I'm changing out the oil of a dana 60 and 80 on a 97 dodge ctd. I spent allot of time removing the old silicone from the differential cover and case and decided I don't want to do that next time and ordered a few paper gaskets to try a method Ive had good luck with so far. Iv used this method on other engine covers, but never a differential cover
I usually adhere the gasket to the cover side with the Right Stuff, then apply Permatex #2 non drying on the case side so that I can remove the cover easily and reuse the gasket. I install it quickly and snugged up maybe 10 lbs, and then torque it home 30-60 minutes later. Ive read removing parts the right stuff has been used on is even more difficult than RTV, so I definitely don't want to use it that way.
Has anyone used this method on a differential? I don't see why if wouldn't work, but just throwing this out there.
Thanks!
Thanks!
