Anyone backing up their data online?
by gonefishing - 11/21/19 09:52 AM
Fram Ultra C&P
by mpgo4th - 11/21/19 09:19 AM
2001 Nissan Sentra / trans issue?
by Mark72 - 11/21/19 09:10 AM
CVT Maintenance for CVT Dummies
by Brons2 - 11/21/19 09:00 AM
Wix/ Napa best oil Filters
by edward51956 - 11/21/19 08:54 AM
Mahle OC84, 1974 BMW 2002
by wings&wheels - 11/21/19 08:48 AM
Oil is staying clean on Kubota L3560!
by Rglossip - 11/21/19 08:41 AM
7317 or 6607?
by cwilliamsws6 - 11/21/19 08:00 AM
Dana S110 Lube change
by Parkman - 11/21/19 07:21 AM
2003 GMC Sierra 1500HD 6.0L
by Redright9 - 11/21/19 07:17 AM
Canadian Tire Early Black Friday
by Snagglefoot - 11/21/19 07:07 AM
Viscosity at 85°C vs 100°C
by doyall - 11/21/19 06:58 AM
New tires for 1988 Toyota Pickup 4x4 22re
by Yota88 - 11/21/19 04:18 AM
Jeep Cherokee Rumble
by Nick1994 - 11/20/19 11:48 PM
2021 RAV4 Hybrid AWD hot rod
by AZjeff - 11/20/19 10:50 PM
0W30 with MB 229.52 and VW 507 for Canadians
by Snagglefoot - 11/20/19 10:12 PM
Andrewm72, FarmGuy, ImBoosted, XpressAuto, Jmpage388
69926 Registered Users
103 registered members (28oz, 1WildPig, 77GrandPrix, 2010Civic, Aichiguy, 379KITTY, 7 invisible), 1,886 guests, and 38 spiders.
Topics297,720
Posts5,121,250
Members69,926
Most Online3,589
Nov 2nd, 2019
2003 Ford Ranger won't start #4847791 08/22/18 02:49 PM
T
Tdbo Offline OP
T
Vehicle is the Ranger in my signature.
Drove the vehicle on Sunday without issues. Did not drive it on Monday. Went out to start it at 6 AM on Tuesday, and got nothing but clicks. Strong headlights and dash lights, just not enough to start it. Checked the overhead dome light to see if it was left on. No sign of it. Ended up taking the Accord on my trip.
Got home last night. Still nothing but clicks. Truck started instantly with a jump. Battery is a 4.5 year old AAP Silver. Went to AAP and had battery, starter and alternator tested. Battery tested "Good" at 12.73V and 487/550 CCA. Starter (10.7V) and alternator (13.64V under load) both tested normal. Cables on the battery are clean and tight, and truck has started flawlessly ever since.
Ideas on what could be going on?
Re: 2003 Ford Ranger won't start [Re: Tdbo] #4847829 08/22/18 03:14 PM
T
tomcat27 Offline
T
Did you remove the battery terminal connector and inspect it?
2019 Cherokee, 2018 Jetta, 2014 Sentra, 2001 Camry, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: 2003 Ford Ranger won't start [Re: Tdbo] #4847833 08/22/18 03:15 PM
M
MasterSolenoid Offline
M
Watching to LEARN something. Coffee
2002 Ford Ranger
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: 2003 Ford Ranger won't start [Re: Tdbo] #4847836 08/22/18 03:22 PM
R
ragtoplvr Offline
R
Starters often become intermittent before failing completely. Often the brushes are worn, and spring pressure is low, and they just do not get started. Jump at a higher voltage and current, and off they go. How many miles.
Rod
Re: 2003 Ford Ranger won't start [Re: Tdbo] #4847860 08/22/18 03:44 PM
T
Tdbo Offline OP
T
Went out to check the terminals more closely and found this. While it was not the complete crack that I found (and replaced) on the positive side this past winter, Id guess that this doesnt look normal:
Last edited by Tdbo; 08/22/18 04:06 PM. Reason: Unsuccessful attempt to post photo.
Re: 2003 Ford Ranger won't start [Re: ragtoplvr] #4847874 08/22/18 04:04 PM
T
Tdbo Offline OP
T
Rod
It is pushing 110K. I certainly wouldn't rule that out, based on age more than miles.
Back to the battery terminal that I tried to insert the photo of, the neg. terminal is not cracked, but it looks like a piece of the terminal was missing, almost looked like the shape was stamped in. Weird. Will try a replacement of that first.
2012 Honda Accord LX-P 100K
2008 Ford Mustang Pony Package Convertible 17K
2006 Honda Odyssey EX-L 77K
2003 Ford Ranger 3.0 Supercab 122K
Re: 2003 Ford Ranger won't start [Re: Tdbo] #4847965 08/22/18 06:04 PM
Colt45ws Offline
I would try fixing the terminal. What you did by jumping it is decrease the resistance of the ground the starter was seeing.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: 2003 Ford Ranger won't start [Re: Tdbo] #4848034 08/22/18 07:28 PM
B
BigD1 Offline
B
Don't trust the AAP starter test 100%.
I was servicing a 2008 Honda Civic. It had intermittent no crank just click, and at other times it would fire right up. Cleaned all the terminals, and bought a new battery. Owner wanted a new one, so I obliged. New battery did not fix the problem, and it still had the intermittent no start problem.
Took the starter to AAP, and they put it on their machine, and it passed. Bought a new starter, and no more problems. Old original factory starter had just north of 100,000 miles.
1992 Toyota Pickup--AmazonBasics Conventional--10W-30--Toyota 90915YZZD1
Re: 2003 Ford Ranger won't start [Re: Tdbo] #4848038 08/22/18 07:32 PM
B
bullwinkle Offline
B
^It's possible to have dead spots on the armature where the brushes make contact, and also have bad contacts in the solenoid (or relay, if it's like older Fords) that can cause intermittent problems. Good catch on the battery terminal-your original symptoms sure sounded like a bad battery or bad connections.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: 2003 Ford Ranger won't start [Re: ragtoplvr] #4848111 08/22/18 08:57 PM
CT8 Offline
Rod
Starter solenoid?
Re: 2003 Ford Ranger won't start [Re: Tdbo] #4848137 08/22/18 09:16 PM
F
FermeLaPorte Offline
F
If it is a 3.0 v6--- same as the old Aerostars-- it's gon get bad
Re: 2003 Ford Ranger won't start [Re: Tdbo] #4848170 08/22/18 09:47 PM
V
vwmaniaman Offline
V
Ford starters have a bolt on the back of the starter that provides the ground side connection for the brushes. This bolt gets corrosion under it and makes the starter intermittent. Happened on my sons ford van. He changed it with a new starter and within a few days it had the same issue. It was a Motorcraft remanufactured one and it had that problem too. Cleaned it up and tightened it back down and no more problems.
Don't waste your time on a slipshod repair.
Re: 2003 Ford Ranger won't start [Re: Tdbo] #4848409 08/23/18 06:46 AM
StevieC Offline
Have you tried hitting the starter with a hammer? If this corrects it, replace or rebuild the starter.
'18 Caravan - 45k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: 2003 Ford Ranger won't start [Re: Tdbo] #4848716 08/23/18 12:27 PM
T
Tdbo Offline OP
T
UPDATE: Just put a new terminal on it. Original problem has not repeated itself again.
If this does not resolve issue, perhaps it will buy me some time to find a local rebuilder.
