98 Expedition heating system flow diagram
by Fitz98. 07/18/19 12:39 AM
How did I become the constable?
by Chris142. 07/17/19 11:05 PM
Changed oil, Ravenol FullSynth Turbo VST 5W-40
by NotEnoughSpeed. 07/17/19 08:30 PM
Blending TCW3 in diesel
by 32319. 07/17/19 08:27 PM
Leaking Batteries
by ecotourist. 07/17/19 08:22 PM
Shake down tow complete!
by ls1mike. 07/17/19 08:22 PM
Looking for cheap int'l air tix
by daves66nova. 07/17/19 08:05 PM
Not *new* per se, but $3.98 for 5 quarts of M1
by mrdctaylor. 07/17/19 07:45 PM
Winter tires for 2019 Ram
by NissanHauler. 07/17/19 06:16 PM
Is the car hobby/enthusiast a dying breed?
by Redright9. 07/17/19 05:48 PM
Mobil One design change M1C-154A
by piesled. 07/17/19 05:26 PM
crazy granny gear spotted
by Number_35. 07/17/19 04:32 PM
Grease gun suggestions
by rideon. 07/17/19 04:16 PM
17 Imprezza 2.0
by JHogan. 07/17/19 03:42 PM
new boat, considering twin f 150 yamis
by 1978elcamino. 07/17/19 03:20 PM
Preventative repair - 2009 Ford Flex water pump
by KGMtech. 07/17/19 02:56 PM
patman3d, Oillogger, Rob707, rageyourdreams, Beemer25
68692 Registered Users
19 registered members (csandste, ArrestMeRedZ, Bailes1992, Bjornviken, clinebarger, DV0993, 2 invisible), 656 guests, and 20 spiders.
Topics292,010
Posts5,015,199
Members68,692
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: Which Nikon DSLR? [Re: 2015_PSD] #4857355
09/01/18 06:38 PM
09/01/18 06:38 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
Well if you can wait, go on over to slickdeals.net and set up an alert for Nikon and see what pops up. I think the D7500 now is $899 as a refurb. You could also go full frame if you're really into it. Anyway, I also suggest going over to dpreview.com for more detailed info.
The D40 is still a decent camera, used one for years. Finally ended up giving it away to some kids. For web purposes, a 21 megapixel camera is kinda overkill.
Re: Which Nikon DSLR? [Re: 2015_PSD] #4857443
09/01/18 08:41 PM
09/01/18 08:41 PM
JBLM, WA
RW1 Offline
RW1  Offline
JBLM, WA
There are so many variables with photography equipment that you can drive yourself crazy trying to decide what to get. For the price range you're looking at and intended purposes, I would recommend something like the Nikon D5600 with the 18-140 lens.
The general rule of thumb is to spend more on the glass than on the body. But again, you can drive yourself crazy with all the options and spend a ton of money to boot.
I do recommend against those camera kits with 2 or 3 lenses. While they're not bad glass and you can take surprisingly good photos with them, it's a pain in the backside to carry extra lenses with you in the field. Having to change lenses under adverse conditions is also a pain. I have had to send camera bodies back to Nikon because I changed lens at the wrong time. One "do-it-all" lens saves you from that. Do they have weak spots? Of course! They all do. But the advantage of having just one single item to grab and go is amazing.
1st Rule of Photography: Have a camera. An iPhone in hand beats the professional kit back at the hotel room because it's too heavy.
2nd Rule: Be there. You can't take a picture of the sunset if you're not out there with a camera.
Bottom line- It really doesn't matter what you buy as much as having a camera with you and learning to use what you have.
Re: Which Nikon DSLR? [Re: 2015_PSD] #4857544
09/01/18 11:49 PM
09/01/18 11:49 PM
WA
Brigadier Offline
Brigadier  Offline
WA
2017 Hyundai Santa Fe SE, 3.3L, AWD, QSUD 5w30, OEM filter, Hy-per Lube ZRA
https://www.pure-gas.org/ << Wake up your engine!!
Where the stars and stripes and the eagle fly
Re: Which Nikon DSLR? [Re: 2015_PSD] #4857742
09/02/18 09:48 AM
09/02/18 09:48 AM
US
bunnspecial Offline
bunnspecial  Offline
US
My inclination would be a used/refurbed D600/D610(watch for an oily shutter on the D600) with the 24-85mm f/3.5-4.5 VR lens that's sold kitted with these. I actually use that particular combo a fair bit, even though I use a D800 as my main DSLR.
I am NOT a fan of the D3x00 and D5x00 line of cameras, and I think that an "above average amateur" would have the same dislikes of them that I do. In particular I dislike cameras that don't have a top LCD. The D3300 and D3400(and presumably also the just-announced D3500) lack the "minimum aperture switch" which means that they won't meter at all with lenses that have an aperture ring. That doesn't really matter to a good part of the target market for these cameras.
