Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
Opinion Of Dodge Nitro
by Warstud. 02/20/19 09:26 PM
Cheap first car
by LeakySeals. 02/20/19 09:08 PM
Grand Caravan break in
by pda1122. 02/20/19 09:07 PM
Million mile Lexus
by Skippy722. 02/20/19 08:57 PM
Antioxidant additive overdose
by xomyeusun. 02/20/19 08:50 PM
F15 Arrested Landing at Portland.
by PimTac. 02/20/19 08:43 PM
Why is Mobil 1 0w30x1 rated higher than most
by spiderbypass. 02/20/19 08:14 PM
Castrol Confusion
by PWMDMD. 02/20/19 07:13 PM
Crashed the Volt this morning...
by 14Accent. 02/20/19 06:55 PM
Best place to file online for Fed taxes?
by Vern_in_IL. 02/20/19 06:47 PM
vavoline instant oil change
by silver1. 02/20/19 06:23 PM
alienyouth33, RoyFJ, Intell77, RA_TJ, tiberius54
67294 Registered Users
68 registered members (aquariuscsm, Best F100, 69Torino, Billbert, bismic1, 8 invisible), 805 guests, and 51 spiders.
Topics284,589
Posts4,873,001
Members67,294
Most Online2,548
Feb 16th, 2019
Wheel Bearing Grease. #4808637
07/08/18 07:17 PM
07/08/18 07:17 PM
wv
krismoriah72 Offline OP
wv
On another thread i saw posted a video on chevrolet trucks you can pump grease into the speed sensor hole to lubricate the bearings..
From what i can tell my bearings are OEM untouched for 225K miles. When i did my brakes i did notice that they werent super smooth.
Now that i have the curiousity to do this its a one time one shot deal on what goes in that hole because it will never come back out.
I have a stick of Pennzoil 707L Premium wheel bearing grease. that i got for $1 at an autozone clearance in the stash..is that good enough? or should i look at something else?
I cant see any harm in adding grease to these bearings.. am i missing something?
Re: Wheel Bearing Grease. [Re: krismoriah72] #4808644
07/08/18 07:22 PM
07/08/18 07:22 PM
The Motor City
Kestas Offline
Kestas  Offline
The Motor City
Is grease purging from the seals? If not, remember that the grease cavity should have no more than 30% grease by volume. You also take the chance of mixing incompatible greases.
The grease that's in there should last a good long time, as long as the seals don't wear out.
BOTH bearings are suspect? If the bearings truly aren't running smoothly, then the damage is done and they need to be replaced.
Re: Wheel Bearing Grease. [Re: krismoriah72] #4808645
07/08/18 07:22 PM
07/08/18 07:22 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Go for it....Be careful removing the speed sensor.
Re: Wheel Bearing Grease. [Re: krismoriah72] #4808647
07/08/18 07:23 PM
07/08/18 07:23 PM
out there
spasm3 Offline
spasm3  Offline
out there
No way to know what the oem used. I have no idea how to pick grease thats compatable, but i find the method interesting.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Wheel Bearing Grease. [Re: Kestas] #4808663
07/08/18 07:43 PM
07/08/18 07:43 PM
wv
wv
Im the third owner, its 15 yrs old with 225K miles.. i dont believe everything i see on youtube but its a decent idea IMHO the guy actually says "good for another 100 thousand miles" after he shoots the grease in..
I think its a semi-sound idea for 'preventative maintenance'... the bearings are tight and dont roar, just saying they aint OEM fresh.
Re: Wheel Bearing Grease. [Re: krismoriah72] #4808700
07/08/18 08:42 PM
07/08/18 08:42 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
I've read both threads and apparently the speed sensor bolts are easy to break. Sounds like a recipe for disaster for no tangible reason.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Wheel Bearing Grease. [Re: krismoriah72] #4808708
07/08/18 08:54 PM
07/08/18 08:54 PM
The Motor City
Kestas Offline
Kestas  Offline
The Motor City
... and you believe this?
Either the bearings are good or they're on their way out.
Re: Wheel Bearing Grease. [Re: krismoriah72] #4808806
07/09/18 04:49 AM
07/09/18 04:49 AM
texas
danez_yoda Offline
danez_yoda  Offline
texas
As said before ther are standard trsts to see if the bearings are shot. Jack up the vehicle and spins and wiggle looking for play.
If still concerned, just get the bearings changed. 225 is a good number.
If your bearings are truely crunchy, grease will not help for long.
Re: Wheel Bearing Grease. [Re: krismoriah72] #4848080
08/22/18 08:25 PM
08/22/18 08:25 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
There are 2 sealed bearings in your hub. Even if you were able to somehow get grease past the seal on one bearing how is it going to get into the other bearing?
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Moderated by  ekpolk
