Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
First Time Timesert Install Questions
by The Critic - 03/28/20 01:56 PM
Ontario Nuclear update
by OVERKILL - 03/28/20 01:42 PM
VIDEO: Degreasing cast aluminum engine parts!
by dwcopple - 03/28/20 01:37 PM
Was I charged a fair price for welding exhaust?
by atikovi - 03/28/20 01:24 PM
McKee’s 37
by buster - 03/28/20 01:21 PM
1990 Toyota 4x4 transmission fluid type
by R1jake - 03/28/20 01:08 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
83 registered members (aquariuscsm, ArPix, Ag76, 2003f7, 2015_PSD, ammolab, 12 invisible), 1,408 guests, and 17 spiders.
Topics303,299
Posts5,233,449
Members71,038
What's the deal on Lucas Heavy Duty Oil Stabalizer #4799040 06/27/18 04:30 PM
A
AnonOIl Offline OP
A
Hey everyone. I am looking for an additive to help reduce the amount of oil my engine consumes. I drive a 2004 Toyota Highlander with just under 200k miles. I have used Lucas Heavy Duty Oil Stabalizer in the past, girlfriends dad is a mechanic and swears by the stuff to help reduce consumption. And truth be told it really does make a difference, in a 5K OCI I have to add maybe 1-1.5 quarts total. Used to be a lot worse. But reading some on here a lot of people are saying the stuff is bad? What is the deal and why? What is a good alternative? Thanks so much, have a great day.
PS: PCV valve was changed 10k ago so that is not a concern for consumption
Re: What's the deal on Lucas Heavy Duty Oil Stabalizer [Re: AnonOIl] #4799059 06/27/18 04:46 PM
CT8 Offline
It thickens the oil a bit some people recommend to use a thicker oil instead. What oil viscosity are you running now?
2015 F150 2.7
2018 F350 6.2
Re: What's the deal on Lucas Heavy Duty Oil Stabalizer [Re: AnonOIl] #4799060 06/27/18 04:46 PM
CT8 Offline
Is that engine one of Toyota engines that use oil because of a pistons]design problem?
2015 F150 2.7
2018 F350 6.2
Re: What's the deal on Lucas Heavy Duty Oil Stabalizer [Re: AnonOIl] #4799068 06/27/18 04:58 PM
SirTanon Offline
The major issue is that Lucas Oil Stabilizer thickens the oil, but because it does not itself contain any beneficial additives, what it really ends up doing is reducing the effectiveness of the motor oil to clean and neutralize acids. The end result is thicker oil that won't protect as well.
You're much better off going up a grade in oil thickness. If you're using 10W-30 oil, then bump it up to a quality 10W- or 15W-40 oil.. such as Shell Rotella.
2013 Nissan Altima SV - 2.5 liter/CVT - 125,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 68,000mi
2010 Ford Fusion - 274k mi - SOLD
Re: What's the deal on Lucas Heavy Duty Oil Stabalizer [Re: AnonOIl] #4799078 06/27/18 05:07 PM
rollinpete Offline
Here's a voa of lucas oil stabilizer
Click here and scroll down
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spd 190k
SRGT 5w30
Whip City Wrencher
Currently under the influence of oil shocked2
Re: What's the deal on Lucas Heavy Duty Oil Stabalizer [Re: CT8] #4799102 06/27/18 05:44 PM
A
AnonOIl Offline OP
A
Currently running 5w30
Re: What's the deal on Lucas Heavy Duty Oil Stabalizer [Re: AnonOIl] #4799111 06/27/18 05:54 PM
SubieRubyRoo Offline
Don’t use it. That’s the deal.
Buy a thicker HDEO like Delo, Delvac, or Rotella. Lucas “waters down” the effectiveness of any oil. It’s that simple.
De omnibus dubitandum.
Re: What's the deal on Lucas Heavy Duty Oil Stabalizer [Re: SirTanon] #4799159 06/27/18 06:57 PM
L
ltslimjim Offline
L
This 100%.
^That also. Better to step up a grade of oil. Maybe a HDEO like Rotella T5 or a high mileage oil would be a step up from 5w-30; at least in favor of those instead of Lucas. Not worth it. You could go to a 10w-40 or even now during an OCI on 5w-30.
