Hyundai ELantra ATF follow up
by flinter. 07/17/19 10:14 AM
Poor Bill
by 4WD. 07/17/19 10:05 AM
Cadillac parked for 25 years...
by mattwithcats. 07/17/19 09:52 AM
Sumitomo Encounter Tires
by parshisa. 07/17/19 09:40 AM
API 1509 Updated with New GF-6B Shield
by Solarent. 07/17/19 07:27 AM
Car Vac Recommendations
by klt1986. 07/17/19 07:05 AM
ECU Cooling
by ET16. 07/17/19 05:58 AM
How's your idle?
by SteveSRT8. 07/17/19 05:47 AM
A01s From Korea branded FourGreen?
by David1. 07/17/19 05:01 AM
New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
'82 BMW 733i M30 - Which Oil
by TXCarGeek. 07/17/19 02:07 AM
Aother MEGA score+Free Mobil 1 oil change
by GMguy84. 07/17/19 12:39 AM
I think I need therapy...
by tony1679. 07/16/19 11:53 PM
Hellcat engine in a Miata
by hate2work. 07/16/19 09:59 PM
Alignment shop questions
by Jeff999. 07/16/19 09:45 PM
ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
prof_redbeard, drnc, blackseven, EdK, guru2019
68686 Registered Users
102 registered members (66ROGUE, 1978elcamino, 928, ad244, AandPDan, 13 invisible), 2,248 guests, and 28 spiders.
Topics291,984
Posts5,014,615
Members68,686
Most Online2,967
Mar 10th, 2019
RELIABILITY OF 2 LITER DI/TURBO ENGINES #4844529
08/19/18 12:57 PM
08/19/18 12:57 PM
Round Rock Texas
jrcowboys Offline OP
Round Rock Texas
GUYS:
Just wondering what you think the reliability will be (long term use) of the new 2 liter DI/Turbo engines that produce a lot of power (255 HP, 273 torque)? They sound great, small engine, good gas mileage, great power, etc, but will they hold up for 200-300K miles? Example: The BMW has 11 to 1 compression ratio, which seems awfully high for a turbo engine.
Thoughts?
JR
Re: RELIABILITY OF 2 LITER DI/TURBO ENGINES [Re: jrcowboys] #4844533
08/19/18 01:02 PM
08/19/18 01:02 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
Toyota, Nissan, Mazda, Honda have been doing them for ages. Toyota thru Daihatsu has been doing 1L turbo-charged engines that are still running and are more than 15 years old.
Europoor engines? I don't think those will hold up. They are sports engines.
Diesel european engines? I think they are good.
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: RELIABILITY OF 2 LITER DI/TURBO ENGINES [Re: jrcowboys] #4844539
08/19/18 01:06 PM
08/19/18 01:06 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Hyundai in sig
6 years (bought in 2012) and 110k miles later...zero issues. Which goes for almost everyone else i know with this tech. Be they domestic or foreign makes.
This TGDi/GDi paranoia is overblown.
2018 KIA Sportage LX 2.4 AWD:
QSAD 5W-20, PH9688
Next: M1 HM 10W-30, PH9688
2013 Hyundai Santa Fe Sport 2.0T:
PP 5W-30, OE
Re: RELIABILITY OF 2 LITER DI/TURBO ENGINES [Re: jrcowboys] #4844558
08/19/18 01:27 PM
08/19/18 01:27 PM
British Colombia
VinceVaughnce Offline
British Colombia
The first real high-torque GDIT 4 cylinder was the Mazda 2.3L DISI in 2004. They were pretty reliable, inspired the whole industry and taught us all about LSPI and ignorant tunes. People made a big deal about chain issues when OCIs were neglected and turbo seals leaking on the Borw Warner K04s when thin ILSAC oils were used and engine was shut down hot, but that engine had rock solid machining, metallurgy and design (particularly cooling and lube). That new-on-the-market DISI engine was more reliable than a lot of normal engines at the time that were fraught with head gasket issues, warping, oil burning etc.
So, that was in 2004. I think no one really needs to worry about it now, in 2018. Not saying they're all reliable, but it's already proven that the technology isn't the differentiating factor.
Re: RELIABILITY OF 2 LITER DI/TURBO ENGINES [Re: jrcowboys] #4844620
08/19/18 02:29 PM
08/19/18 02:29 PM
USA
slacktide_bitog Offline
USA
They are ok if you use premium gas and synthetic 5w30 or 40 (HTHS > 3.5 preferred) with regular OCI's.
Problems arise when they try to put 0w20 and regular in a turbo. That combination does NOT work in a turbo, especially a DI turbo TGDI mad
d1g2 5w30 minimum, dexos2 5w30 or 40 better, A3/B4 even better than that
Re: RELIABILITY OF 2 LITER DI/TURBO ENGINES [Re: slacktide_bitog] #4844637
08/19/18 02:47 PM
08/19/18 02:47 PM
Cali
Malo83 Offline
Malo83  Offline
Cali
GM has improved their 2.0T LTG engines for performance and reliability, key to keeping them in top shape is premium top tier gas and synthetic oil changes, stay away from extended oil changes cheers
http://gmauthority.com/blog/gm/gm-engines/ltg/
Re: RELIABILITY OF 2 LITER DI/TURBO ENGINES [Re: jrcowboys] #4844642
08/19/18 02:54 PM
08/19/18 02:54 PM
Hudson valley
Oildudeny Offline
Oildudeny  Offline
Hudson valley
I believe if you're the original owner do the routine maintenance run the correct oil don't beat the peepee out of the engine it will hold up.
