Originally Posted by Cressida
If you are wanting long term protection and durability, I would spray it two coats (or more) with an epoxy primer. Then depending on how much you care about looks and UV protection you could follow that with a top coat of your finish color.
I've been around here long enough to know that reason has little chance against the entrenched US consumer "buy stuff" fetish, but REALLY?
This is an angle-iron barrier. As I read it, it has little inherent value, doesn't have to look pretty or colour match anything, and any finish applied is quite likely to get damaged.
The treatment I suggest is free (Shee-oot, caiyn't be no daym guid theyn), very easy to apply, very very easy to re-apply, effective, and non-toxic.
You can apply it with your bare hands, (you'll have to wash them afterwards), No brush or spray equipment (or its cleaning) or respiratory protection involved at any time.
Those characteristics are hard to beat. I'm VERY confident you can't beat them with a sprayed epoxy.
I've used that Hammerite stuff (admittedly on a boat trailer, which is a high threat application) and it is pretty good, but rust does get under it, and then its toughness just gets in the way of re-treatment.
