You might see 100 rpms more at full throttle, depending on the condition of the gear lube that is in their. The synthetic two stroke oils will definitely give you more top end speed, generally on the order of 100-200 rpms compared to a petroleum based, TC-W3 oil ....
The preferred gear lube for the lower unit is the 80w-90 marine oil. This is a GL-4 chemistry with a reduced level of sulphur and phosphorus. Sulphur/phosphorus and water don't mix very well, hence a GL-5 oil is "contra-indicated", as they say.
Tooslick
Dixie Synthetics
