Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
Opinion Of Dodge Nitro
by Warstud. 02/20/19 09:26 PM
Cheap first car
by LeakySeals. 02/20/19 09:08 PM
Grand Caravan break in
by pda1122. 02/20/19 09:07 PM
Million mile Lexus
by Skippy722. 02/20/19 08:57 PM
Antioxidant additive overdose
by xomyeusun. 02/20/19 08:50 PM
F15 Arrested Landing at Portland.
by PimTac. 02/20/19 08:43 PM
Why is Mobil 1 0w30x1 rated higher than most
by spiderbypass. 02/20/19 08:14 PM
Castrol Confusion
by PWMDMD. 02/20/19 07:13 PM
Crashed the Volt this morning...
by 14Accent. 02/20/19 06:55 PM
Best place to file online for Fed taxes?
by Vern_in_IL. 02/20/19 06:47 PM
vavoline instant oil change
by silver1. 02/20/19 06:23 PM
alienyouth33, RoyFJ, Intell77, RA_TJ, tiberius54
67294 Registered Users
63 registered members (69Torino, Best F100, Billbert, Astro_Guy, alarmguy, 8 invisible), 791 guests, and 53 spiders.
Topics284,589
Posts4,872,994
Members67,294
Most Online2,548
Feb 16th, 2019
01 kdx220r newbie qs #4808733
07/08/18 10:03 PM
07/08/18 10:03 PM
New England
pda1122 Offline OP
pda1122  Offline OP
New England
Just bought this bike and just got back from riding a dirt bike for the first time ever! So much fun. Anyways I was wondering what kind of oil I should run? The previous owner said he used Maxima Castor. Im pretty sure the local shop carries Maxima products and looking online, there seems to be several oils to choose from. Im confused, is Castor really best for my application when I am much too new to actually get anywhere close to the potential of the bike? I mean I feel like Im in too low of a gear most times because Im afraid of the power. The shop might carry Klotz and other popular brands if that affects the decision. I am definitely going to ask them for help also. I just would like your opinions as well.
Also what is everyone running for chain lube? Im thinking clean with wd40 and lube with Maxima chain wax. Is this good SOP? The previous owner said he only uses wd40 to clean/lube. He claims hes been around bikes for 30 years and he doesnt have faster wear doing so. Says the wax attracts dirt and in his opinion makes chain wear faster. Just weird to me since I know wd40 is more of a cleaner than lubricant but if I lube it every ride like he says, maybe Id have no issues also.
For clutch fluid the previous owner said he runs Castrol 80w-90 gear oil. I couldnt help but notice this has limited slip additive. Is that a problem? I have Lucas 75w-90 synthetic that I could use if that would suffice. I saw some of you using atf type-f as well. Where would I find that and what brand?
Now onto the air filter. What would I use to clean and lube with?
Anything else I might be missing? Thanks all!
'13 Toyota Tundra 5.7-Idemitsu
'08 Hyundai Elantra-Mobil 1
'96 Ranger R72 90hpJohnson
'03 Ski Doo REV 600 H.O.
�01 Kawasaki KDX 220r
Re: 01 kdx220r newbie qs [Re: pda1122] #4808739
07/08/18 10:25 PM
07/08/18 10:25 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
I like torco oil. But any oil you get at the bike shop will be fine. Put an O-ring chain and new sprockets on it and don't lube it. Lube just attracts dirt which grinds the chain and sprockets up. If it has a foam air filter you want that gooey maxima filter oil
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 01 kdx220r newbie qs [Re: pda1122] #4808741
07/08/18 10:31 PM
07/08/18 10:31 PM
New England
pda1122 Offline OP
pda1122  Offline OP
New England
He said something about oring and chain, prob is one
Re: 01 kdx220r newbie qs [Re: pda1122] #4808747
07/08/18 10:48 PM
07/08/18 10:48 PM
Chris142 Offline
Chris142  Offline
Look at the chain and see if you see orings between the links
Re: 01 kdx220r newbie qs [Re: pda1122] #4808750
07/08/18 10:59 PM
07/08/18 10:59 PM
New England
pda1122 Offline OP
pda1122  Offline OP
New England
Is running 32:1 as he did too rich?