Re: RELIABILITY OF 2 LITER DI/TURBO ENGINES [Re: jrcowboys] #4844644
08/19/18 02:56 PM
08/19/18 02:56 PM
Sask, Canada
BrianF Online content
BrianF  Online Content
Sask, Canada
My brother just picked up a 2019 Acura RDX with its turbo DI four cylinder. They indicate premium is preferable and wanting 20 weight oil.
2006 Trailblazer LT. QSUD, Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30, Baldwin BT7349.
1993 GMC 1500. QSAD, Fram PH5
Re: RELIABILITY OF 2 LITER DI/TURBO ENGINES [Re: jrcowboys] #4844649
08/19/18 03:03 PM
08/19/18 03:03 PM
Ajax,Ontario, Canada
Pelican Offline
Pelican  Offline
Originally Posted By: jrcowboys
GUYS:
Thoughts?
JR
Under ideal conditions with ideal maintenance they would, but under our everyday driving with the average driver's mechanical knowledge not on you nelly !!!
Re: RELIABILITY OF 2 LITER DI/TURBO ENGINES [Re: wemay] #4844719
08/19/18 04:37 PM
08/19/18 04:37 PM
E. Tennessee
WhizkidTN Offline
WhizkidTN  Offline
E. Tennessee
Originally Posted By: wemay
Hyundai in sig
I too am a very happy owner even with less miles than you but with lots of power creating modifications (and it sure is FUN).
But to be fair, Kia/Hyundai's 2.0L T-GDI engines have had their own set of issues both in how well they are maintained by their owners (they really, really need OCI of 5K miles or less with a great oil) and how they initially were built at the factory (the bearing journal debris recall of ~2% of certain engines built which caused blown rods, etc.). These engines are known to pop plugs that are too hot a range (screwing the engine) under hard load conditions with inferior gas, create intake valve carbon deposits over a long time frame, etc. There are of coarse good mitigations for all these things which an owner can employ.
Just remember, No technology or manufacture is perfect 100% of the time. BUT, the odds are with you if you use good common sense (a rare thing these days), excellent maintenance habits and trust in reasonable economies of scale when it comes to building these complex machines millions of times by both robots and humans. I'm still a fan!
His: '12 Kia Optima SX - 2.0L GDI Twin-Scroll Turbo [Tuned] (82K)
>EDGE 0W-40, Fram XG9688
Her's: '14 Nissan Rogue SL AWD - 2.5L NA (87K)
>EDGE 0W-20, Fram XG6607
Re: RELIABILITY OF 2 LITER DI/TURBO ENGINES [Re: jrcowboys] #4844729
08/19/18 04:59 PM
08/19/18 04:59 PM
Georgia
MParr Offline
MParr  Offline
Georgia
Being the owner of a Ford Escape 2.0T, I have to agree with the Hyundai/KIA guys. Forget the oil life monitor and change the oil at 5,000 miles. Use a good quality synthetic 5W30 or 5W40. I either run premium gas or non-ethanol 87 octane. The engine performs better and gives better fuel mileage on those two fuels.
2019 VW Tiguan SE Now: Factory fill & OEM filter
2017 Ford Escape SE 2.0T Now: NAPA Synthetic 5W30 & NAPA Gold 1348
Re: RELIABILITY OF 2 LITER DI/TURBO ENGINES [Re: wemay] #4844743
08/19/18 05:23 PM
08/19/18 05:23 PM
NC
BigD1 Offline
BigD1  Offline
NC
Hyundai in sig
I think a lot of Lexus IS250 owners would disagree that the DI carbon problem was overblown. Plenty of pictures on the net, and even Lexus extended the warranty on those engines.
1992 Toyota Pickup--Quaker State Advanced Durability 10W-30--Motorcraft 910S
Re: RELIABILITY OF 2 LITER DI/TURBO ENGINES [Re: FermeLaPorte] #4844749
08/19/18 05:32 PM
08/19/18 05:32 PM
KS
FordBroncoVWJeta Offline
KS
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: RELIABILITY OF 2 LITER DI/TURBO ENGINES [Re: jrcowboys] #4844921
08/19/18 09:26 PM
08/19/18 09:26 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
The VW 2.0T is holding up well.
Re: RELIABILITY OF 2 LITER DI/TURBO ENGINES [Re: BigD1] #4845086
08/20/18 05:34 AM
08/20/18 05:34 AM
Mississippi
Speak2Mountain Offline
Mississippi
I agree. I have 152K so far no CB issues. But, I keep it on the highway and it helps having a manual and let it rev pretty high b4 shifting.
I add Gumout PEA multi to crankcase about 1K miles b4 OCI and Gumout PEA every other tankful.
