1988 cadillac brougham oil disappearing
by momo - 08/25/19 01:41 PM
Amp draw
by mjk - 08/25/19 01:36 PM
SHELL cracker plant
by 53' Stude - 08/25/19 12:03 PM
Mirrored Window Film
by Warstud - 08/25/19 11:40 AM
I want a Challenger
by Jarlaxle - 08/25/19 11:33 AM
Why not?đŸ¤”
by Mad_Hatter - 08/25/19 11:10 AM
CanAm OEM oil alternatives
by Carbon12 - 08/25/19 10:46 AM
2019 Dodge Ram Classic 1500 Big Horn Brakes
by Honda2003 - 08/25/19 10:45 AM
Pontiac V8 oil observation
by CheezWhiz - 08/25/19 10:42 AM
Dillemma ...
by Baveux - 08/25/19 10:41 AM
Schaeffers vs Mobil one
by salesrep - 08/25/19 10:04 AM
Moly EP grease
by rideon - 08/25/19 09:59 AM
grease in a golf cart clutch
by jacobsond - 08/25/19 09:53 AM
Pennszoil
by JohnnyJohnson - 08/25/19 09:32 AM
Clunk from the front when I let out the clutch
by atikovi - 08/25/19 09:16 AM
M1 5w30 SN+ D1 / G2 Make Up ?
by ChrisD46 - 08/25/19 09:07 AM
2015 F150 owners manual rear diff fluid options
by Buzzinhalfdozen - 08/25/19 09:02 AM
Recommend a 7 passenger w/10,000 tow
by sasilverbullet - 08/25/19 08:54 AM
Lawn tractor problem
by supton - 08/25/19 07:57 AM
Jobs and social interaction
by ZZman - 08/25/19 07:52 AM
Faux, jk1401, EricTwoCamaros, Subie5w30, Iautox
69057 Registered Users
103 registered members (2010Civic, 2K2AcuraTL, ABerns, Alex_V, Ag76, 13 invisible), 2,489 guests, and 27 spiders.
Topics293,782
Posts5,046,652
Members69,057
Most Online3,532
Jul 30th, 2019
G11 HOAT/IAT confusion #4849328 08/24/18 02:12 AM
F
FordCapriDriver Offline OP
F
I'm investigating again what coolant to use in my Escort, i've found this which looks appealing.
https://www.repsol.com/imagenes/global/en/max_quality_pure_coolant_antifreeze_tcm14-25160.pdf
" It is free of amines,
nitrites and phosphates
So it's free from the typical Inorganic additives found in European IAT coolants, except Silicates, which seems appealing as Silicates are for aluminium and my engine has everything but the block made of aluminium.
This to me sounds like a HOAT right? aren't most HOAT's, OAT's with silicates in Europe, and OAT's with Phosphates in Japan?
It doesn't say specifically on the datasheet wether it's IAT, HOAT or OAT, however it meets VW TL744 C, which is a G11 spec, it's also blue like most / all G11s
So we know it's G11, however isn't G11 supposed to be a full IAT, with nitrates, phosphates, amines etc etc included?
I'm debating wether to use this, or a G12++ Si-OAT made by the same company.
1975 Ford Capri II Ghia 3000 V6 - Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - Shell Rimula R4X 15W-40 HDEO
Re: G11 HOAT/IAT confusion [Re: FordCapriDriver] #4849334 08/24/18 02:38 AM
FowVay Offline
If you have access to it then I would definitely use the G12++ or even G13. G13 simply lasts longer and does a better job of preventing corrosion.
Re: G11 HOAT/IAT confusion [Re: FordCapriDriver] #4849344 08/24/18 03:38 AM
F
F
Kind of worried about issues with lead solder and OATs in a 30 year old cooling system.
Re: G11 HOAT/IAT confusion [Re: FordCapriDriver] #4849380 08/24/18 06:00 AM
Sayjac Offline
Depending on just how worried, then 'imo' an original/conventional green IAT AF would be absolute "safest" choice. That would have been original spec, at least here. That's easily found here as Motorcraft Premium AF green or an equivalent. Some original green IAT's here are low(er) silicate and have a longer service interval.
Don't know anything about G11/G12, but according to Wolflubes it would be a better choice than G13. That said, don't how authoritative or specifically applicable it would be to the Escort.
https://www.wolflubes.com/EN_EU/Blog/201...nd-coolant.aspx
Re: G11 HOAT/IAT confusion [Re: FordCapriDriver] #4849397 08/24/18 06:46 AM
T
Trav Offline
T
G12+ or G12++ is what you want in that car.
Re: G11 HOAT/IAT confusion [Re: FordCapriDriver] #4849417 08/24/18 07:20 AM
F
F
I could also get one that is G12+, that claims to have no Silicates, amines, phosphates, nitrates or borates.
Would that be good?
Re: G11 HOAT/IAT confusion [Re: FordCapriDriver] #4849818 08/24/18 03:23 PM
T
Trav Offline
T
Yes that should work well with the aluminum, copper, brass, solder, iron, etc parts in this engine.
Re: G11 HOAT/IAT confusion [Re: FordCapriDriver] #4852140 08/27/18 09:00 AM
F
F
I think i'mg going to go with G-13, it seems to be just what i want, an OAT with Silicates, but no nitrates, amines, phosphates or borates.
Re: G11 HOAT/IAT confusion [Re: FordCapriDriver] #4869280 09/15/18 10:35 AM
T
Tikka Offline
T
Hi
Have you ever considered the waterless coolants? I have read of them being used in the older classic cars to good effect.
Tikka.
Re: G11 HOAT/IAT confusion [Re: FordCapriDriver] #4869281 09/15/18 10:39 AM
K
kschachn Online Content
Online Content
K
Waterless coolants are an inferior choice for nearly every application. The heat transfer is inhibited, the specific heat capacity is lower, and the freezing point is elevated. For any application with a thermostat there is no upside.
1994 BMW 530i, 246K
1996 Honda Accord, 280K
1999 Toyota Sienna, 420K
2000 Toyota ECHO, 281K
Re: G11 HOAT/IAT confusion [Re: FordCapriDriver] #4869285 09/15/18 10:53 AM
F
F
There's a channel on Youtube that put Evans Waterless to the test and honestly it did not fare well.
Heat transfer significantly worse than normal coolants, unknown long terms effects on metals.
Sadly a lot of people seem to have bought into it, atleast on the forums and groups i'm in.
Re: G11 HOAT/IAT confusion [Re: FordCapriDriver] #4871086 09/17/18 12:49 PM
T
Tikka Offline
T
Hi Gents
Well, you live and learn. Would be interesting to read some science based evidence for and against.
Re: G11 HOAT/IAT confusion [Re: Tikka] #4871120 09/17/18 01:35 PM
K
Online Content
K
Originally Posted by Tikka
Hi Gents
That’s very easy for you to find yourself. Just start with the terms that I used in my response. Plain water has the best heat transfer and the highest specific heat capacity, but to improve the boiling and freezing point it is mixed with glycol. A formulated antifreeze brings along corrosion inhibitors and other useful substances. There are many threads here on this site that discuss it in detail.
There are no upsides for any passenger car application with a thermostat.
1994 BMW 530i, 246K
Re: G11 HOAT/IAT confusion [Re: kschachn] #4871321 09/17/18 06:25 PM
T
Tikka Offline
T
Hi Gents
Yes that is fair comment. I should have said 'will' instead of 'would'.
Tikka.
