Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
new tire 4 years old
by 1978elcamino. 04/19/19 08:51 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
109 registered members (Astro14, ABCarr, AandPDan, Al, 2004tdigls, andyd, 11 invisible), 2,222 guests, and 30 spiders.
Topics287,749
Posts4,933,775
Members67,850
Most Online2,967
Mar 10th, 2019
Octane, Ethanol, and Dilution #4729315
04/16/18 08:36 PM
04/16/18 08:36 PM
NC
Isophix Offline OP
Isophix  Offline OP
NC
I bought a 2018 Hyundai Elantra Sport a couple of weeks ago, and have been zipping around in it.
Got about 900 miles on it now.
Checked the oil today, smells like a fuel factory.
I have been putting 90 octane, ethanol-free Valero (a recommended Top-Tier branded) gasoline in it.
Does octane and/or ethanol levels play any role in dilution, or are they unrelated?
What steps can be taken to mitigate dilution?
The reason I like the higher octane and the ethanol free is supposedly they help prevent LSPI.
Re: Octane, Ethanol, and Dilution [Re: Isophix] #4729328
04/16/18 08:46 PM
04/16/18 08:46 PM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
I do a lot of oil changes. Almost all DI engines smell like fuel in the oil. That is no matter what make.
1998 Honda Accord EX 2.3L Auto (Sold) 214k mi
2009 Scion tC Manual (Daily Driver) 165k mi
Re: Octane, Ethanol, and Dilution [Re: Isophix] #4729330
04/16/18 08:49 PM
04/16/18 08:49 PM
PimTac Offline
PimTac  Offline
Reduce short trips if possible. Is the 90 the highest octane available?
I also short trip the Mazda but I purposely drive the long way when I can. Run the car at highway speeds for 30+ minutes each week if possible. The last thing to do is to keep oci short.
Cannot see signatures any longer so it doesn’t matter.
Re: Octane, Ethanol, and Dilution [Re: Isophix] #4729361
04/16/18 09:05 PM
04/16/18 09:05 PM
out there
spasm3 Offline
spasm3  Offline
out there
In your manual, you have the option of 3 oil weights. 5w20, 5w30, and 10w30 all in the chart on page 8-9. Since you smell fuel, and its a DI engine, and the manual allows it, i would run a 5w 30 oil. The fuel is already reducing the viscosity of the 5w20 to even less.
You could get a uoa sample drawn after a typical drive, and send it of to confirm fuel ( i'm going to do this on my mazda). A 5w 30 oil will give you a bit more viscosity if you are getting fuel dilution.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Octane, Ethanol, and Dilution [Re: Isophix] #4729369
04/16/18 09:12 PM
04/16/18 09:12 PM
pa
benjy Offline
benjy  Offline
pa
being in a warmer area the 10W-30 is a better choice, less viscosity improvers and a better noack, prolly a higher HTHS as well that is seldom shown anymore. noack and hths are important and not easily 'pumped' up by additives that do not last.
Re: Octane, Ethanol, and Dilution [Re: Isophix] #4729377
04/16/18 09:20 PM
04/16/18 09:20 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Unless it is very well known synthetic (Mobil, Motul, etc.) the XW rating mostly tells you what the base oils are. 5W is thinner than 10W in base oils. Then they add VII's to make the op temp (hot) grade numbers.
Fuel dilution thins the base oils badly, so given any choice, always opt for the highest XW grade they will allow. In this case it's 10W-XX.
Don't put expensive oil in there as you'll have to run short oil change intervals. The only effective solution for fuel dilution is change the oil ... Sorry, but it's a fact of some cars life. It used to be bad carburetors, now it DI engines. We're back to 3~5,000 mile oil changes.
Use a good quality oil with chemistry that will reduce intake deposits, but no need for expensive synthetics as you are not going to get their real benefit before the oil has to come out ... frown
Re: Octane, Ethanol, and Dilution [Re: Isophix] #4729386
04/16/18 09:28 PM
04/16/18 09:28 PM
Florida
hatt Offline
hatt  Offline
Florida
FYI, not that it has anything to do with your situation. The 90 octane E0 may not be the same brand as the station.
