Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
29 registered members (Brad_C, bbhero, c502cid, 5 invisible), 531 guests, and 59 spiders.
Topics286,442
Posts4,908,263
Members67,622
Most Online2,967
Mar 10th, 2019
2001 Impala check engine light on question #4727070
04/14/18 07:50 PM
04/14/18 07:50 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline OP
JimPghPA  Offline OP
Yesterday on the way back home the check engine light came on on our 2001 Chevy Impala with 102 K miles on it. Today I stopped in Advance Auto Parts and borrowed their code reader. No P codes came up,
but it did say:
Exhaust gas recirculation flow insufficient detected
Top reported fix 1 - cleaned exhaust gas recirculation (EGR) passages
freq reported fixes:
1 - replace exhaust gas recirculation (EGR) valve
2 - cleaned engine carbon
3 - cleaned exhaust gas recirculation (EGR) transfer tube
4 - clean intake manifold
5 - replace intake manifold
6 - cleaned throtle body
I looked on youtube for "Chevy 3.4 EGR" and there are videos showing the passageway that is part of the intake manifold that goes from the EGR valve to the intake port, and it shows one that was completely clogged up. This is probably what is going on with our Impala.
I am going to be very busy for the next four weeks then I will have a couple of weeks when I will not be busy. Do any of you see any problems in putting off fixing this exhaust gas flow problem for four weeks and continuing to use the car every day?
The engine runs fine, and I had it inspected last month so there is currently no problem in having the check engine light on for several weeks. I think that if the EGR valve had failed open that it might be something that requires immediate attention. But according to what the code reader displayed there is an insufficient flow of exhaust gas, so basically it failed in the not supplying exhaust gas mode.
So what do you say, does anyone see any possibility of causing engine damage by driving it the way it is for four weeks, about 100 miles per week?
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: 2001 Impala check engine light on question [Re: JimPghPA] #4727084
04/14/18 08:00 PM
04/14/18 08:00 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
You may notice slight pinging because the exhaust gases are used for cooling in the combustion chamber and help prevent detonation, if so use the next higher octane fuel, otherwise no problem other than the CEL.
Edit: Give the EGR valve a couple of sharp taps with a rubber mallet just for the heck of it.
Re: 2001 Impala check engine light on question [Re: JimPghPA] #4727102
04/14/18 08:24 PM
04/14/18 08:24 PM
MN
14Accent Offline
14Accent  Offline
MN
3.4? Clogged passages for sure.
You won't hurt anything until you get around to fixing it. Drive on.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: 2001 Impala check engine light on question [Re: JimPghPA] #4727117
04/14/18 08:38 PM
04/14/18 08:38 PM
ME
eljefino Offline
eljefino  Offline
ME
You might only need 1/2 hour to an hour to get the valve off and see what's going on. Sometimes the pintle hangs up and you can poke it with a pencil or spray brake cleaner in to clean it.
Though I understand not wanting to mess with your ride to work when you're busy.
Re: 2001 Impala check engine light on question [Re: JimPghPA] #4727128
04/14/18 08:50 PM
04/14/18 08:50 PM
JimPghPA Offline OP
JimPghPA  Offline OP
Trav, thanks for the info, and the suggestion to run high octane.
I have not noticed any pinging. Currently, it has a half tank of 87 octane. I will fill it with high-test, and run high test until I can get it fixed.
JimPghPa
Re: 2001 Impala check engine light on question [Re: JimPghPA] #4727132
04/14/18 08:52 PM
04/14/18 08:52 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
It should have a P0401 stored in the PCM, You may want to have it checked with a better/different scan tool if the AZ one couldn't show such a generic DTC, It's also possible the operator didn't enter correct vehicle info in the scan tool.
P0401 is NOT usually set by the EGR valve itself, GM OBD II EGR valves have a Pintle Position Sensor, If the Desired/Commanded Pintle Position is more than 15% different from the Actual/Read Pintle Position......DTC P0404 will set.
Unless you have a bad exhaust leak.....I would lean toward a clogged/partially clogged EGR passage. ALL the EGR passages (That aren't part of the Valve Assembly) are in the Upper Intake Manifold which isn't to bad to remove & clean.
In some rare cases.....P0404 is not enabled in the calibration, But not likely on a 2001 Impala.
2001 Chevy Camaro L92/4L80E
Re: 2001 Impala check engine light on question [Re: JimPghPA] #4727172
04/14/18 09:35 PM
04/14/18 09:35 PM
ME
eljefino Offline
eljefino  Offline
ME
I legit cleaned the passages in a saturn with electric EGR (same as yours) with a frayed bike brake cable chucked in a drill. It's a cliche but it works.
When you have the valve off, run the motor. If it's not loud with exhaust it's on that end of things. If it idles normally the intake side's plugged.
Re: 2001 Impala check engine light on question [Re: eljefino] #4728242
04/15/18 08:20 PM
04/15/18 08:20 PM
JimPghPA Offline OP
JimPghPA  Offline OP
That is a great idea on how to troubleshoot what passageway is clogged.
JimPghPa
Re: 2001 Impala check engine light on question [Re: JimPghPA] #4731365
04/18/18 07:39 PM
04/18/18 07:39 PM
Florida
artificialist Offline
Florida
I would sometimes encounter steel EGR lines that would crack during removal, so I say you just leave the EGR system alone until you have extra time. You can probably leave it alone for a while.
2010 Lancer Ralliart Sportback
