Who is censoring me? public wifi
by Vern_in_IL. 02/22/19 06:53 PM
Serpentine Belt Tool
by Gebo. 02/22/19 06:49 PM
SUNOCO GLOBAL FULL SYNTHETIC ATF
by Ursatdx. 02/22/19 06:46 PM
No more Meijer batteries!!
by bullwinkle. 02/22/19 06:24 PM
Valvoline premium blue tsc
by Dudemanmaximus. 02/22/19 05:38 PM
Echo won’t run on high speed
by artbuc. 02/22/19 05:36 PM
Roadside Assistance memberships
by paulri. 02/22/19 05:35 PM
Remembering Steve Irwin
by 2015_PSD. 02/22/19 05:27 PM
Transmission Cooler
by rcbob. 02/22/19 04:59 PM
Amazon: PP Euro 5W-40 $38 for pack of 6 quarts
by 1JZ_E46. 02/22/19 04:56 PM
89 Wrangler oil recommendations
by Chris142. 02/22/19 04:55 PM
New batteries failing on the shelf
by Chris142. 02/22/19 04:53 PM
Schaeffer’s 5w30 LT1
by s2krunner. 02/22/19 04:48 PM
Lexus LS430 P0756
by Kibitoshin. 02/22/19 04:41 PM
PUP is now SN + ??? Formulation change??
by Lazydan. 02/22/19 04:17 PM
Got a new wireless printer/MFC
by y_p_w. 02/22/19 02:48 PM
NM
by y_p_w. 02/22/19 02:47 PM
Names of brand names quality non-pro multi-meter
by JLawrence08648. 02/22/19 02:16 PM
Lady Luck
by CourierDriver. 02/22/19 02:06 PM
jcthorne, duckthis1, Roughneck777, KDW, avantika31
67313 Registered Users
117 registered members (Alisobob, Al, 2004tdigls, 10WSmuckers, 928, 12 invisible), 1,725 guests, and 53 spiders.
Topics284,681
Posts4,874,972
Members67,313
Most Online2,548
Feb 16th, 2019
Amsoil in a 5.7 (~1000hours) or still use T5 ? #4761388
05/18/18 07:09 PM
05/18/18 07:09 PM
Montreal,Quebec,Canada
Yannick Offline OP
Yannick  Offline OP
Hello,
I have a Mercruiser 5.7 with around 1000hours in the heart, I always put Rotella T5 15w40, but now the API SM is over.
What do you think switching at 1000hours on full Synthetic AMSOIL 15w40 ? AM I gonna expect some leak problem ?
Should I keep going with T5 even without the API SM ?
thanks
Re: Amsoil in a 5.7 (~1000hours) or still use T5 ? [Re: Yannick] #4761394
05/18/18 07:19 PM
05/18/18 07:19 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
Should be fine. If it leaks, switch back.i run something different every year in mine.
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Amsoil in a 5.7 (~1000hours) or still use T5 ? [Re: Yannick] #4761431
05/18/18 08:21 PM
05/18/18 08:21 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
My last UOA on my 4Runner with Rotella T4 10w30 in CK-4 spec looks pretty darn similar to the old SM spec. It's boxed and labeled as CJ-4 /SM but in the new bottle and confirmed by shell rep on here that the new bottle contains CK-4 despite the label stating CJ-4 SM. To me that says it would've also met the SM specs but the new labeling requirements force the removal of gas ratings unless the oil companies cut way down on Phosphorus and Zinc. I would continue to use the Rotella with confidence.
Luke
Re: Amsoil in a 5.7 (~1000hours) or still use T5 ? [Re: Yannick] #4761432
05/18/18 08:22 PM
05/18/18 08:22 PM
US
JLTD Online shocked
JLTD  Online Shocked
US
1000 hours is similar to 60000 miles in a car; several members have switched to synthetic at much higher mileage without issue so IMO you should be fine - and will probably see a cooler running engine and perhaps fuel savings.
I'm a thickie; assimilate
But 20s have their place
Using AMSOIL
Hers: 2008 Jeep Liberty 138k, SS 5w30/Amsoil
His: 2015 4Runner 45k, OE 5w30/Wix
Re: Amsoil in a 5.7 (~1000hours) or still use T5 ? [Re: Yannick] #4761433
05/18/18 08:22 PM
05/18/18 08:22 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
As an aside with 1,000 hours I'd consider freshening up the top end on your 350. Valve job and new valve springs. They're really ugly when they break a valve spring and end up dropping a valve.
