So, I have a sort of partially restored 1965 black bomber, actually a particularly early one at serial number 1657.
Cast into the alumnimum case, it says to use 30wt over 50 degrees, and 20 weight below, and that the oil capacity is 2.3L. It seemsly like everyone runs a thicker oil in vinatge bikes, so I ran it on 15W40 delo and Rotella T last summer, and this year I have 15W50 yellow cap mobil 1 in it (it was on sale for $4.50/qt). Is this an OK oil choice? I'd just assume not glaze a clutch since the early 4 speed models are particularly hard to find clutch and transmission parts for.
Dumb question, but if anyone actually has a vintage honda, where's the oil supposed to be on the dipstick?
How often should I change the oil? I did a couple of quick changes last summer since the bike had sat for 30+ years, but now I would imagine things are reasonably clean in there.
Finally, several good honda mechanics I know advised never cleaning the centrifugal oil filter, but I think they were more concerned about mouth-breathers that put the cover on indexed wrong and destroy engines with the resulting 0psi oil pressure. I've wiped out the filter once, and there was only maybe 0.025-0.050" of sludge in it and no metal visible metal. Should I mess with the filter at all? How clean should I try to get the housing? I just wiped it out with papertowels last time, without using solvents or anything.
