Elf 4T moto tech 10w50 is good?
by firstime911. 01/15/19 09:25 PM
New Champ Filter
by CapitalTruck. 01/15/19 08:30 PM
19 Elantra vs corolla vs civic vs 18 Mazda 3
by wolf_06. 01/15/19 07:28 PM
New guage cluster need to be programed?
by callbay. 01/15/19 07:28 PM
good brand of inner tie rod?
by motor_oil_madman. 01/15/19 07:27 PM
Look at this blast from the past!
by SubieRubyRoo. 01/15/19 05:50 PM
Factory service manuals?
by buck91. 01/15/19 05:49 PM
Road Trip - Drive My Own Car or Rent?
by The Critic. 01/15/19 05:23 PM
‘19 GTI specs 0w-20 508 00
by LotI. 01/15/19 05:22 PM
Fram TG11955
by advocate. 01/15/19 03:03 PM
Bosch Steeltech = Wix?
by Black_Thunder. 01/15/19 02:44 PM
CVT and 6 speed automatic
by jerseyguy123. 01/15/19 01:56 PM
Hypothetical - X6M vs X5M vs AMG GLE63
by OVERKILL. 01/15/19 01:48 PM
2001 dodge neon coolant reservoir
by mobilaltima. 01/15/19 01:38 PM
Washing under car at self-service wash (salt)
by TmanP. 01/15/19 01:19 PM
Full Synthetic High Mileage in 40w range.
by FlyPenFly. 01/15/19 12:41 PM
2018 Silverado 3500HD TPMS Re-Learn
by Phishin. 01/15/19 12:36 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
121 registered members (1.8Tango, 97prizm, 2003f7, AdditiveOCD, 28oz, 92saturnsl2, 13 invisible), 1,895 guests, and 33 spiders.
Topics296,610
Posts4,955,804
Members66,950
Most Online2,577
Jan 14th, 2019
STP Fuel Cleaner & Better MPG? #4758181
05/15/18 06:27 PM
05/15/18 06:27 PM
N. Calif - State of Jefferson
Greg L Offline OP
Greg L  Offline OP
Having bought a new (to me) 2010 Prius, I went through 2 tank fulls of gas.
On the second tank, I added some STP Super Concentrated Fuel cleaner, in the black bottle.
I would swear it had more MPG with that second tank. Averaged about 52 mpg, with use of Arco gas. (The first tank with no fuel treatment was also Arco gas)
Now I just did a 3rd fill up (Chevron gas this time) and no STP treatment....and now the MPG is back down to 49 mpg average.
Did STP do more than just clean the injectors, or make a difference at all? Should I add another bottle to get the job done even better?
This is the first time I've used this brand in a Prius.
GL
1951 GMC 1/2 Ton 270ci
2008 Jeep Compass 2.4
2010 Toyota Prius 1.8
2011 Dodge Ram 1500, 5.7 Hemi
Re: STP Fuel Cleaner & Better MPG? [Re: Greg L] #4758187
05/15/18 06:34 PM
05/15/18 06:34 PM
DFW
JustN89 Online content
JustN89  Online Content
DFW
In all likelihood, it made no difference. If it cleaned injectors, then there's no reason for there to be an immediate drop in MPG on next fill up as the injectors have already been cleaned and should perform the same. That said, there's just too many variables that affect MPG to point to any one thing when it comes to improved MPG.
Re: STP Fuel Cleaner & Better MPG? [Re: Greg L] #4758193
05/15/18 06:38 PM
05/15/18 06:38 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
I typically see unusually high fuel economy when running any fuel system cleaner.
Don't know why, but it does happen.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: STP Fuel Cleaner & Better MPG? [Re: fdcg27] #4758207
05/15/18 07:07 PM
05/15/18 07:07 PM
Tri State Conservative
Zee09 Offline
Zee09  Offline
Same here and then it falls back to normal.
"If I walked on water, they'd say I couldn't swim."
Re: STP Fuel Cleaner & Better MPG? [Re: fdcg27] #4758219
05/15/18 07:25 PM
05/15/18 07:25 PM
California
boom10ful Offline
boom10ful  Offline
California
Glad I'm not the only one. I experience this as well.
Re: STP Fuel Cleaner & Better MPG? [Re: Greg L] #4758236
05/15/18 07:43 PM
05/15/18 07:43 PM
HondaBroMike Offline
But top tier gas and use the highest octane if you are battling FD issues.
Re: STP Fuel Cleaner & Better MPG? [Re: Greg L] #4758344
05/15/18 10:48 PM
05/15/18 10:48 PM
CA
raytseng Offline
raytseng  Offline
CA
I've experienced the difference and chalk it up to UCL which make the engine run smoother, but I don't track the MPG so closely so can't comment on that.
Usually I can get the smooth behavior with just maintenance doses level of redline si-1 (to make things easy, I use 1/4th of a bottle every so often or every other tank).
If you noticed a difference, you could get the same results with other additives products, even those that are not as "super concentrated" or less effective at cleaning; as it's the ucl part you want and not necessarily need the cleaning part.
Re: STP Fuel Cleaner & Better MPG? [Re: Greg L] #4758905
05/16/18 02:18 PM
05/16/18 02:18 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
3 mpg difference in fuel economy isn't as big when you get high mpg as it is when you get low mpg.
For example, a 10 mpg pickup truck getting a 3 mpg (30%) increase is huge.
A 49 mpg car getting a 3 mpg (6.5%) increase isn't that much. You win some and you lose some on tanks.
2015 Hyundai Sonata 2.4L 89k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 232k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
