Most engines today use a gear rotor crank driven pump, older engines mostly used the double spur gear pumps either in the pan or from cover.
The difference was not gear hardness but housing hardness, cast iron wore less than aluminum housings.
Front cover types were almost universally aluminum housings for some of these hardened stainless inserts were sometimes available along with longer spur gears, spacers and modified cover and relief valve.
Getting good oil pressure and flow with some of these old gear pumps could be a real challenge, brand new some engines has less than 10psi at hot idle and max of about 40 psi using 10w30.
