Originally Posted By: hallstevenson
Originally Posted By: daves87rs
Change the oil. It’s piece of mind and cheap.
It has 6800 miles on it. NOTHING needs changed at that point. Honda is perfectly okay with oil change intervals of close to 7500 (maybe longer nowadays). Our ’05 Odyssey had an oil percentage life counter and routinely went 7000 miles.
It is within 3 months of a year, they should have changed it unless there is a record of a change we don’t know about.
It has 6800 miles on it. NOTHING needs changed at that point. Honda is perfectly okay with oil change intervals of close to 7500 (maybe longer nowadays). Our '05 Odyssey had an oil percentage life counter and routinely went 7000 miles.
That is if the owner knowing it was going to get repossessed didn't dump say a quart of karo syrup into the oil. I would change it run a few hundred miles on a cheap conventional oil and then change it again to a full synthetic. But that just me go with what you feel comfortable with.
Honda Certified Pre-Owned Vehicle
https://www.hondacertified.com/certified-preowned-benefits
