trailer brakes required over 4400 lbs gvwr?
by motor_oil_madman. 07/22/19 08:56 PM
Cool one off gun
by The_Eric. 07/22/19 08:44 PM
First timer here need some info
by VintageOilGuy. 07/22/19 08:14 PM
Tractor and Hydraulic Fluids Standards
by MolaKule. 07/22/19 08:04 PM
FL homeowners insurance jumped up
by gregk24. 07/22/19 08:03 PM
Swapping out PF48E for M1-113
by OZHSV. 07/22/19 06:30 PM
Vehicle Insurance Goes Down Again
by BlueOvalFitter. 07/22/19 05:20 PM
2003 Dodge Caravan front brakes
by Oldtom. 07/22/19 04:52 PM
TPMS Sensors for a 2012 Highlander
by Tundragod. 07/22/19 04:43 PM
No one has posted the C8 interior yet?
by wensteph. 07/22/19 04:42 PM
Discard veggies from homemade veggie broth? Really?
by Ed_Flecko. 07/22/19 04:37 PM
Water spot remover
by Redright9. 07/22/19 03:40 PM
Optimal oil temp?
by gfh77665. 07/22/19 03:08 PM
Westlake Tires
by bunnspecial. 07/22/19 03:04 PM
Performance, hodgkh57, Cb46, mhuds, Pongo23
68739 Registered Users
115 registered members (69Torino, 2015_PSD, 4WD, 14Accent, 11 invisible), 1,992 guests, and 37 spiders.
Topics292,256
Posts5,019,768
Members68,739
Most Online2,967
Mar 10th, 2019
Any thoughts on univega? #4782407
06/09/18 05:49 PM
06/09/18 05:49 PM
MURICA
maverickfhs Offline OP
MURICA
So I have this univega classic bike laying around.
Its rusty and needs some work, like tires, brakes, chain etc...
Should I rebuild it or get rid of it? Never worked on bicycles and hence wanted to check before I go too deep into it in terms of money.
Thanks for the advice and help.
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Any thoughts on univega? [Re: maverickfhs] #4782408
06/09/18 05:49 PM
06/09/18 05:49 PM
MURICA
MURICA
It fits me perfectly and light weight.
Re: Any thoughts on univega? [Re: maverickfhs] #4782436
06/09/18 06:47 PM
06/09/18 06:47 PM
Oregon
MrQuackers Offline
MrQuackers  Offline
Oregon
Pictures
Master the 1000 yard stare
coffeeMobil 1 USA
Re: Any thoughts on univega? [Re: maverickfhs] #4782438
06/09/18 06:49 PM
06/09/18 06:49 PM
PA
wha232 Offline
wha232  Offline
PA
They were generally better than department store bicycles. I think it sounds interesting. Don't let a little money be the deciding issue- GO FOR IT
Re: Any thoughts on univega? [Re: maverickfhs] #4782464
06/09/18 07:28 PM
06/09/18 07:28 PM
MURICA
MURICA
Its univega chromoly.
Re: Any thoughts on univega? [Re: maverickfhs] #4782496
06/09/18 08:06 PM
06/09/18 08:06 PM
VW Fanboy Island
maxdustington Online content
maxdustington  Online Content
VW Fanboy Island
If it has a lugged frame then it is probably worth while.
03 Jetta AWP/09A 210k kms
Edge 0W40 + Mann 719/30
Re: Any thoughts on univega? [Re: maverickfhs] #4782527
06/09/18 08:39 PM
06/09/18 08:39 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
It's hard to beat the ride quality of a road bike that has a chromoly frame. Until about the turn of the century, 4130 chromoly was cheaper than aluminum and now aluminum is cheaper than chromoly steel. A good chromoly frame is lighter than a cheap aluminum frame. If the bike has 700c tires it is probably worth fixing up. If the bike sat outside and rusted, I would re-grease the headset. Should probably re-grease everything anyways. Tubes, tires, brake pads, grip tape and a chain doesn't cost much. If you have a Performance Bike store near you, pay them a visit as they stock the typical stuff cheap.
https://www.performancebike.com/shop/retail/oh/columbus
Me: 13' VW GTI 3 door 6 speed manual
Re: Any thoughts on univega? [Re: maverickfhs] #4782545
06/09/18 08:51 PM
06/09/18 08:51 PM
MURICA
MURICA
Here are some pics, thanks for all feedback.