Re: 01 kdx220r newbie qs [Re: pda1122] #4808764
07/09/18 12:53 AM
07/09/18 12:53 AM
New Zealand
Silk Offline
Silk  Offline
New Zealand
I wouldn't run a castor oil, it makes hard carbon. You have power valves to keep clean...I know on the old KDX200's they would sieze and then strip the gears that opperate them. The KDX220 was like the Yamaha DT230, the extra capacity over the 200's and tuned for more bottom end - they come on strong down low, it feels a bit much at times, but are less savage in the top end.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - 5W-40 Castrol Magnatec diesel.
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: 01 kdx220r newbie qs [Re: pda1122] #4808793
07/09/18 04:21 AM
07/09/18 04:21 AM
BC, Canada
marc1 Offline
marc1  Offline
BC, Canada
Nice bike, I recently sold my 05 KDX220. I wish this bike wasn't discontinued.
This is what I used for the life of my bike:
Engine Pre-Mix - Redline 2 Stroke Racing Oil at 50:1 https://www.redlineoil.com/two-stroke-racing-oil
Gear Box - BelRay Gear Saver 75w http://www.belray.com/bel-ray-gear-saver-transmission-oil
Chain - BelRay cleaner and lube, I see no issue with you using WD40 to clean as you described and then a good o-ring chain lube to finish with http://www.belray.com/bel-ray-chain-cleaner http://www.belray.com/bel-ray-super-clean-chain-lube
Air Filter - Again, BelRay products assuming you have the factory foam style filter http://www.belray.com/bel-ray-foam-filter-cleaner-degreaser http://www.belray.com/bel-ray-foam-filter-oil
The above products are all reasonably priced and have wide availability. You didn't mention fork oil, I replaced that as well over the lifespan of the bike with RedLine fork oil. I used LightWeight https://www.redlineoil.com/lightweight-5wt-suspension-fluid that was good for my riding style and terrain, you may need a different weight.
2017 Tacoma 15k km M1 EP 0w20 M1 Filter
1970 Chevelle SS454 LS6 42k mi Pennzoil Euro 5w40 Fram XG5
Re: 01 kdx220r newbie qs [Re: pda1122] #4809044
07/09/18 09:57 AM
07/09/18 09:57 AM
justin , tx
87sammy Offline
87sammy  Offline
justin , tx
If you have oring chain get a grunge brush and use wd40 to clean after riding. The gearbox is designed for engine oil do not use gear oil. Get a jd jet kit and jet for your riding conditions. Use 32 to 1 oil ratio. Clean your air filter however you want , but use air filter oil you pour on to saturate the filter then squeeze not ring the filter out.
Re: 01 kdx220r newbie qs [Re: pda1122] #4809334
07/09/18 02:22 PM
07/09/18 02:22 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
As someone with two stroke oil testing under my belt Ill add my thoughts.
A very good choice is to use a quality FC or FD and or EG-D rated oil, oil mixed at 32 to 1. It will provide superb lubrication, clean power valves, less chance of ring sticking and lower carbon. All while producing lower smoke and other benefits. A choice that I like is Castrol TT-S synthetic. Its one of many great choices. Please dont fall for the hype of 100 to 1 oil being a good choice. In our testing, Regardless of oil choice, 100 to 1 = wear.
Redline racing oil, while quite robust, accelerates corrosion on brass jets and crank bearings. Its a very well known issue with RRO. Its not the right oil for a KDX unless its tuned to make 60HP, and even then, the corrosion issue will appear.
Re: 01 kdx220r newbie qs [Re: pda1122] #4809345
07/09/18 02:35 PM
07/09/18 02:35 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
As for gearbox oil, you will find that the kdx is not particular about what you use. Anything from Mobil 1 ATF to 10w-40 automotive oil to dedicated motorcycle transmission oil will work equally well as they are more similar than different. And thats where the confusion sets in. Thick 75w90 GL5 type differential oil, and similar products (comes in tall containers) are not appropriate.
Re: 01 kdx220r newbie qs [Re: pda1122] #4811129
07/11/18 08:58 AM
07/11/18 08:58 AM
Billings,MT
Bwalker Offline
Bwalker  Offline
Billings,MT
Cujet gives sound advice on redline and using a Jaso FC/FD oil.
Yamalube 2R is an excellent reasonable priced oil. If Maxima is about it for availability Super M and K2 are both great.
I would not use Maxima Castor 927 for your use or any other castor/castor blend.
Moderated by  ekpolk