Luke
Re: Amsoil in a 5.7 (~1000hours) or still use T5 ? [Re: Yannick] #4761529
05/18/18 11:53 PM
05/18/18 11:53 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
The lack of API Sx means nothing, other than the fact that it does not comply with a restriction. Just keep T5 in there.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 106K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: Amsoil in a 5.7 (~1000hours) or still use T5 ? [Re: JLTD] #4761631
05/19/18 04:56 AM
05/19/18 04:56 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I could only dream about driving 60K miles in thousand hours. I seriously doubt I'd see 25K miles in that much time.
Back OT- switching won't be a problem.
God Bless Our Troops
Re: Amsoil in a 5.7 (~1000hours) or still use T5 ? [Re: Yannick] #4761704
05/19/18 06:31 AM
05/19/18 06:31 AM
central Georgia
terminaldegree Offline
central Georgia
As others have mentioned, not having the SM spec is meaningless for the engine youre using. Id stay the course and keep using it. Switching is also fine, but Id rather save my money on a motor with that many hours to pay for refreshing exhaust riser gaskets, water pump impellers, stern drive gaskets, and other things that are more likely to ruin your day than the brand of motor oil.
I run Delo 400 LE 15w-40 in my Nautique. Going to try and find a couple more oil changes of older stock, just so it continues to have a steady diet of the same thing its had for the last 3 oil changes. But thats honestly #30 of the things Im actually worried about with my old boat.
'16 Mini Cooper S, 32k
'10 F150 4.6 3v, 120k
'13 Kawasaki STX-15f, 180 hr
'96 Sport Nautique 351 GT-40, 745 hr
Re: Amsoil in a 5.7 (~1000hours) or still use T5 ? [Re: terminaldegree] #4761779
05/19/18 07:59 AM
05/19/18 07:59 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Agreed.
It's probably time to do a THOROUGH inspection of the entire drive system.
Re: Amsoil in a 5.7 (~1000hours) or still use T5 ? [Re: Linctex] #4787923
06/16/18 01:44 AM
06/16/18 01:44 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Agreed.
If he's gone 1000 hours without doing that at least once a year, he's probably already on the cusp of apocalypse.
Unless you have a catalyzed 5.7 (doubt it), your engine isn't going to care that SM was dropped from the bottle.
Where the engine is concerned, skip the top-end job. A brand new crate engine + brass freeze plugs is less than $2000. When that top-end is done, kick the whole engine, rather than tighten the top, just to start having bottom issues.
When dealing with big blocks at $5,000+ for a crate, we bother with the top end (especially since big blocks love to get a hole ate through their heads). On a 5.7? We'll do it if someone is adamant, but pretty much nobody ever has been.
Amsoil in that engine? See above. Every oil change, throw your savings by using T5 into a jar marked "crate engine". Might be surprised how much of the job your jar will cover when the time comes.
Use some nice RA or WM dollar clearance filters, and jar that savings too.
Re: Amsoil in a 5.7 (~1000hours) or still use T5 ? [Re: Yannick] #4788560
06/16/18 06:57 PM
06/16/18 06:57 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Rotella T 15W40.
How many hours do you put on the engine a year?
2015 Ford F250 w/Powerstroke
Re: Amsoil in a 5.7 (~1000hours) or still use T5 ? [Re: JLTD] #4792435
06/20/18 06:43 PM
06/20/18 06:43 PM
NY, USA, etc.
oilpsi2high Offline
oilpsi2high  Offline
NY, USA, etc.
Maybe if you floor it at every takeoff and run it at 3000RPM when cruising. Boat engines live a way harder life than a car engine. I'd say 1000 hours is closer to 120-150,000 miles.
Re: Amsoil in a 5.7 (~1000hours) or still use T5 ? [Re: Yannick] #4800346
06/29/18 06:52 AM
06/29/18 06:52 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Originally Posted By: Yannick
Hello,
thanks
Just curious. Do they put cats on the inboards?
If you want the job done right......do it yourself.
Re: Amsoil in a 5.7 (~1000hours) or still use T5 ? [Re: Snagglefoot] #4806388
07/05/18 11:31 PM
07/05/18 11:31 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Hello,
thanks
They do on the most recent ones, and yes, they do use a special oil just for catalyzed engines.
Moderated by  ekpolk