2013 F150 5.0, Delo XLE CK-4 10W-30, Baldwin B7449
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Octane, Ethanol, and Dilution [Re: BrocLuno] #4729389
04/16/18 09:28 PM
04/16/18 09:28 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
OCI, OCI, OCI is most important when combating dilution, nothing else.
18 KIA Sportage 2.4 AWD
QSUD 5W-20, PH9688
13 Hyundai Santa Fe Sport 2.0T
PP EuroL 5W-30, OE
Re: Octane, Ethanol, and Dilution [Re: Isophix] #4729463
04/16/18 11:20 PM
04/16/18 11:20 PM
workbench CZ-USA KS KC
Marco620 Offline
Marco620  Offline
Just stay with the pure fuel and 5w30 full synthetic oil. Clean throttle body with CRC GDi IVD cleaner. iTs made for DI and has PEA in it every 10k. Use Gumout Regane/Redline Si-1 in conjunction. No Seafoam. No PEA,no good.
15' Civic 1.8 i-vtec 229,500 mi Redline oil & M1 3:1/BP transmax cvt fluid & Archoil9100
Say no to drugs, union made cars and amsoil.
Son of a Navy Corpsman. Support vets!
Re: Octane, Ethanol, and Dilution [Re: Isophix] #4729490
04/17/18 12:43 AM
04/17/18 12:43 AM
burlington ,ontario, canada
ndfergy Offline
ndfergy  Offline
Go with the octane rating as specified in your owners manual. If it's regular then using a premium will have no benefit. The octane rating is commensurate with your normal combustion chamber temps. Going with a higher octane when not required could lead to more unburned fuel.
2015 Toyota Yaris 5spd Manual
Summer: Mobil Super 1000 10w30
Winter: Mobil Super 1000 5w30
OEM Filter
Re: Octane, Ethanol, and Dilution [Re: wemay] #4729510
04/17/18 02:02 AM
04/17/18 02:02 AM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
What's the typical OCI called out by manufacturers for their DI engines? If fuel dilution is a major concern I'd think the OCI would be less than a typical non-DI vehicle calls out.
Re: Octane, Ethanol, and Dilution [Re: ZeeOSix] #4729520
04/17/18 03:18 AM
04/17/18 03:18 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
My normally aspirated GDi?
Normal: 7500 /12 months
Severe: 3750 /6 months*
The turbo GDi?
Normal: 5000 /6months
Severe: 3000 /same*
*me
QSUD 5W-20, PH9688
PP EuroL 5W-30, OE
Re: Octane, Ethanol, and Dilution [Re: Isophix] #4729583
04/17/18 06:55 AM
04/17/18 06:55 AM
The land of USA-made Subies!
SubieRubyRoo Offline
So wemay, you could say it is the turbo that changes the OCI recommendation, NOT the fact that they are GDI.
Based on many EcoBoost UOAs, I think the whole fuel dilution thing is WAY overblown on here. I can't remember seeing ANY UOA that was truly concerning solely due to excessive fuel. Maybe now that we're moving to ultra-low sulfur fuels it's nowhere near the issue it once may have been? I know gasoline is not a lubricant... but it also has a much, much lower viscosity and therefore would be "pushed away" by the oil?
I'm not saying try to run 20k OCIs on a GDI, but I think a large portion of the witch hunt is just that, until I see horrible UOAs or failed GDI engines that had reasonable UOAs. JMO
Re: Octane, Ethanol, and Dilution [Re: Isophix] #4729591
04/17/18 07:03 AM
04/17/18 07:03 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Some distillation curves
Premium should have less left in the crankcase both with or without ethanol.
Re: Octane, Ethanol, and Dilution [Re: Isophix] #4729608
04/17/18 07:24 AM
04/17/18 07:24 AM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
I agree with SUBYRUBYROO THAT fuel dilution in most cases is overblown because, the wear values are usually low or in-line with non DI engines. A teas-spoon of gasoline in a gallon of oil smells like 50% fuel due to the aromatics in gasoline. I guess BITOGers need something to champion. Ed
2014 CX5 Touring 2.5L :-)