In the DX(crop sensor) realm, I think that the D7x000 bodies are something of a sweet spot. They will autofocus with all AF lenses(older bodies may have issues with AF-P lenses, and lower end bodies can't autofocus "screwdriver" lenses). The D7000-7200 all will also meter and allow aperture priority with AI and AI-S manual focus lenses(the D7500 doesn't have an AI coupling tab, so can't meter with non-CPU lenses). I'm also not wild about the D7500 because it gets rid of the second card slot.
That's just my two cents, though. I'm not afraid of buying used, and for $1200 I might try to stretch my budget and get a used D800 and 24-85...but then I'm also a full frame nut and likely won't buy another crop sensor camera.
2010 Lincoln MKZ-Mobil 1 5W-30
1970 MG MGB Roadster-Valvoline VR-1 20W-50
Re: Which Nikon DSLR? [Re: 2015_PSD] #4857970
09/02/18 03:40 PM
09/02/18 03:40 PM
Central Texas
sleddriver Offline
sleddriver  Offline
Central Texas
Once you decide, check KEH camera brokers.
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: Which Nikon DSLR? [Re: 2015_PSD] #4859643
09/04/18 02:15 PM
09/04/18 02:15 PM
Canada
camrydriver111 Offline
Canada
You already have a DSLR. Why not go mirrorless?
BITOG or: How I Learned to Stop Worrying and Love the Extended OCI
Re: Which Nikon DSLR? [Re: 2015_PSD] #4863154
09/08/18 07:58 AM
09/08/18 07:58 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
Ive been lightly into Photography for decades, more or less, if there is anyone in my family circle for photos, they know I am the one to take them.
Ive been VERY pleased with the Nikon 3400 for the last 2 years.
The 2 kit lens has been great and for super quality photos such as grandchild close up I use a Nikon 35 MM single focal lens.
The reason I choose the 3400 was size over the larger DSLRs besides good reviews on the Nikon over the other similiar size DDLR brands, if you dont mind a larger camera then your world opens up (as well as price) more but for what I do, Im very happy.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: Which Nikon DSLR? [Re: Wolf359] #4863177
09/08/18 08:11 AM
09/08/18 08:11 AM
ME
eljefino Offline
eljefino  Offline
ME
Megapixels aren't everything; the image processing and post-processing software/firmware gets better with every generation. I may have to buy a new body every decade or so. It sucks seeing cell phone pics with better processing (but worse optics) and wishing my camera were innately capable (vs shooting RAW and taking all sorts of steps later.)
Ultimately I take pictures to make myself happy. Going from my D50 to D3200 added some "wow" I wasn't expecting.
This pic is from a D3200, F/4, 1 second, braced-handheld. Has the dynamic range to include a porch light but was able to pick up the full moon sky as well. Never used to be able to pull this off.
Re: Which Nikon DSLR? [Re: 2015_PSD] #4863230
09/08/18 09:06 AM
09/08/18 09:06 AM
Canada
Canada
Low light shooting has more to do with the size of the lens than megapixels or processing.
Cell phones still suck at it because the lens is so tiny.
Re: Which Nikon DSLR? [Re: camrydriver111] #4863267
09/08/18 09:42 AM
09/08/18 09:42 AM
US
bunnspecial Offline
bunnspecial  Offline
US
Current DX and FX CMOS sensors have amazingly good high ISO capabilities.
I'll take my D800 up to ISO 6400 without even thinking about it, and I can print a beautiful 8x10 from it. The backlit sensor in the D850 is probably a stop better, and the sensor used in the D4/Df is still freakishly good. A Df at 25,600 is probably as good as my D800 at 6400.
The only real reason to use fast lenses these days is for shallow DOF. Cameras like the D800 have made me realize just how little DOF an f/1.4 lens has wide open, and also how difficult it is to actually focus them correctly in low light(something that you won't notice on Tri-X or your typical 400 ASA color print film). Between being able to use ISO 6400 without too much worry and VR(as long as I don't need to stop action) I can usually get away with a fixed f/4 zoom, or-horror of horrors-a variable aperture zoom that hovers around f/4. Even when I need to stop action, I rarely want to go past f/2.8 for DOF and focus accuracy reasons.
And yes, I have Nikkors as fast as f/1.2(although I don't have a Noct) and plenty of both AF and MF primes in the f/1.4-f/2 range
I'd also argue that the real issue with cell phone cameras is the physical size of the sensor. The optic actually are quite amazing given what they're able to resolve onto such a tiny, dense sensor-they're a lot more demanding of good optics than even something like a 24mp DX-sized sensor.
Re: Which Nikon DSLR? [Re: 2015_PSD] #4863812
09/08/18 09:22 PM
09/08/18 09:22 PM
ME
eljefino Offline
eljefino  Offline
ME
Remember, light bounces off at stuff. It's aimed at me and it's aimed an inch to the right of me.
If I have a lens and sensor big enough to catch a square inch of an object's "essence", it's going to get more photons than a pea-sized cell phone camera.
There's no replacement for displacement, and there isn't one for camera optics either.
Page 2 of 2 1 2
