Pajero
Thread starter
Originally Posted By: badtlc
Don't panic. This is the chemistry of Redline doing work. The first run of Redline is always a bit crazy as the esters do a lot of things other oils don't. This is from the leaching. If you want to see how Redline really works for you, then i would run it for consecutive OCIs and then sample again on third OCI (this one being the first).
Can you please explain what this leaching is? And, I plan on at least 3 OCIs.
Redline is not an oil you want to switch to, switch from, switch to, etc. You will only get the best from it if you keep running it w/out mixing with other oils. If you can't stick with redline, don't waste the time.
Good luck.
PS: Do not use additives with Redline. Its chemistry is too different with all the esters and the add pack within redline has to be designed to specifically work with the high polarity of the ester base stock.
Can you please explain what leaching is in this context?
Agreed! I didn't have a bottle of redline readily accessible at the time. Lesson learned!
Respectfully,
Pajero!
Good luck.
Respectfully,
Pajero!
