Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
Grumpy Kid
by wings&wheels - 11/17/19 01:57 PM
h9/95R FLA Batteries
by TXCarGeek - 11/17/19 01:40 PM
Preventative parking brake service
by Donald - 11/17/19 01:26 PM
Should I run an AC Delco Ultraguard gold?
by JHZR2 - 11/17/19 01:13 PM
Ford Ecoboost 400 at Homestead Miami Speedway
by bdcardinal - 11/17/19 01:08 PM
Strut mount, Moog vs KYB?
by jbutch - 11/17/19 01:07 PM
Is bar and chain oil hard on rubber?
by jqgz - 11/17/19 12:53 PM
TSC - Mobil Delvac $10.99
by Greg L - 11/17/19 12:42 PM
Wifi Thermostats
by FA_WRX - 11/17/19 10:33 AM
Test drove a few trucks. Ram Pentstar V6?
by dja4260 - 11/17/19 10:15 AM
2010 Corolla LE Opinions
by maverickfhs - 11/17/19 10:06 AM
2019 Toyota Highlander LOTS of metal flakes
by Mathew_Boss - 11/17/19 09:46 AM
Blaster Sidekick
by buster - 11/17/19 09:27 AM
Microwave time when microwaving 2 things at once?
by atikovi - 11/17/19 07:28 AM
2018 Nissan Rogue CVT @ 30k
by jcwhidby - 11/17/19 06:44 AM
gnouhp, tiblow, Gruenmeister, ZieloElo, Eisen77
69893 Registered Users
106 registered members (Alfred_B, 2002 Maxima SE, 53' Stude, Aero540T, Al, 92saturnsl2, 8 invisible), 2,498 guests, and 24 spiders.
Topics297,554
Posts5,117,885
Members69,893
Most Online3,589
Nov 2nd, 2019
Outside fumes enter cabin on Saab 9-5. #4808479 07/08/18 03:03 PM
G
gr8gatzby Offline OP
G
3 months with my 2004 Saab 9-5 wagon. Stage 0 was the first order of business, including cabin air filter. However, when recirculate is selected, I still get fumes from outside air inside the cabin. Was it installed incorrectly by my mechanic, or is this a design flaw in the system?
'95 Ford F150 | 4x4 | 5.8 | 9MPG
'11 Honda Crosstour | AWD | 3.5 | 21MPG
Re: Outside fumes enter cabin on Saab 9-5. [Re: gr8gatzby] #4808497 07/08/18 03:50 PM
E
edwardh1 Offline
E
all recirc systems I think mix some outside air
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Outside fumes enter cabin on Saab 9-5. [Re: edwardh1] #4808505 07/08/18 04:12 PM
K
Kira Offline
K
We've had 3 9-5's in the family. All of 'em allowed a bit of outside air to come in. It's an anti mold & mildew thing.
The Volvos I've had are 100% closed from my experience.
Also, FYI: There's an easy to reach hose on the 2.3l 4 cyl. behind the engine high up so it's quite doable. It can come off the oil drip box and stink to high heaven. Just shove it back on.
Which engine do you have? If it's the 2.3 has PCV modification #6 been done to it? If not it's real easy to do and takes about an hour. There are extra hoses on the right (passenger's side No. America) and one of them T's into the oil filler neck. A new neck is part of the PCV #6 kit.
Good luck with your Saab. They are easy and fun to drive....responsive.
Re: Outside fumes enter cabin on Saab 9-5. [Re: gr8gatzby] #4808576 07/08/18 05:43 PM
slacktide_bitog Offline
What kind of cabin filter is it? Did you get a filter with carbon/charcoal? Was the filter sealed in a plastic bag when you bought it?
Recric doesn't necessarily filter during recirc mode (although some cars will run the recirculated air thru the filter, not all cars do this)
Re: Outside fumes enter cabin on Saab 9-5. [Re: gr8gatzby] #4889306 10/06/18 01:35 PM
N
NoNameJoe Offline
N
Did you check to make sure the door and motor for recirculation are even working? They may not be working.
In most cases you can observe their operation with the cabin air filter removed. When you adjust the recirculation you should physically see the door (usually with foam seal) move in and out of place.
2015 Civic LX Coupe