Another thing would be to do a piston soak overnight next time the plugs are due.
Lucas is fine for masking and helping with viscosity...but so does going up a grade of oil and you get more for less money. It's a money pit or an expensive band-aid at best.
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
Re: What's the deal on Lucas Heavy Duty Oil Stabalizer [Re: AnonOIl] #4799166 06/27/18 07:06 PM
F
FlyNavyP3 Offline
F
I'd sooner run 20w50 or SAE 50 over Lucas in an engine to help with consumption. If you're using 5w30 now stepping up to an inexpensive 15w40 would yield about the same increase in viscosity as mixing in Lucas at the recommended dose and the 15w40 would be a boost in additives over the 5w30 as opposed to a dilution of the additives with Lucas. Walmart 15w40 is great stuff and it's cheap, try that and report back.
Luke
Re: What's the deal on Lucas Heavy Duty Oil Stabalizer [Re: AnonOIl] #4799208 06/27/18 07:46 PM
B
Buzzinhalfdozen Offline
B
Do a piston soak with a solvent. I used mmo and lc20. Check the thread where I asked a similar question about oil consumption in a Highlander. After that use an oil a grade or two up depending on consumption. I think I used 5w-40 euro oil at the time because that's what I had. There were several suggestions to try a high mileage oil as well.
Lucas is to be stayed away from. There is no point in adding a substance that dilutes oil additive packages when you can just use a thicker oil.
1999 Jeep Cherokee sport 4.0L
2015 Jeep Cherokee 3.2
2015 Ford F150 5.0
Re: What's the deal on Lucas Heavy Duty Oil Stabalizer [Re: AnonOIl] #4799213 06/27/18 07:53 PM
A
andyd Offline
A
I bought a qt for a Jeep. BIL wised me up. I used it to lube the cams on a Honda head R+R instead. Stuff is really too slippery for assembly lube. I would use a cheap 20w50. After I poured a can of Berryman's B 12 Chemtool into what is in the sump and idled it for 10-20 minutes. A fill -idle - drain using kerosene is what Smoky Yunnick recommended 50+ yrs ago.
Thick oil is better grin2
Re: What's the deal on Lucas Heavy Duty Oil Stabalizer [Re: AnonOIl] #4799860 06/28/18 03:55 PM
M
man114 Offline
M
Dilutes the additive package but it’s thick. Would quiet a loud old engine. I have 4 gallons of it that I bought for $9 at a Kmart that mistakenly was shipped it instead of the usual quarts they have. I don’t know why I bought it. It just seemed like a good deal.
I’ve used thickeners like it in small engines to get a bit more use out of them. Usually stuff I garbage picked. I’d probably reserve it’s use for that.
Re: What's the deal on Lucas Heavy Duty Oil Stabalizer [Re: AnonOIl] #4799939 06/28/18 06:01 PM
I'd probably enjoy lighting $9 on fire and running around the yard naked more than I would enjoy finding out how quickly Lucas can do bad things to my engine (OPE, car, etc).
It's been proven to entrain LOTS of air in the oil (on this site, no less), and even if you're brand new to oil you should be able to understand that air is not a lubricant, oil is. You've got three choices, the way I see it: 1. live with it; 2. run a thicker oil and live with it and a little lower consumption; or, 3. rebuild the darn thing and start over. Your money, your call. But IMHO the Lucas is at best a very poor choice to put in your sump and should be avoided at all costs.
Re: What's the deal on Lucas Heavy Duty Oil Stabalizer [Re: AnonOIl] #4805192 07/04/18 04:25 PM
A
airbusdrvr Offline
A
I know Lucas products are not a favored product here and I have never used any of them but if they are as bad as everyone says they are on BITOG wouldn't there have been a class action lawsuit against Lucas by now? Remember the class action lawsuit against Slick 50? As litigious as society has become I'm sure some law group would have went after Lucas by now if their product was purely useless.
Re: What's the deal on Lucas Heavy Duty Oil Stabalizer [Re: AnonOIl] #4805372 07/04/18 11:02 PM
J
jakewells Offline
J
I have only used it in gear boxes or manual transmissions to cut down on noise with luck.
2001 Mercury Cougar base 2.5l CD4E automatic.
