Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
102 registered members (01rangerxl, 2015_PSD, aaronc7, 77GrandPrix, 10 invisible), 1,559 guests, and 57 spiders.
Topics286,092
Posts4,902,394
Members67,560
Most Online2,967
Mar 10th, 2019
Rough idle - Running lean? #4754849
05/12/18 08:39 AM
05/12/18 08:39 AM
Australia
Spetz Offline OP
Spetz  Offline OP
Australia
Hi everyone,
Is there a product in a spray can that you can inject into the intake of a car to check whether a rough idle is causing by a lean condition?
I am not sure if butane gas in a can would work?
2003 Mitsubishi Diamante 6G74 3.5L. 5 Speed auto. 160,000 miles. Shell Helix Ultra 5W40 at 6k OCI
Re: Rough idle - Running lean? [Re: Spetz] #4754865
05/12/18 08:52 AM
05/12/18 08:52 AM
NH
supton Offline
supton  Offline
NH
Always thought anything flammable would work. WD40 on up. Usually one fogs in an area to see if recovers--pointing to a vacuum leak. Don't see why butane wouldn't work.
2011 Toyota Camry, base, 2.5L/6MT, 179k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 146k, ours
1999 Toyota Camry LE, 2.2L/4AT, 202k, his
Re: Rough idle - Running lean? [Re: Spetz] #4754868
05/12/18 09:00 AM
05/12/18 09:00 AM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
Carb cleaner, but it will increase your revs and possibly mask the issue.
If you want the job done right......do it yourself.
Re: Rough idle - Running lean? [Re: Spetz] #4754871
05/12/18 09:02 AM
05/12/18 09:02 AM
USA
mk378 Offline
mk378  Offline
USA
Check the fuel trims. Do a cylinder drop test to see if it is one cylinder misfiring or generalized.
Re: Rough idle - Running lean? [Re: Spetz] #4754922
05/12/18 10:04 AM
05/12/18 10:04 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I use a propane torch with hose among other things when looking for a vacuum leak, just turn the gas on and move it around the suspected area the idle will smooth out when you find one (not it isn't OSHA approved so do it outside). It does not work well with fans that run all the time.
Like this one.
Re: Rough idle - Running lean? [Re: Spetz] #4754953
05/12/18 10:42 AM
05/12/18 10:42 AM
California
Dave1027 Offline
Dave1027  Offline
California
Google "smoke test". +1 to the fuel trims idea.
Re: Rough idle - Running lean? [Re: Dave1027] #4755045
05/12/18 12:42 PM
05/12/18 12:42 PM
Trav Offline
Trav  Offline
Smoke testing is all well and good if you have one but most DIY usually don't happen to have one handy. Checking trim while looking for the leak is helpful when looking for a leak.
Re: Rough idle - Running lean? [Re: Spetz] #4755536
05/13/18 03:31 AM
05/13/18 03:31 AM
Australia
Spetz Offline OP
Spetz  Offline OP
Australia
Hi everyone,
Thanks for that.
I've had a smoke test done before and it showed no vacuum leaks.
I was thinking perhaps the AFM or something was faulty causing a rough idle.
The car idles worse with colder ambient temperatures.
The butane/propane test was purely to isolate or exclude any fueling issue.
At least in my mind that's what it'll show as if idle gets better I know it's a fueling issue and if it doesn't I know it's not - Would that be right?
Re: Rough idle - Running lean? [Re: Spetz] #4755554
05/13/18 05:10 AM
05/13/18 05:10 AM
Trav Offline
Trav  Offline
Correct, it is only to isolate the leak. If the idle gets better you have a vacuum leak in that area.
Re: Rough idle - Running lean? [Re: Spetz] #4755557
05/13/18 05:22 AM
05/13/18 05:22 AM
Australia
Spetz Offline OP
Spetz  Offline OP
Australia
Trav,
I was actually planning on feeding the butane gas directly into the intake just before the throttle body to isolate or exclude a lean running condition that may be causing rough idle.
Would my theory be sound?
My tests so far have shown no vacuum leak however perhaps an injector is faulty or something causing a lean condition in one cylinder?
As the car does periodically idle smoothly I believe whatever is causing it must be able to be corrected
Re: Rough idle - Running lean? [Re: Spetz] #4755562
05/13/18 05:31 AM
05/13/18 05:31 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I wouldn't do a thing till I checked the fuel trims first.
The "thinking" man's friend.
Re: Rough idle - Running lean? [Re: Lubener] #4755573
05/13/18 05:43 AM
05/13/18 05:43 AM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
What are we looking for when we check fuel trims?
Re: Rough idle - Running lean? [Re: das_peikko] #4755627
05/13/18 07:53 AM
05/13/18 07:53 AM
Trav Offline
Trav  Offline
Most engines have one O2/AFM (aka wide band O2) per bank, some inline have 2 and some modified engines use one per cylinder which is much better but more expensive and complex.
Given this V6 has one per bank fuel trims will tell which bank or both are adding fuel (eg +10) for a lean condition or taking fuel away (eg-10)because its rich.
If one bank is hovering around 0 give or take a couple of points and the other is +10 for example then that bank is running lean.
The problem is that bank has multiple cylinders making it difficult to pinpoint the exact one if the misfire count is the same for all.
Enriching the whole system through the TB wont help pinpoint the issue, checking the fuel trims to find out what is happening is the only real way to get a good starting point.
Back in the day when engines has secondary air system ports for each cylinder and no OBD 2 we removed them one at a time and put a gas analyzer probe down it to identify the offending cyl.
Re: Rough idle - Running lean? [Re: Spetz] #4755750
05/13/18 10:11 AM
05/13/18 10:11 AM
Australia
Spetz Offline OP
Spetz  Offline OP
Australia
The car only has a single O2 sensor.
I know the test I am proposing won't pinpoint the offending cylinder but all I am trying to achieve here is to establish whether or not a lean condition (on a single, multiple, all etc cylinders) is the cause of the rough idle.
If the car idles better once I inject butane into the intake then I know I should be looking at a lean idle condition.
How do I check fuel trims?
Re: Rough idle - Running lean? [Re: Spetz] #4755847
05/13/18 11:59 AM
05/13/18 11:59 AM
Trav Offline
Trav  Offline
With a scan tool. This engine has both banks going into a single pipe with one O2? GM V6 engines were like like.
Yes enriching the mixture to see if it smooths out will tell you if you have a lean condition but you need some numbers.
