New Champ Filter
by CapitalTruck. 01/15/19 08:30 PM
19 Elantra vs corolla vs civic vs 18 Mazda 3
by wolf_06. 01/15/19 07:28 PM
New guage cluster need to be programed?
by callbay. 01/15/19 07:28 PM
good brand of inner tie rod?
by motor_oil_madman. 01/15/19 07:27 PM
Look at this blast from the past!
by SubieRubyRoo. 01/15/19 05:50 PM
Factory service manuals?
by buck91. 01/15/19 05:49 PM
Road Trip - Drive My Own Car or Rent?
by The Critic. 01/15/19 05:23 PM
‘19 GTI specs 0w-20 508 00
by LotI. 01/15/19 05:22 PM
Fram TG11955
by advocate. 01/15/19 03:03 PM
Bosch Steeltech = Wix?
by Black_Thunder. 01/15/19 02:44 PM
CVT and 6 speed automatic
by jerseyguy123. 01/15/19 01:56 PM
Hypothetical - X6M vs X5M vs AMG GLE63
by OVERKILL. 01/15/19 01:48 PM
2001 dodge neon coolant reservoir
by mobilaltima. 01/15/19 01:38 PM
Washing under car at self-service wash (salt)
by TmanP. 01/15/19 01:19 PM
Full Synthetic High Mileage in 40w range.
by FlyPenFly. 01/15/19 12:41 PM
2018 Silverado 3500HD TPMS Re-Learn
by Phishin. 01/15/19 12:36 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
142 registered members (92saturnsl2, 97prizm, AdRock, 28oz, AdditiveOCD, 15 invisible), 1,971 guests, and 35 spiders.
Topics296,608
Posts4,955,759
Members66,950
Most Online2,577
Jan 14th, 2019
Mini gutter or bent flashing for water routing #4783358
06/10/18 07:32 PM
06/10/18 07:32 PM
New Jersey
JHZR2 Offline OP
JHZR2  Offline OP
New Jersey
We had a shed built a few years back. Its a great little setup, we have been quite pleased with it except for one thing - water routing down the one side.
There is a side door and we have come to realize that some water can occasionally come in under heavy rains.
The design is such that there is maybe 1-1.5" of overhang of the roof from the vertical panels that make up the exterior walls. There is no practical overhang of the shingles beyond that.
So I guess under hard rain, the water teams down the roof and then falls straight down, with some managing to drip under the very short eave. Not sure if the drip edge isnt angling the water far enough out, or if under lighter rain, perhaps the water takes more of an arc off the roof and away from the walls.
Naturally Id like to prevent this, as it is obvious that there has been water on the floor of the shed from this.
The drip edge and design of the shed doesnt really allow the installation of a gutter. While I suppose one could be rigged, I dont think it would look or operate right.
I was thinking to take some flashing and try to fabricate something. Either let the flashing just extend out beyond the last shingle by an inch or two in order to help route the water, or else literally tuck it under and then let it route all the water to a sufficient distance away from the shed walls on either end.
Would either of these work? If I took a brake and bent the flashing up, could I put it under the very last shingles, at the drip edge? Those I can lift very slightly. All higher levels seem to be bonded to themselves at this point. Or do I put the flashing on top of the shingles, and nail/bond it down somehow, in order to route the water but avoid any flashing from routing water under the shingles?
Thanks!
Re: Mini gutter or bent flashing for water routing [Re: JHZR2] #4783365
06/10/18 07:43 PM
06/10/18 07:43 PM
PV Az
AZjeff Online content
AZjeff  Online Content
PV Az
When out last house was re-roofed there wasn't enough overhang of the shingles past the drip edge and instead of forming a drip it would capillary back and run down the drip edge onto the fascia. I got some brown flashing cut into 2.5" wide strips and had a slight down angle bent 1/2" back and slipped the 2" up under the shingles with the angle under the end of the shingles, fixed the problem. Sounds like you want to do something similar, it should work. Flat or steep pitch roof?
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Mini gutter or bent flashing for water routing [Re: JHZR2] #4783367
06/10/18 07:45 PM
06/10/18 07:45 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Need Pics !
Re: Mini gutter or bent flashing for water routing [Re: AZjeff] #4783403
06/10/18 08:18 PM
06/10/18 08:18 PM
New Jersey
JHZR2 Offline OP
JHZR2  Offline OP
New Jersey
That's it! Fairly flat.
Re: Mini gutter or bent flashing for water routing [Re: JHZR2] #4783406
06/10/18 08:21 PM
06/10/18 08:21 PM
MI
doitmyself Offline
doitmyself  Offline
MI
Vented drip edge is expensive, but might get the job done. https://www.google.com/search?q=vented+d...h=923&dpr=1
Buying or making something like masonary drip edge would probably work also: http://estore.masonpro.com/stainlesssteeldripedge.aspx
Both would be slipped under the shingles.
