New Champ Filter
by CapitalTruck. 01/15/19 08:30 PM
19 Elantra vs corolla vs civic vs 18 Mazda 3
by wolf_06. 01/15/19 07:28 PM
New guage cluster need to be programed?
by callbay. 01/15/19 07:28 PM
good brand of inner tie rod?
by motor_oil_madman. 01/15/19 07:27 PM
Look at this blast from the past!
by SubieRubyRoo. 01/15/19 05:50 PM
Factory service manuals?
by buck91. 01/15/19 05:49 PM
Road Trip - Drive My Own Car or Rent?
by The Critic. 01/15/19 05:23 PM
‘19 GTI specs 0w-20 508 00
by LotI. 01/15/19 05:22 PM
Fram TG11955
by advocate. 01/15/19 03:03 PM
Bosch Steeltech = Wix?
by Black_Thunder. 01/15/19 02:44 PM
CVT and 6 speed automatic
by jerseyguy123. 01/15/19 01:56 PM
Hypothetical - X6M vs X5M vs AMG GLE63
by OVERKILL. 01/15/19 01:48 PM
2001 dodge neon coolant reservoir
by mobilaltima. 01/15/19 01:38 PM
Washing under car at self-service wash (salt)
by TmanP. 01/15/19 01:19 PM
Full Synthetic High Mileage in 40w range.
by FlyPenFly. 01/15/19 12:41 PM
2018 Silverado 3500HD TPMS Re-Learn
by Phishin. 01/15/19 12:36 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
141 registered members (92saturnsl2, 97prizm, AdRock, 28oz, AdditiveOCD, 15 invisible), 1,969 guests, and 35 spiders.
Topics296,608
Posts4,955,759
Members66,950
Most Online2,577
Jan 14th, 2019
Nikki carburetor clean and rebuild #4783288
06/10/18 05:54 PM
06/10/18 05:54 PM
Crawfordville FL
SilverFusion2010 Offline OP
Crawfordville FL
42” Troy-bilt pony with 17.5 hp B&S Power Built. Has a Nikki carburetor. My brother-in-law’s mower, sat for a long time without being run.
When I pulled the fuel line off the carb something resembling mud came out. I pulled the carb off, dumped yellow gas out of the bowl. Sprayed everything out with carb cleaner, put it back on and she still wouldn’t run. It would run if I sprayed carb cleaner directly into the intake so I knew I had a fueling problem.
Took the bowl off again and it was dry, so I grabbed the big guns and shot some compressed air through the fuel inlet, popped the float valve off and sprayed the passages clean and ran air through all of them. Valve works because when I blow through it it will stop flow as I move the float.
I’m waiting for a new float valve gasket, old one has swelled and doesn’t fit. Gasket won’t be here until Tuesday, so what else should I check while I have it apart? I’ve replaced the air and fuel filters. The oil has been changed and I’ve got the battery on a tender while I’m waiting on the gasket. Oh and I have a new spark plug arriving tomorrow. Ngk iridium because they really do improve starting and my brother-in-law is not mechanically inclined and does no maintenance so best to have a “lifetime” plug installed.
I’ll be checking tire pressures, possibly shooting some grease into the steering gear. I don’t have the right kind of grease, the stuff I have is high moly wheel bearing grease. Valvoline I think.
Anyway, what else should I look over while I have the mower?
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Nikki carburetor clean and rebuild [Re: SilverFusion2010] #4783321
06/10/18 06:33 PM
06/10/18 06:33 PM
Coastal South Carolina
edwardh1 Online happy
edwardh1  Online Happy
honda gen set bowl drain plug gasket was sold only as a $32 package. i went to a hardware store for a simple washer. glad u could get the gasket
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Nikki carburetor clean and rebuild [Re: SilverFusion2010] #4783336
06/10/18 06:56 PM
06/10/18 06:56 PM
Crawfordville FL
Crawfordville FL
It was 7.88 on amazon
Re: Nikki carburetor clean and rebuild [Re: SilverFusion2010] #4783377
06/10/18 07:50 PM
06/10/18 07:50 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
The gasket will probably shrink back to normal by the time the other one arrives.
Re: Nikki carburetor clean and rebuild [Re: SilverFusion2010] #4783470
06/10/18 09:40 PM
06/10/18 09:40 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
mud looking stuff in the carb float bowl? Is there a gas filter?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Nikki carburetor clean and rebuild [Re: SilverFusion2010] #4783485
06/10/18 10:21 PM
06/10/18 10:21 PM
Crawfordville FL
Crawfordville FL
Yes, there is a fuel filter. I just replaced it
Re: Nikki carburetor clean and rebuild [Re: SilverFusion2010] #4783495
06/10/18 10:54 PM
06/10/18 10:54 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
An ebay or Amazon carb can be found for $12-$30 some times, depending on model. Always look at the cost of a new carb before buying gaskets and attempting to clean it.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Nikki carburetor clean and rebuild [Re: SilverFusion2010] #4783566
06/11/18 04:34 AM
06/11/18 04:34 AM
Crawfordville FL
Crawfordville FL
Last I checked 7.88 < 30
Re: Nikki carburetor clean and rebuild [Re: SilverFusion2010] #4783570
06/11/18 05:01 AM
06/11/18 05:01 AM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
Those tiny little ports can get covered over by corrosion. Shop mechanics will use tag wire to clean them out. If there's any welch plugs, the ports underneath the welch plugs may be covered over with corrosion. You can use tag wire to clean the ports out. New welch plugs will have to be installed.
Re: Nikki carburetor clean and rebuild [Re: SilverFusion2010] #4783600
06/11/18 06:26 AM
06/11/18 06:26 AM
South Central PA
Delta Offline
Delta  Offline
South Central PA
I have a Nikki carb on my Briggs 13.5HP, and more than likely it's the same model. Couple years ago it was $120 and the cheapest I've seen it now is around $75.
'17 VW GTI 2.0T - 6MT - 12K - PPE 5w40
'15 Camry SE - 2.5 - 21K - PP 0w20
'99 S10 - 2.2 5MT - 157K - PP 10w30
