Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
Worst relationship you've ever been in
by Lolvoguy - 06/02/20 01:58 PM
2 cycle with catalyst - carb settings?
by cjolson140 - 06/02/20 01:22 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
25 registered members (bmod305, Danno, blufeb95, Char Baby, Blueskies123, ctechbob, 3 invisible), 723 guests, and 47 spiders.
Topics306,079
Posts5,286,975
Members71,596
Should have changed it? #4876308 09/22/18 10:14 PM
P
parshisa Offline OP
P
Changed the oil in my pilot today at 3700mi (MM was at 20%) but left the filter on( Honda A01). Was that a right move it should have been changed oout as well? I feel like i did ok although would like to hear y’alls opinion
'17 Honda Civic 1.5T/ 6MT
'16 Honda Pilot 3.5NA/6AT
Re: Should have changed it? [Re: parshisa] #4876310 09/22/18 10:18 PM
T
TheLawnRanger Offline
T
According to what oil you were using, you possibly could have skipped both.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: Should have changed it? [Re: TheLawnRanger] #4876313 09/22/18 10:20 PM
P
parshisa Offline OP
P
I had to in order to be compliant with warranty requirements
Re: Should have changed it? [Re: parshisa] #4876323 09/22/18 10:32 PM
Z
ZeeOSix Offline
Z
Honda usually says to change the filter every other OCI - check the maintenance schedule.
Re: Should have changed it? [Re: ZeeOSix] #4876325 09/22/18 10:40 PM
SnowDrifter Offline
I actually didn't believe you until I looked it up
That's rather curious
2005 Tahoe - 140k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
Re: Should have changed it? [Re: parshisa] #4876326 09/22/18 10:40 PM
dave1251 Offline
According to your orginal post this was not the case.
don't use.
Re: Should have changed it? [Re: dave1251] #4876328 09/22/18 10:43 PM
P
parshisa Offline OP
P
20% or 15% on MM doesn’t make that much of a difference. Car has been up anyways so i figured why not. Free oil went in. Filter stays on. How did i do?
Re: Should have changed it? [Re: parshisa] #4876331 09/22/18 10:51 PM
T
T
I would have changed it unless the filter is rated to go a lot longer. I don't know a lot about the reputation of your filter but you should be ok if changing every 3700 miles or so.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Re: Should have changed it? [Re: TheLawnRanger] #4876340 09/22/18 11:06 PM
P
parshisa Offline OP
P
Given the fact that Honda recommends chaning filter every other OCI, my Civic would have to have filter on for around 20K ( MM on it goes on at 10K). I guess they believe it lasts
Re: Should have changed it? [Re: parshisa] #4876347 09/22/18 11:13 PM
Snagglefoot Offline
I’m trying to get 20,000 miles on a Fram Ultra using multiple OCI’s.
If you want the job done right......do it yourself.
Re: Should have changed it? [Re: SnowDrifter] #4876361 09/22/18 11:44 PM
W
Wolf359 Offline
W
Not really. If people read the manual, that's actually been standard for lots of cars.
Re: Should have changed it? [Re: Wolf359] #4876371 09/23/18 01:02 AM
SnowDrifter Offline
Curious for me. Every car I've messed with has had it spec'd oil and filter.
Saying "if people read the manual" is somewhat self defeating as most wouldn't have access to manuals of new cars, let alone memorize them and stay up to date.
2005 Tahoe - 140k
Re: Should have changed it? [Re: parshisa] #4876426 09/23/18 06:10 AM
P
PWMDMD Offline
P
I do question these MMs. You’re at 3700 miles on the oil and you’re at 20%. On my 2018 Pilot I currently have 4800 miles on the oil and I just hit 50%. It’s been a hot summer here, I’m mostly city driving, give it the beans all the time and do a fair amount of idling. Hmmm....
Current: 2019 Lexus RX 350 (Mobil AFE 0W-30 and Toyota OEM Filter) and 2018 Honda Pilot Touring (PP 5W-30 and Mobil 1 EP M1-110A Filter)
Re: Should have changed it? [Re: Wolf359] #4876427 09/23/18 06:13 AM
P
PWMDMD Offline
P
I can’t remember a single car I’ve owned that didn’t state the filter should be changed every other OC.
Re: Should have changed it? [Re: parshisa] #4876447 09/23/18 07:11 AM
Snagglefoot Offline
And every other OC is just a nominal suggestion. With a quality filter that can be 3x or 4x.
