Topics298,307
Posts4,989,254
Members67,252
Most Online2,548 Feb 16th, 2019
Safety Reminder: don’t trust a jack
#4782020
06/09/18 07:50 AM
06/09/18 07:50 AM
Posts: 4,934 Midwest
volk06
OP
OP
Midwest
This was posted this week on Facebook by the Indianapolis FD. It is not graphic but may be disturbing to some. Video summary: A jack failed and trapped a person working under their car. https://www.facebook.com/indianapolisfiredepartment/videos/1933947383290446/Always use a jack stand with your jack when you are working under your vehicle. Stands are cheap at Walmart and Harbor Freight.
2011 F-150 Ecoboost 2012 Focus S 2001 Taurus
Re: Safety Reminder: don’t trust a jack
[Re: volk06]
#4782034
06/09/18 08:03 AM
06/09/18 08:03 AM
Posts: 427 California
VeryNoisyPoet
California
In addition to the above, set parking brake and chock any wheels still on the ground. Before getting under the car, grab each corner and give it a good shake to settle it and make sure it won't slip down on you while you work.
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: Always use a jack stand n just don’t trust a jack
[Re: volk06]
#4782040
06/09/18 08:08 AM
06/09/18 08:08 AM
Posts: 775 Northern Arizona
funflyer
Northern Arizona
Wow! About a dozen firefighters and every piece of equipment the truck has just to lift a car off the guy?
2016 Prius 1.8L 2001 Tacoma 2.4L 1966 GTO 6.5L 2015 Cub Cadet Honda CT70 (X6)
[Re: VeryNoisyPoet]
#4782041
06/09/18 08:09 AM
06/09/18 08:09 AM
Posts: 20,964 MA, Mittelfranken.de
Trav
In addition to the above, set parking brake and chock any wheels still on the ground. Before getting under the car, grab each corner and give it a good shake to settle it and make sure it won't slip down on you while you work. +2 Never trust a jack of any type alone for under the car work.
[Re: volk06]
#4782060
06/09/18 08:43 AM
06/09/18 08:43 AM
Posts: 390 California
Billbert
California
Great reminder, I read in the local paper about a car falling of of a Jack about once a year, and pretty often it ends up as a fatality
If you think you can, or if you think you can't, You are probably right.
Auto Instructor / ASE Master Tech
[Re: Al]
#4782074
06/09/18 09:00 AM
06/09/18 09:00 AM
volk06
OP
OP
Midwest
Ramp or jackstands period. No jacks I personally use ramps with a jack stand as a safety measure. I've seen many rhino or plastic style ramps get old and brittle.
[Re: volk06]
#4782109
06/09/18 09:41 AM
06/09/18 09:41 AM
Posts: 2,687 Canada
Lolvoguy
Canada
I live in the PNW area (oodles of rain). There's a neighbor who has stored his home-made, wooden ramps stored outside near to where he parks. Do these ppl not understand what happens to rain-soaked wood!?!?!
06 Lexus IS350- Wife 88 BMW 325is- Mistress Say "no" to Turbo!
[Re: volk06]
#4782115
06/09/18 09:47 AM
06/09/18 09:47 AM
Posts: 9,715 out there
spasm3
out there
I use jack stands on level concrete. I shake the car to see if the jack stands rock. I want it to make noise or fall before i'm under it. If i have the wheels/tires off, i put them under there as well. I don't get under the car,( or on top of my camper) when no one but me is home. I'm not 30 anymore.
13 elantra 72k 5w30 QSUD 03 chevy avalanche 80k synpwr 5w30 17 mazda cx-5 7300 miles m1 0w30
[Re: spasm3]
#4782124
06/09/18 09:54 AM
06/09/18 09:54 AM
volk06
OP
OP
Midwest
I use jack stands on level concrete. I shake the car to see if the jack stands rock. I want it to make noise or fall before i'm under it. If i have the wheels/tires off, i put them under there as well. I don't get under the car,( or on top of my camper) when no one but me is home. I'm not 30 anymore. You have the exact same process and approach as I do. I don't get under the car without my wife home and knowing I'm out in the garage working under the car. Heck, even sometimes she'll come out help hand me wrenches.
[Re: funflyer]
#4782171
06/09/18 10:37 AM
06/09/18 10:37 AM
Posts: 7,963 Marshfield , MA
andyd
Marshfield , MA
Wow! About a dozen firefighters and every piece of equipment the truck has just to lift a car off the guy? The metaphor about a monkey and a football crossed my mind. There were enough personnel on hand to lift the car off the poor idiot
'16 Camry LE STP synth 0w20 and STP filter. the Fridge 1994 Ranger ,the Rat, 5w30 dino, STP filter '16 Camry SE, Valvoline HM 0w20 and OEM filter Thick oil is better
[Re: volk06]
#4782174
06/09/18 10:40 AM
06/09/18 10:40 AM
Posts: 4,084 Connecticut
69GTX
Connecticut
Looks like there's a metal stand just forward of the right rear wheel. If so, it tipped over. Guy could have been doing it mostly right except setting the car's partial weight properly on the stand.
If immediate risk of life was in the balance they might have lifted the car by hand. But blowing out backs isn't the safest method. And if the car slips out of their grips and falls again, you can crush the person worse than before, especially if they change position while trying to get out. The firefighters may have deemed the situation stable and not immediately life threatening...enough time to get proper rigging gear. I wasn't there so this is all conjecture.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2 1999 Camaro SS M6 /19K /Mobil 1 0w40 /Fram UG /GM MTL-ATF 1969 Ply GTX/RRs
