White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
27 registered members (DaleRider, Char Baby, billt460, claluja, 4 invisible), 796 guests, and 29 spiders.
Topics296,866
Posts4,960,384
Members66,982
Most Online2,688
Jan 19th, 2019
High concentrate injector cleaner in a engine #4729260
04/16/18 07:01 PM
04/16/18 07:01 PM
Montreal,Quebec,Canada
Yannick Offline OP
Yannick  Offline OP
Hello,
I have a boat with a fuel tank of 60gallons.
My engine is now reaching 1000hours and its a 2008.
Its running a little bit "rough". I want to clean up injectors and intake.
Instead of removing all injectors a guy suggested me to remove the main gas line and use a separate line connected in a 5gallons of gas mix with high concentrate injector cleaner like P.i. Performance Improver Gasoline Additive from Amsoil.
High concentrate = 5gallons for all the P.I bottle. (Amsoil suggest 20 gallons for one bottle of P.i)
Do you see any problem running high concentrate injector cleaner through the gas pump ? (I mean can it damage rubber seals, diaphragm etc...)
Its a Volvo Penta gas pump
Once the 5gallons is burned, I will reconnect the gas line to the main tank.
In parallel of that I will Seafoam it.
Re: High concentrate injector cleaner in a engine [Re: Yannick] #4729282
04/16/18 07:19 PM
04/16/18 07:19 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
no
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: High concentrate injector cleaner in a engine [Re: Yannick] #4729392
04/16/18 08:31 PM
04/16/18 08:31 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
Of all the things I've tried B12 chemtool was the only thing that made a difference, give it a whirl.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 104K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 37k Idemitsu 0w20, 57047
Re: High concentrate injector cleaner in a engine [Re: Dyusik] #4729397
04/16/18 08:37 PM
04/16/18 08:37 PM
out there
spasm3 Offline
spasm3  Offline
out there
+1
I don't care for seafoam. If you don't like alcohol in fuel, why add a product that has more alcohol?
With a boat, i would not want alcohol in the fuel. Why buy ethanol free fuel then add alcohol back in with seafoam? Is mostly light oil and alcohol.
13 elantra 72k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 7300 miles m1 0w30
Re: High concentrate injector cleaner in a engine [Re: Yannick] #4729406
04/16/18 08:52 PM
04/16/18 08:52 PM
Parts Unknown
UG_Passat Offline
UG_Passat  Offline
Parts Unknown
On diesels, there is lubro (liqui) moly diesel purge, which is a high concentration cleaner and fuel.
Startron is a popular additive for good reason in boat motors
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: High concentrate injector cleaner in a engine [Re: Yannick] #4729462
04/16/18 10:15 PM
04/16/18 10:15 PM
[email protected] CZ firearm factory
Marco620 Offline
Marco620  Offline
Stay away from Seafoam. Try Redline Si-1
15' Civic 1.8 i-vtec 207,000 mi 0w20 Redline/Redline CVT/Archoil9200/TEIN/Eibach/Tanabe Sustec/Borla Exhaust/Redline Si-1/87 E0 fuel
Son of a Navy Corpsman. Support vets!
Re: High concentrate injector cleaner in a engine [Re: Yannick] #4729594
04/17/18 06:07 AM
04/17/18 06:07 AM
Central NY
rsylvstr Offline
rsylvstr  Offline
Central NY
B12 but burn it as fast as you can.
2013 F150 SCrew Lariat 4X4 5.0 3.55
2012 Altima SL that still vibrates.
2018 Polaris Sportsman 850 SP. Polaris fluids and filter.
Re: High concentrate injector cleaner in a engine [Re: Yannick] #4730217
04/17/18 04:53 PM
04/17/18 04:53 PM
USA
SOHCman Offline
SOHCman  Offline
USA
+1 on redline SL-1 and B12 chemtool. Even the cheap Gumout at WM has PEA in it.
I urge people not to wait 100K to change out the fluid in their transfer case units. -Kestas
Re: High concentrate injector cleaner in a engine [Re: Yannick] #4731525
04/18/18 09:37 PM
04/18/18 09:37 PM
CA
raytseng Offline
raytseng  Offline
CA
how long does it take you to use the 60gallons tank? Is it full now?
Are you in a rush?
Why not just start by throw 2 bottles of si1 into whatever you have in the tank and see if that resolves the issue over a longer time, even though thats just the "normal" shock dose, and not a double or quad dose.
If you get down to 10gallons and fill up the diluted remainder still is fine. Si1 is also a fuel preservative
Re: High concentrate injector cleaner in a engine [Re: Yannick] #4738240
04/25/18 09:23 AM
04/25/18 09:23 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
Any strong solvent will help so B12 is good in the short term, after the B12 use Redline Si1 at 1 bottle per tank for the next 3 tanks.
Cable ties should hold it