Re: Any thoughts on univega? [Re: maverickfhs] #4782551
06/09/18 09:00 PM
06/09/18 09:00 PM
saginaw michigan
saginawmale50 Offline
saginaw michigan
If youre looking to ride it, keep it. If youre thinking you can fix it up and sell it, you will lose money. And if you have never worked on bicycles before you wont know how to work on the headstem and crank or even the cables and derailler gears. But that being said if you dont mind spending 200 or so on a 75 dollar bike go for it. Most of the bikes on craigslist are junk IMHO so unless you live in a college town where cheap bikes are plentiful, Id do it but just know what youre in for.
Re: Any thoughts on univega? [Re: saginawmale50] #4782559
06/09/18 09:13 PM
06/09/18 09:13 PM
MURICA
MURICA
Definitely not planning to flip it, because I would rather get rid of it as-is. Instead of putting effort, money and energy into it.
I have never worked on a bicycle, that's why weighing my options if I should consider it or no?
I could spend up to $100-$150(top max) in parts and doing the work on my own, but otherwise would just get rid of it.
Re: Any thoughts on univega? [Re: skyactiv] #4782561
06/09/18 09:14 PM
06/09/18 09:14 PM
MURICA
MURICA
Please have a look at the pictures of the bike, I am not well versed at the specifics of it frown
Re: Any thoughts on univega? [Re: maverickfhs] #4782595
06/09/18 10:19 PM
06/09/18 10:19 PM
PV Az @ 5000'
AZjeff Online content
AZjeff  Online Content
PV Az @ 5000'
OK, an old MTB. It's a TIG'd cromo frame, traditional fork/quill stem. The LX in the name might indicate decent components. Got any pics of the rear derailleur or thumb shifters? You might get it running for as little as some tubes and copious amounts of lube on the chain and in the cables. To be right it needs a complete overhaul top to bottom. No doubt you can find Youtube vids that cover everything you'd need to do, bikes aren't rocket surgery but getting those canti brakes and the shifters adjusted correctly can be frustrating. I've got a bike in similar condition that I'll make good and give away to someone to enjoy. It takes $50-$100 depending on what all they need but it's a hobby I enjoy. It's not worth much as is or running so your call.
Edit, does the sticker on the frame say double or triple butted? Tange was good tubing BITD.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Any thoughts on univega? [Re: AZjeff] #4782797
06/10/18 07:37 AM
06/10/18 07:37 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I am seeing "triple butted"
What does that mean?
Re: Any thoughts on univega? [Re: maverickfhs] #4782853
06/10/18 08:32 AM
06/10/18 08:32 AM
New York
Recalculating Offline
New York
Thought I'd throw in a few photos of my 15 year ago purchase of a Univega. Purchased for $50. It has been in storage for 2 years and am looking to retrofit it to an upright handlebar system. You will find a serial number under the crank which be be referen
ce to year made.
2009 Honda CR-V EX-L 59k
2007 Buick Lacrosse 59k
2008 Ford Ranger XLT V-6 4.0 SOHC 75k
Re: Any thoughts on univega? [Re: Linctex] #4783309
06/10/18 07:20 PM
06/10/18 07:20 PM
PV Az @ 5000'
PV Az @ 5000'
Triple butted means the main tubes have been worked to have 3 different thicknesses, thicker at the welds then thinner toward the middle of the tube. Lighter and livelier ride. Not an entry level bike.
Nice lugged frame road bike Recalc. Are you moving the shifters to the bars too? Also, take a look at "alternative" bars with some sweep. Love em.
