Best Shell/Pennzoil is ?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
Champion AGM Batteries
by The Critic. 06/15/19 06:52 PM
Redneck Battery Recovery
by cwilliamsws6. 06/15/19 06:29 PM
Currently Using iPhone 6S...Should I Upgrade?
by john_pifer. 06/15/19 05:08 PM
Is it Router or Comcast?
by RW1. 06/15/19 05:01 PM
bagyoau, frank57, gheewala114, Rob_Jeff, BrianinTucson
68412 Registered Users
24 registered members (chance, bagyoau, carviewsonic, 4WD, BlakeB, Astro14, 3 invisible), 529 guests, and 20 spiders.
Topics290,258
Posts4,987,212
Members68,412
Most Online2,967
Mar 10th, 2019
White Honda paint needs a little help #4778710
06/06/18 12:15 AM
06/06/18 12:15 AM
Rainville, USA
JEL01 Offline OP
JEL01  Offline OP
Rainville, USA
Hello,
Who or what do you all like for white paint? Iíve used Poor Boys Blackhole in dark charcoal Toyota paint before and it worked awesome, I then threw some 3m Performance Finish on top to keep it nice all year, but the white paint on my Honda, while still looking good for its age, has some mild oxidation and haziness/staining. Anyone tried Diamond White by PB? I want to get it REALLY shiny and looking new this summer, of course 3m will go on top to seal it in.
Thanks
Cars I maintain:
02 Mercedes CLK430-Edge 0w40
05 Honda Accord V6-Maxlife 5w30
13 Lexus RX350 AWD-M1 AFE 0w20
02 Toyota Tundra 4x4 M1 5w30
Re: White Honda paint needs a little help [Re: JEL01] #4778740
06/06/18 02:40 AM
06/06/18 02:40 AM
Athens, GA
ctechbob Offline
ctechbob  Offline
Athens, GA
If its the 05 in your signature, it is probably the beginnings of the clear coat failing. Common problem with Honda's paint unfortunately.
2008 Acura TL Type S - 155k*
2003 Honda Accord V6 - 207k*
2000 Honda Accord I4 - 325k
Oil - Milesyn SXR5W30 / *Havoline ProDS 5W30
Filter - Partsmaster 61334 (All)
Trans - Idemitsu H Plus (All)
Re: White Honda paint needs a little help [Re: JEL01] #4778774
06/06/18 05:45 AM
06/06/18 05:45 AM
South Central PA (Fulton Co)
Delta Offline
Delta  Offline
2005, hmm, that might even be single stage being white. Regardless a quick polish might do the trick before the glaze. I would try Poorboy's Pro Polish and follow with White Diamond, then a sealant such as EX-P. Pro Polish is pad dependent, so start with a fine pad and medium speed. Pro Polish has worked great for me on white, so I've never had to try White Diamond
'17 VW GTI 2.0T - 6MT - 16K - PPE 5w40
'15 Camry SE - 2.5 - 23K - PP 0w20
'09 Tacoma TRD - 4.0 - 131K
Re: White Honda paint needs a little help [Re: JEL01] #4778782
06/06/18 06:08 AM
06/06/18 06:08 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Fortunately your is not clear coated, Taffeta white and San Marino red were single stage in 05. Now that is cleared up the best way to address this on one of Honda's thinnest paints ever.
http://www.driveaccord.net/forums/attachment.php?attachmentid=18351&d=1235869274
I usually use 3M and rotary tools only but in this case Meguiar's has some good products and a DA is definitely the way to go.
You will need a lot finesse with this or it will burn through with ease. Keep it slow and moving to keep it cool, don't try to remove scratches you will probably end up needing to paint the panel or do a touch up blend.
First wash the car properly, use Dawn liquid to strip old wax, grit guard, separate mitt for the lower panels and a separate bucket and mitt/wheel brush for the wheels.
Clay the car with a fine clay bar and plenty of lube. Wash the car again and dry it.
Use a DA on a slower speed with a Meguiar's DMC6 micro fiber cutting pad/bonnet and Meguiar's D30216 DA Microfiber Polish keeping it wet and moving so as not to create much heat.
Wash the car again to remove any traces of polish, the point is to prevent anything getting into the open paint pores. Oxidation is dead paint and can stain or absorb contaminates easily. I don't like dedicated sealer products for this type of issue, it sometimes seems to exacerbate the problem.
Dry the car and with a DA and black no cut pad apply Meguiar's G6107 White Wax Paste, this is the best wax I have ever used on a white car, buff it to a high shine and give it as many more coats as you want, it looks better every time and does a nice job of sealing the paint with no problems.
That's how I do Taffeta white if I repaint a panel and do the rest of the car, others may use other products but for me these work amazingly well and are safe for the thin paint. Link to the products. I hope you find this helpful.
https://www.amazon.com/Pinnacle-Ultra-Poly-Clay-4oz/dp/B000FGWQEC
https://www.amazon.com/Meguiars-G6107-Wh...te+wax+meguiars
https://www.amazon.com/Meguiars-DMC6-Mic...te+wax+meguiars
https://www.amazon.com/Meguiars-D30216-M...te+wax+meguiars
Re: White Honda paint needs a little help [Re: JEL01] #4779128
06/06/18 01:21 PM
06/06/18 01:21 PM
Rainville, USA
JEL01 Offline OP
JEL01  Offline OP
Rainville, USA
Wow thanks again to the BITOG brain trust, I really appreciate it and definitely will plan on attacking it soon. Yeah as far as I know there is no CC on it, but all the rain and mold tends to find its way into everything up here in the PNW
Cars I maintain:
Re: White Honda paint needs a little help [Re: JEL01] #4779140
06/06/18 01:34 PM
06/06/18 01:34 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
PB White Diamond is every bit as good as Black Hole. Lots of good advice in thread esp from Trav. I think my 94 Civic was taffeta white also. It seemed to turn flat/matte if not waxed regularly. Esp being outside most of the time.