Re: Mini gutter or bent flashing for water routing [Re: JHZR2] #4783407
06/10/18 08:22 PM
06/10/18 08:22 PM
Kansas, USA
Kansas_Ron Offline
Kansas_Ron  Offline
Kansas, USA
Could you have flashing above the door? https://www.youtube.com/watch?v=hOa8sKZjYrg
2000 Chevy Prizm
2015 Honda Civic
2017 Hyundai Elantra
Re: Mini gutter or bent flashing for water routing [Re: JHZR2] #4783446
06/10/18 09:11 PM
06/10/18 09:11 PM
Central Texas
sleddriver Offline
sleddriver  Offline
Central Texas
Photo?
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: Mini gutter or bent flashing for water routing [Re: JHZR2] #4783576
06/11/18 05:38 AM
06/11/18 05:38 AM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
I use a wallpaper scraper or a masonry chisel to lift tabs without damage. What if the facsia was extended by a 2x4 or even one ripped in half to support the flashing?
Thick oil is better grin2
Re: Mini gutter or bent flashing for water routing [Re: sleddriver] #4783601
06/11/18 06:27 AM
06/11/18 06:27 AM
New Jersey
JHZR2 Offline OP
JHZR2  Offline OP
New Jersey
Originally Posted By: sleddriver
Photo?
Re: Mini gutter or bent flashing for water routing [Re: JHZR2] #4783619
06/11/18 07:07 AM
06/11/18 07:07 AM
Huntington WV
dbias Offline
dbias  Offline
Huntington WV
Find someone with a metal brake and have them bend you up a small "gutter" out of coil stock. You could also get some regular aluminum fascia, trim it down to size and slip it up btwn the drip edge and the fascia board backwards which would kick the water away a little better
2011 VW JETTA Castrol Edge 0W-40
2012 FORD TRANSIT CONNECT Castrol Edge 5W-20
2016 HONDA CIVIC COUPE Frankenbrew 0W-20 to 5w-40
2017 AUDI A4 Castrol Edge 0W-40
Re: Mini gutter or bent flashing for water routing [Re: JHZR2] #4783621
06/11/18 07:08 AM
06/11/18 07:08 AM
New England
madRiver Offline
madRiver  Offline
New England
1) place some bent flashing under the other flashing and see how it goes.
2) Replace the flashing with a more appropriate size that goes slightly past the trim
I'd avoid the gutter if trees are around and also another issue of routing its water etc.
Re: Mini gutter or bent flashing for water routing [Re: JHZR2] #4783955
06/11/18 12:59 PM
06/11/18 12:59 PM
Central Texas
sleddriver Offline
sleddriver  Offline
Central Texas
Whomever shingled the shed sure did not allow for much overhang. Further, the flashing looks tight to the fascia. Third, photo shows water drops clinging underneath the horizontal "ceiling".
I'd recommend a strip of flashing slid underneath the first course to extend at least 1-1/2".
M1 10W-30 HM
Re: Mini gutter or bent flashing for water routing [Re: sleddriver] #4784034
06/11/18 02:52 PM
06/11/18 02:52 PM
New Jersey
JHZR2 Offline OP
JHZR2  Offline OP
New Jersey
Blame the Amish. No, seriously, I saw them do it.
That is exactly my thought process. Unless in lieu of flashing I slide a row of shingles?
Re: Mini gutter or bent flashing for water routing [Re: JHZR2] #4784393
06/11/18 09:09 PM
06/11/18 09:09 PM
Central Texas
sleddriver Offline
sleddriver  Offline
Central Texas
You can get away with trimming the overhang close on the rake; not so much on the fascia. Particularly if thunderstorms are a regular event.
Another option is to slit the metal at the corners, then pry out the "kick" a bit and slide a piece of plastic shim in there. When I re-roofed, I used spacers to prevent the heavy-gauge flashing from making contact with the fascia board. I wanted water to be able to drain on the backside and air to get in there.
Some will saw-curf the bottom of that fascia board to prevent water from hanging down as shown. My own house has square returns rather than plumb cuts.
You can slide a single-shingle under there however metal (galva-lume) will last longer.
M1 10W-30 HM
Re: Mini gutter or bent flashing for water routing [Re: JHZR2] #4784402
06/11/18 09:20 PM
06/11/18 09:20 PM
New Jersey
JHZR2 Offline OP
JHZR2  Offline OP
New Jersey
I picked up a 10' piece of 30 degree bent flashing. All my shingles are stuck hard to the current flashing. Is it typical to goop some adhesive to the final edge of th shingles to adhere to the drip edge? Or is it just from heat and asphalt shingles?
