Originally Posted By: billt460
While we're on the subject of computer pictures. Does anyone know how to get rid of those stupid green check marks that cover up over half of the thumbnail photo when you open, "My Pictures"?
Follow the below instructions:
1. Depress "Windows" key
2. Type "File Explorer Options"
3. Select "File Explorer Options" from the list to open the File Explorer Options window
4. Select "View" tab at the top of the File Explorer Options window
5. Ensure the following is unchecked:
a. "Use check boxes to select items"
6. Select "Apply"
7. Select "OK"
If anyone else is curious about which options are available, follow steps 1 through 4 above and read each option. Change one at a time to change and continue at step 6. If the option works for you, leave it. If it doesn't (un) check, and follow steps 6 and 7 above, as necessary, until you're satisfied.
