If the unit uses no oil I’d stick with the same if it did I’d run a 40W oil. Makes no sense at all to be running a 5w30 at all ever.My 7000is is used in a very hot desert environment. In the summer ambient temps reach 115-120F routinely and year-round temps never go below 45F. I have 5500 hours on it and have been using Castrol 30W. I am considering switching to Mobil 1 5w-30 because synthetic is supposed to be better in hot environments and "evaporate" (I don't know what the technical term is ) as quickly as conventional oil does. Do the experts see anything wrong with my thinking? Or, should I just stick with Castrol 30W? Oh yea, the generator is located in a gazebo-like structure with four sides open to the weather, the sun NEVER shines on the generator. Rain is not a problem, we've only received .6 inches in two years.
Thanks for your time.
Paul
With 5500 hours on the generator why change now? I wouldn’t over think this. If the 30W oil has been working why the need to change? IMO I’d just keep doing what you’re doing.My 7000is is used in a very hot desert environment. In the summer ambient temps reach 115-120F routinely and year-round temps never go below 45F. I have 5500 hours on it and have been using Castrol 30W. I am considering switching to Mobil 1 5w-30 because synthetic is supposed to be better in hot environments and "evaporate" (I don't know what the technical term is ) as quickly as conventional oil does. Do the experts see anything wrong with my thinking? Or, should I just stick with Castrol 30W? Oh yea, the generator is located in a gazebo-like structure with four sides open to the weather, the sun NEVER shines on the generator. Rain is not a problem, we've only received .6 inches in two years.
Paul
Thanks for all the input. How long would you guys recommend running on the Dino oil before switching over to synthetic?
