2015 Subaru Forester XT?
by Drew99GT. 02/17/19 10:26 AM
Motorkote or Archoil?
by lawnguy. 02/17/19 10:25 AM
Vehicle stored for 4 months
by palmerwmd. 02/17/19 09:57 AM
How often to drive a car that sits in the winter?
by Corollaman. 02/17/19 08:49 AM
Top Off or Change it Early
by 99Saturn. 02/17/19 08:22 AM
Do your vehicles have a nickname?
by ZZman. 02/17/19 08:19 AM
Another work project thread
by mattd. 02/17/19 08:18 AM
Buzzing sound behind dash
by Spetz. 02/17/19 05:09 AM
Ain't stupid, but can't find Cummin Hist
by BrocLuno. 02/16/19 11:41 PM
Rethinking oil choices
by JLTD. 02/16/19 11:29 PM
coolster 150 cc atv 2019 new
by hyperscion. 02/16/19 10:37 PM
older gps - week counter rollover Apr 6 '19
by spackard. 02/16/19 10:32 PM
Thoughts on an old Lexus?
by JustN89. 02/16/19 09:50 PM
Understanding Fuel Trims for diagnostics.
by StevieC. 02/16/19 07:59 PM
book of matches for tune up?
by marine65. 02/16/19 07:53 PM
New Penrite 0w-30
by toyota62. 02/16/19 07:45 PM
New HID bulbs for the Cadillac
by 14Accent. 02/16/19 07:17 PM
2008 Prius - Water in oil
by cjolson140. 02/16/19 07:00 PM
jpdeal, Snipeuout, DeltaWing, JRS3, krzyq
67252 Registered Users
87 registered members (2015_PSD, AZjeff, 2dogs, benjy, ABerns, 9 invisible), 1,967 guests, and 55 spiders.
Topics298,309
Posts4,989,286
Members67,252
Most Online2,548
Feb 16th, 2019
Original 1981 MB Engine Shock - How to Test? #4783334
06/10/18 06:55 PM
06/10/18 06:55 PM
New Jersey
JHZR2 Offline OP
JHZR2  Offline OP
New Jersey
I am doing engine mounts on my 81 240D. I have to remove the engine shock to lift the engine, in order to do mounts.
The car is very clean, the shock looks like it is in good shape. How do I know if it is good?
If I push the shaft all the way in, should it extend back out?
Likewise, if I pull the shaft all the way out, should it pull back in?
When I push it, should I feel any change in how resistive it is? Should I hear anything? Along the travel, I feel two spots where it gets easier for a fraction of a mm, then keeps up the resistance. When moving it along the full length of travel, I hear what Id call a fluid sound, like there is some oil in there moving between chambers.
Any recommendations on how to test?
Thanks!
Re: Original 1981 MB Engine Shock - How to Test? [Re: JHZR2] #4783376
06/10/18 07:48 PM
06/10/18 07:48 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Sounds like it's worn out in the area where there is little resistance.
Re: Original 1981 MB Engine Shock - How to Test? [Re: JHZR2] #4783404
06/10/18 08:19 PM
06/10/18 08:19 PM
New Jersey
JHZR2 Offline OP
JHZR2  Offline OP
New Jersey
Maybe so, that would be (Id guess) where the engine typically sat height-wise? But whats to say its actually worn? Any excursion beyond that spot and its stiff/resistive.
Re: Original 1981 MB Engine Shock - How to Test? [Re: JHZR2] #4783422
06/10/18 08:39 PM
06/10/18 08:39 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
I would guess it is a damper so is there equal resistance in both directions or oil leaking from it?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Original 1981 MB Engine Shock - How to Test? [Re: JHZR2] #4783426
06/10/18 08:41 PM
06/10/18 08:41 PM
New Jersey
JHZR2 Offline OP
JHZR2  Offline OP
New Jersey
yes equal resistance both ways. No sign of oil. Shaft is clean.
Re: Original 1981 MB Engine Shock - How to Test? [Re: JHZR2] #4783496
06/10/18 10:55 PM
06/10/18 10:55 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
It's almost certainly fine. These are only there to avoid severe engine rocking when rotational inertias make it want to rotate clockwise upon application of Wide Open Throttle (WOT) conditions.
It is a very simple device, unlikely to wear out in my opinion. But to test, reinstall, and have someone activate the throttle (idle > WOT > idle) while you observe the engine rock while the hood is open. It's somewhat difficult to describe what to expect, but in your case you could observe without and with it in place. It just moderates the movement, not eliminate it, but in some cases with no damper the intake can hit the hood if closed.
Many engines do without it, or only install it on high performance variants. It's a good thing to have but as long as no part of the engine hits the hood or other parts in the engine bay, it's not really even absolutely necessary in most cases. I like to have one, though, and install one in vehicles that lack one from the factory.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Original 1981 MB Engine Shock - How to Test? [Re: JHZR2] #4783508
06/11/18 12:02 AM
06/11/18 12:02 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
All indicators say its fine, these are not gas charged so there is no pressure or vacuum just a simple oil chamber and valve.
It is only a simple oil damper with a very short travel and is really only in operation a idle and near idle speeds, at higher rpm the oscillations are minimal.
The fact it has oil in it and from the picture isn't leaking is a good sigh its good. The question in my mind is with any part this age is do you reinstall a 40 wear item?
The fact you have moved it probably more than it ever did in regular service could have stressed the ancient seals inside, or not?
Re: Original 1981 MB Engine Shock - How to Test? [Re: Trav] #4783572
06/11/18 05:13 AM
06/11/18 05:13 AM
New Jersey
JHZR2 Offline OP
JHZR2  Offline OP
New Jersey
The fact that it's 40yo is part of the consideration. The mount and rubber parts are not cracked, and actually are soft and compliant. I'm planning to reuse them. Replacement of this mount is easy enough. It's really just three 10mm fasteners.
My car is smooth as glass at fast idle and driving, but has a nasty vibration at slow idle. I want to rectify that as much as possible. Not sure how much this helps with the mitigation...
Re: Original 1981 MB Engine Shock - How to Test? [Re: JHZR2] #4783581
06/11/18 05:47 AM
06/11/18 05:47 AM
Trav Offline
Trav  Offline
They help but not as much as you would thing, that 4 cyl diesel really wants to hop around at low idle. Just reuse them, as long as there is some resistance if you try to push it fast and you hear the oil moving its okay.
Re: Original 1981 MB Engine Shock - How to Test? [Re: JHZR2] #4783620
06/11/18 07:08 AM
06/11/18 07:08 AM
Ajax,Ontario, Canada
Pelican Online content
Pelican  Online Content
That piece is 37 years old, even if good it must be on its last legs, why not replace it while you have it out?
Re: Original 1981 MB Engine Shock - How to Test? [Re: Pelican] #4783865
06/11/18 11:25 AM
06/11/18 11:25 AM
New Jersey
JHZR2 Offline OP
JHZR2  Offline OP
New Jersey
No reason really, other than that the original one is still stiff, and replacement is maybe a 20 minute job.
At the same time, the German-made part is only around $28.
Re: Original 1981 MB Engine Shock - How to Test? [Re: Pelican] #4783891
06/11/18 11:33 AM
06/11/18 11:33 AM
VW Fanboy Island
maxdustington Online content
maxdustington  Online Content
VW Fanboy Island
The new one will not be made in West Germany.
All original, baby down to the grease in the front wheel bearings.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Moderated by  ekpolk
