Gas trimmers
by weeksjake. 01/22/19 09:11 AM
Supertech Heavy Duty 15W40 ...$9.64
by dblshock. 01/22/19 08:53 AM
Trooper recommends dash cameras
by FordBroncoVWJeta. 01/22/19 07:14 AM
New Harley synthetic 80w-140 gear released
by shanneba. 01/22/19 06:43 AM
Registering a Vacation Car
by ssamaroo01. 01/22/19 06:23 AM
Starter cross reference?
by dlundblad. 01/22/19 05:11 AM
Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
Binco, Coolbreez1973, jmcast1127, DF8005, FT86dude11
67009 Registered Users
93 registered members (4WD, 2015_PSD, 53' Stude, A310, 69Torino, 13 invisible), 1,872 guests, and 35 spiders.
Topics296,969
Posts4,962,601
Members67,009
Most Online2,821
Jan 21st, 2019
Cummins N14 5W40 vs 15W40 #4754096
05/11/18 09:58 AM
05/11/18 09:58 AM
Arizona
offtosleep Offline OP
Arizona
I have a 1999 Monaco Signature 45í Class A. The motor is a Cummins N14. Just added a FS2500 bypass filter plus the factory Fleetguard FF filter. I havenít filled it with oil yet, but want to run synthetic and do EOC. Any issues with running 5W40?
Re: Cummins N14 5W40 vs 15W40 [Re: offtosleep] #4754105
05/11/18 10:08 AM
05/11/18 10:08 AM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
Probably not, but in Arizona, no need to. The 15w40 would be just fine.
There is no advantage to synthetic unless the conditions call for it. Temperatures or extended drains, maybe, but there are many, many UOA that prove that a conventional will do just as well as a full synthetic, depending on application.
beanoil: Tough under heat, real dirty afterwards.
Re: Cummins N14 5W40 vs 15W40 [Re: offtosleep] #4754121
05/11/18 10:21 AM
05/11/18 10:21 AM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
Just run 15w40. Valvoline Premium Blue Classic if it's still available. Or Mobil Delvac MX.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: Cummins N14 5W40 vs 15W40 [Re: A_Harman] #4754128
05/11/18 10:29 AM
05/11/18 10:29 AM
Arizona
Arizona
Neither of those are available in my town. My only synthetic option is the Rotella T6 5W-40
Re: Cummins N14 5W40 vs 15W40 [Re: A_Harman] #4754129
05/11/18 10:32 AM
05/11/18 10:32 AM
wv
krismoriah72 Offline
wv
Many millions of miles logged on the old N14 engines using nothing but conventional 15w40. Spend the money on clean air filters and clean fuel filters as well as coolant.
How much of an extended drain do you want? 10000 miles is the normal change interval.
Re: Cummins N14 5W40 vs 15W40 [Re: krismoriah72] #4754149
05/11/18 11:01 AM
05/11/18 11:01 AM
Arizona
Arizona
My plan was to go as long as possible using analysis. I figure with the bypass filter I should be able to easily go 20,000 miles. That was based on my reading regarding synthetics since they have a higher TBN
Re: Cummins N14 5W40 vs 15W40 [Re: offtosleep] #4754172
05/11/18 11:18 AM
05/11/18 11:18 AM
wv
wv
Rotella T4 15w40 TBN is 10.27 http://pqiadata.org/Shell_Rotella_T4_15W40_4192017.html
Delvac 15w40 TBN is 11.0 http://www.pqiamerica.com/June%202014/ExmoDelvac13001540.htm
Rotella T6 5w40 TBN is 10.94 http://www.pqiamerica.com/June%202014/shellrotellat6.htm
Re: Cummins N14 5W40 vs 15W40 [Re: offtosleep] #4754185
05/11/18 11:41 AM
05/11/18 11:41 AM
Rabbit Creek, Alaska
jayg Offline
jayg  Offline
Higher starting TBN doesn't necessarily mean it lasts longer though. TBN can drop faster or slower depending on oil and conditions.
If your only synthetic option is T6 in 5w40 then run it if you are dead set on extended drains. You don't need it for the winter weather starting obviously but I would feel more comfortable with the synthetic going 20k miles with the bypass filter setup.
2018 Ford Ecosport AWD- Napa 0w20
2017 Ram 1500 Ecodiesel- CP Triton ECT 5w40
1973 Datsun 240Z 10w30- VWC from '73
1973 Triumph Bonneville 750- M1 5w50
1967 BSA 441 Victor Special- M1 5w50
Re: Cummins N14 5W40 vs 15W40 [Re: offtosleep] #4754194
05/11/18 11:55 AM
05/11/18 11:55 AM
Ocala, Florida
racin4ds Online content
racin4ds  Online Content
Ocala, Florida
If you're attempting extended drain intervals then yes you should use synthetic, and you should being that you've went to the expense and trouble to install a bypass filter setup.How many gallons of oil does the N14 hold?
I'm sure that ol Cummins will love the Rotella 5W40 either way.
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: Cummins N14 5W40 vs 15W40 [Re: offtosleep] #4754195
05/11/18 11:59 AM
05/11/18 11:59 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Exactly how many miles are you thinking of running the oil? Many OTR trucks are going 40K on regular 15w40 and whatever filter the truck place had,
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Cummins N14 5W40 vs 15W40 [Re: offtosleep] #4754276
05/11/18 01:27 PM
05/11/18 01:27 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
The only advantage the 5w- will buy you is below freezing starts. If you can use the starting advantage then run the syn.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Cummins N14 5W40 vs 15W40 [Re: racin4ds] #4754345
05/11/18 03:05 PM
05/11/18 03:05 PM
Arizona
Arizona
I canít find anyone who has run the 5W40 in that engine, hence my concerns. The manual calls for 14 gallons.
Re: Cummins N14 5W40 vs 15W40 [Re: CT8] #4754347
05/11/18 03:06 PM
05/11/18 03:06 PM
Arizona
Arizona
Despite being in Arizona, I donít live at the lower elevations. We were freezing up until about a week ago. I live at 8000 FT ASL
Re: Cummins N14 5W40 vs 15W40 [Re: Chris142] #4754350
05/11/18 03:09 PM
05/11/18 03:09 PM
Arizona
Arizona
Iíd love to go that long! I think with UOA and the bypass filter, Iím hopeful. I hate wasting good oil just because itís been. Year. I donít think Iíll put more than 20k per year anyway. Mostly just hate wasting 14 gallons of oil when I donít need to
Re: Cummins N14 5W40 vs 15W40 [Re: offtosleep] #4754443
05/11/18 05:48 PM
05/11/18 05:48 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
A lot of people have ran 5w40 HDEO in their N-14's, 350 engine hours should be easy to do with just about any good quality HDEO......That's a lot of run time for a recreational vehicle!!
2001 Chevy Camaro L92/4L80E
