Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
How cold is it? (Humor)
by StevieC. 01/21/19 07:13 PM
Slight performance decrease
by A_User55555. 01/21/19 06:54 PM
how to keep your vehicle battery...
by Char Baby. 01/21/19 06:31 PM
2012 to 2016 ford focus
by WhyMe. 01/21/19 06:30 PM
LHM anyone?
by mistersooty. 01/21/19 06:30 PM
Walmart Oil Changes.
by Bill7. 01/21/19 06:10 PM
Coolbreez1973, jmcast1127, DF8005, FT86dude11, RTSAllison
67008 Registered Users
33 registered members (Char Baby, berniedd, alcyon, billt460, BlakeB, citationxeleven, 5 invisible), 868 guests, and 37 spiders.
Topics296,961
Posts4,962,404
Members67,008
Most Online2,821
Jan 21st, 2019
Balancing tires increase gas mileage? #4778979
06/06/18 09:54 AM
06/06/18 09:54 AM
Washington for now
WhyMe Offline OP
WhyMe  Offline OP
Washington for now
i had my tires rotated and balanced at DT the day after memeorial day. after that something did not seem right . there was a vibration and thumping and the cRV seemed sluggish. After a while i got tired of it so decided to take it back to DT to have it checked.
I took it to a different DT than i usually go to as i have lost trust in them. when i originally got the tires they balanced them wrong and i had to go back to get it done again.
The DT i went to was great. they check it and put it on a hunter road force machine. they said the balance was all messed up and that a couple of the tires were out of round. guy told they got it the best they could and if there are issue i need new tires.
the hunter seems to have worked as it drive smooth and normal now. What is odd is i seemed to have picked up a couple of MPG according to the dash. even on the highway, in the past i would rarely see it go over 25 MPG. coming back from the DT on the freeway i saw 27.3 .
So does balance affect mpg? can it affect things like acceleration which was an issue after i get the rotate and rebalance?
Re: Balancing tires increase gas mileage? [Re: WhyMe] #4778996
06/06/18 10:11 AM
06/06/18 10:11 AM
PimTac Offline
PimTac  Offline
I don’t see why not although the effect on fuel economy might be slight. They may have inflated your tires up some more as well and that would have a bigger effect on FE. Check your tires psi.
Cannot see signatures any longer so it doesn’t matter.
Re: Balancing tires increase gas mileage? [Re: WhyMe] #4778997
06/06/18 10:12 AM
06/06/18 10:12 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
I don't think balancing is likely to impact mpg in a measurable amount, but tire pressure will. It is possible your tires were low on pressure and were increased by whoever did the balancing.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (36k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Balancing tires increase gas mileage? [Re: PimTac] #4779001
06/06/18 10:20 AM
06/06/18 10:20 AM
Washington for now
WhyMe Offline OP
WhyMe  Offline OP
Washington for now
checked that. went in with 35 came home with 35psi.
Re: Balancing tires increase gas mileage? [Re: WhyMe] #4779010
06/06/18 10:27 AM
06/06/18 10:27 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
The amount of energy to shake your car with a unbalanced tire has to come from somewhere and its not zero, but 10% of highway mileage sounds a bit high. I'll say its 2-3% from the tire and the rest was a tailwind or slight downhill.
07 Focus ZXW, 5spd manual, 218km M1 5W30
18 Outback 2.5 CVT 15km 0W20
Re: Balancing tires increase gas mileage? [Re: WhyMe] #4779013
06/06/18 10:30 AM
06/06/18 10:30 AM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
If course it can. The less energy needed to turn the tires, the better the mileage.
Depending on how out the tire is, energy is consumed shaking the car.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Balancing tires increase gas mileage? [Re: WhyMe] #4779020
06/06/18 10:40 AM
06/06/18 10:40 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
If the tire is noticeably vibrating, there is wasted energy, something is going side wise. How much?
My first vehicles were old trucks with typically 650 x 16s bias plies and tubes. Never a shimmy and never a balance weight. Was the vibration dampened by the inner tubes, wheel bearings ,kingpins, leaf springs, etc of the old trucks?. How long has wheel balancing been around?
Thick oil is better grin2
Re: Balancing tires increase gas mileage? [Re: WhyMe] #4779126
06/06/18 12:21 PM
06/06/18 12:21 PM
North Carolina
Rat407 Offline
Rat407  Offline
North Carolina
2002 Silverado 5.3 0w-20 AMSOIL®
Re: Balancing tires increase gas mileage? [Re: Rat407] #4779168
06/06/18 01:08 PM
06/06/18 01:08 PM
Cali
Malo83 Offline
Malo83  Offline
Cali
Re: Balancing tires increase gas mileage? [Re: WhyMe] #4779402
06/06/18 04:47 PM
06/06/18 04:47 PM
NY
mx5miata Offline
mx5miata  Offline
NY
Did they fill tires with nitrogen.
NAPA FULL SYNTHETIC 0w20 Partsplus oil filter
Wix air filter
Re: Balancing tires increase gas mileage? [Re: WhyMe] #4779451
06/06/18 05:34 PM
06/06/18 05:34 PM
DFW
DBMaster Offline
DBMaster  Offline
DFW
If you fill them with helium will MPG improve due to lightening of the vehicle?
Re: Balancing tires increase gas mileage? [Re: DBMaster] #4779671
06/06/18 09:09 PM
06/06/18 09:09 PM
Joplin
Cressida Offline
Cressida  Offline
Joplin
Of course, but you'll lose traction on curves and the off ramps so don't do it
