RATS
by MrQuackers - 12/07/19 07:46 PM
Topics298,432
Posts5,135,286
Members70,066
Most Online3,589 Nov 2nd, 2019
Re: 2018 Subie Crosstrek 1st oil change
[Re: goodtimes]
#4893788
10/11/18 09:37 AM
Miller88
Posts: 13,742 |
DO NOT use a 12 point socket on the 14mm drain plug. For some reason they put the small drain plug in and then painted it. You can't fit a 13mm on it (or 1/2), but 14mm and 9/16 are lose on it. If you use a 12 point, you will strip it. they make 17/32 wrenches,.sockets, how about that? It might actually be the right size. Though, it doesn't use the American system, so I think 13.5 or "13,5mm" is more appropriate!
18 Forester 2.5I 6M 00 Jeep XJ 01 F-350 4x4 5M
[Re: dave123]
#4893789
10/11/18 09:38 AM
Miller88
Posts: 13,742 |
1st change on my 18 WOW that drain bolt is Tiiiiight!!!! Mine OEM filters only all cut yea it’s a decent filter no problems almost 30k I like the engine never a drop burns. Zepro high moly 0W20. I couldn't get mine off without some work. I was afraid of rounding it even with a 6 point. I ended up taking a sledge hammer to a 1/2'' drive 6 inch ratchet in order to get it off. I didn't want to yarn on it with a breaker bar and have more risk of rounding it.
[Re: aba4430]
#4893926
10/11/18 12:04 PM
nthach
Posts: 6,074 |
Before anyone goes bonkers, the Purolator Boss PBL 14615 is a good filter for the CrossTrek. My son used it on his 18 CrossTrek (@2400 miles now) and I have used it on our 17 OB 2.5 with no issues. The start up rattle is subdued with the PBL14615 on the OB...…., vs. the original blue Subie filter. I am presently running the Fram Ultra 7317 on the OB and will go back to the PBL14615 next time. Motorking told me the 7317 filters are OK for Subaru applications in Ultra or Tough Guard flavors or he might have mentioned that publically. The specs on that Purolator look good, maybe I should try one and send it into '53 Stude for a teardown. I use the Toyota 90915-YZZS1 filter for the FR-S/FT-86, made by Denso in Thailand and it's a fat and short filter that just clears the lip on the oil filter mount. I prefer the OEM Fram-made filter myself but I hate Subaru parts departments.
[Re: Miller88]
#4894201
10/11/18 06:30 PM
fdcg27
Posts: 17,054 |
1st change on my 18 WOW that drain bolt is Tiiiiight!!!! Mine OEM filters only all cut yea it’s a decent filter no problems almost 30k I like the engine never a drop burns. Zepro high moly 0W20. I couldn't get mine off without some work. I was afraid of rounding it even with a 6 point. I ended up taking a sledge hammer to a 1/2'' drive 6 inch ratchet in order to get it off. I didn't want to yarn on it with a breaker bar and have more risk of rounding it. Other people have mentioned this challenge with this engine, so I approached the first drain with some trepidation. This proved to be misplaced since the plug on our '17 came out with no special effort. Part of the problem that people may be having with the drain plug and rounding may be a result of the awkward angle of the plug on the sump as well as the small hatch that Subaru gives you to get to it. You do have to be careful to properly seat the socket. After that, a clean change is really easy with these as is the case with every Subaru we've owned.
18 Accord Hybrid 20K HGMO 0W-20 17 Forester 30K VME 0W-20 12 Accord LX 115K SSO 0W-20 09 Forester 119K M1HM 5W-30 96 Accord LX 104K T5 10W-30 95 318i
[Re: nthach]
#4894572
10/12/18 09:04 AM
1bioguy
OP
OP
Posts: 199 |
Before anyone goes bonkers, the Purolator Boss PBL 14615 is a good filter for the CrossTrek. My son used it on his 18 CrossTrek (@2400 miles now) and I have used it on our 17 OB 2.5 with no issues. The start up rattle is subdued with the PBL14615 on the OB...…., vs. the original blue Subie filter. I am presently running the Fram Ultra 7317 on the OB and will go back to the PBL14615 next time. Motorking told me the 7317 filters are OK for Subaru applications in Ultra or Tough Guard flavors or he might have mentioned that publically. The specs on that Purolator look good, maybe I should try one and send it into '53 Stude for a teardown. I use the Toyota 90915-YZZS1 filter for the FR-S/FT-86, made by Denso in Thailand and it's a fat and short filter that just clears the lip on the oil filter mount. I prefer the OEM Fram-made filter myself but I hate Subaru parts departments. AGREED! I called the parts dept and they sounded like I was bothering them...NAPA here i come...
[Re: 1bioguy]
#4894576
10/12/18 09:05 AM
1bioguy
OP
OP
Posts: 199 |
"Other people have mentioned this challenge with this engine, so I approached the first drain with some trepidation. This proved to be misplaced since the plug on our '17 came out with no special effort. Part of the problem that people may be having with the drain plug and rounding may be a result of the awkward angle of the plug on the sump as well as the small hatch that Subaru gives you to get to it. You do have to be careful to properly seat the socket. After that, a clean change is really easy with these as is the case with every Subaru we've owned."
This was helpful , been afraid to try...
[Re: 1bioguy]
#4894626
10/12/18 10:15 AM
PimTac
Posts: 11,686 |
On a brand new vehicle it’s usually the paint that hinders the first loosening of the drain plug. I use a small sharp knife to score around the plug. The rest is brute strength.
I would rather use a longer ratchet like a 12-14” than hitting it with a sledge hammer. Then again, I was t there.
The filters are usually the hardest part to loosen in a new car.
2017 Mazda CX5 Havoline Pro DS 0w20 Roki OEM filter.
[Re: PimTac]
#4894778
10/12/18 01:12 PM
sw99
Posts: 2,528 |
The Subaru bypass setting on factory filters is 23 psi. The Premium Guard PG4615 filter has this exact setting and sell for $1.68 at Rock Auto. I have been running these to 7500 miles and they look fantastic upon the end of life inspection.
[Re: 1bioguy]
#4897248
10/15/18 03:50 PM
1bioguy
OP
OP
Posts: 199 |
Anybody use the Fram Racing HP17??
[Re: Miller88]
#4897281
10/15/18 05:06 PM
goodtimes
Posts: 3,120 |
DO NOT use a 12 point socket on the 14mm drain plug. For some reason they put the small drain plug in and then painted it. You can't fit a 13mm on it (or 1/2), but 14mm and 9/16 are lose on it. If you use a 12 point, you will strip it. they make 17/32 wrenches,.sockets, how about that? It might actually be the right size. Though, it doesn't use the American system, so I think 13.5 or "13,5mm" is more appropriate! 17/32 is 13.5 essentially. http://mdmetric.com/tech/cvtchtfdm.htm
