU Forester XT 4EAT - COBB Stage 1 Rotella T6 0W-40 CJ-4/SN - WIX 51365
2018 WESTERN STAR 5700 - Detroit DD15 - Eaton Fuller Super 13 Rotella T5 10W-30 CK-4 - Donaldson P551005
Re: Shell Rotella T6 0W-40 CJ4 VOA
[Re: SubaJew]
#4892147
10/09/18 05:49 PM
SubieRubyRoo
Posts: 3,420 |
Looks stout! Gonna use it in the Forester as well?
Where did you find the 0W40? AAP?
[Re: SubaJew]
#4892149
10/09/18 05:51 PM
Snagglefoot
Posts: 5,294 |
Thanks for the VOA. This is also rated SN. Very high Zinc. Excellent.
If you want the job done right......do it yourself.
[Re: SubieRubyRoo]
#4892153
10/09/18 05:54 PM
SubaJew
OP
OP
Posts: 12 |
Where did you find the 0W40? AAP? Nope. Forester never leaves south Florida. Sticking with the M1. It's been working well for me. Local supplier is Advance Auto.
[Re: SubaJew]
#4892215
10/09/18 06:55 PM
skyactiv
Posts: 6,144 |
Looks like it would be a good oil for the my wifes Audi and my VW.
Wife: 15' Audi A4 quattro 6 speed manual Sold: 13' VW GTI 3 door 6 speed manual Me: 18' Elantra Sport 6 speed manual
[Re: SubieRubyRoo]
#4892253
10/09/18 07:26 PM
Linctex
Posts: 9,661 |
But it has almost no Moly ;'-(
"The evidence demands a verdict". (Re:VOA)"it's nearly impossible to actually know the particular additives that are in there at what concentrations."
[Re: SubaJew]
#4892272
10/09/18 07:38 PM
SubieRubyRoo
Posts: 3,420 |
You know moly isn't the end-all-be-all of a motor oil. Stop feeding the trolls
[Re: SubaJew]
#4892438
10/09/18 11:17 PM
userfriendly
Posts: 2,946 |
Am I reading it correctly? 11.99 @ 100C
[Re: userfriendly]
#4893157
10/10/18 03:19 PM
SubaJew
OP
OP
Posts: 12 |
Am I reading it correctly? 11.99 @ 100C Yes. It appears that way. I'm a bit suspect of it though. It seems a bit low compared to the specs released by Shell.
[Re: SubaJew]
#4893244
10/10/18 04:43 PM
SubaJew
OP
OP
Posts: 12 |
I will also note that other posted UOAs show ~12.5 @ 100C. Considering that those samples were taken from degraded end of service life oil, I'm inclined to think that the 11.99 number on my VOA is an unexplained anomaly? FWIW Shell says it should be ~13.2 @ 100C, which would jive better with the posted UOA vs my VOA. YMMV....
[Re: SubaJew]
#4895072
10/12/18 07:20 PM
dave1251
Posts: 12,524 |
Looks like I may use this in the Focus.
make the inside of your engine oil cap white. don't use.
[Re: SubaJew]
#4897806
10/16/18 10:51 AM
userfriendly
Posts: 2,946 |
The 0W40 VOA is almost identical to the 5W30 RT posted. 11.99 @ 100C falls short of the SAE 40 grade, and the minimum HTHS for 0W40 - 10W40 is suspect.
[Re: userfriendly]
#4898861
10/17/18 04:39 PM
oil_film_movies
Posts: 4,672 |
The 0W40 VOA is almost identical to the 5W30 RT posted. 11.99 @ 100C falls short of the SAE 40 grade, and the minimum HTHS for 0W40 - 10W40 is suspect. Only in KV100 is it similar. Additive package between Rotella T6 0w-40 & Rotella T6 Multi-vehicle 5w-30 is a lot different. Also, a 0w40 is usally formulated with thinner base oils than 5w30 here.
[Re: SubaJew]
#4915948
11/05/18 07:14 PM
CT8
Posts: 14,214 |
Do you have to mail order the 0w?
