Gsleve, Ravenol makes great oils. Its a true PAO synthetic. They don't test for tungsten on UOA's, but many Ravenol flavors have tungsten added to the moly for more friction reduction, not sure it's in this particular VMP soup. Based on your choice of a high quality oil, and if you don't take too many short trips where the oil never gets hot, it should be fine to go up to 15k miles.
Your iron wear rate looked very good, it should have been around 36 ppm for that amount of miles, and you only got 28 ppm, a win.
I don't know what anti-oxidants Ravenol uses. Their base stock oil is awesome though. I know Mobil lauds their Mobil1 Annual Protection's anti-oxidants keep the oil from ageing too much up to 20k miles (or 1 year). Without really knowing if those German chemists are using advanced anti-oxidants, its hard to say if its really possible to push past 15k miles here.
And remember, the iron wear might be fine, yet we don't know what black gunk gets on the pistons as it stays in there a long time, the real weak point (maybe that and varnish/sludge forming).
