EGR code 32 on my 1991 Grand Am 2.5L
Suburban Washington DC
The car runs great overall and cruises at 70 just fine. It rides on a set of Michelins and feels quite smooth. The issues are pinging on even light acceleration and a rough idle. The code 32 confirms it as EGR related so that makes sense. I ordered a repair manual so that should help. In the mean time, is the EGR valve controlled by the computer and a solenoid, or just by vacuum? I'll removing and cleaning out the carbon but sure how actually works
I believe those were ran off "Ported Vacuum" The ECM checks EGR operation by using "Block Learn" values (Now called fuel trims).....If the engine is only running lean when the EGR should be flowing, The PCM will set a EGR DTC.
  • Helpful
Reactions: GON
Apply vacuum to the valve while the engine is idling, the engine should die or come close to it.. That should tell you if the valve is working and the passages are clear without taking it apart and to start looking upstream from the valve for problems..
My 1990 Century w/Iron Duke will on occasion throw that code. I've cleaned my EGR and even replaced with OEM, still does it.
That's where I would start.
If you have easy access to the valve, you can also start cold and immediately squeeze the diaphragm with your fingers.
I had code 32 on a 1994 Saturn. I took the valve off to clean it and found the pintle basically jiggling around inside. The code came back with a new valve, and the "activate at idle" test caused no change in idle quality. I finally figured out that the intake passage was sealed shut with hard carbon after years of burning a quart of oil every 400-500 miles.
I'm not sure this applies to your Pontiac, but the Saturn also had a solenoid that controlled vacuum to the EGR. I found some brittle vacuum lines while troubleshooting it.
I had that issue on my 90 G/A 2.5, was a bad EGR valve diaphragm.
When you introduce hot egr gas back into the engine, the fuel/air charge is less volatile, so when the valve stays closed, you don't get that displaced charge and it burns hotter...then pings.
Test the hose first.
  • Like
Reactions: wlk
I took the valve off and tested with a Mityvac. It won't hold ANY vacuum. There is NO movement. Diaphragm must be busted. Says Rochester Products on it so probably the original.
And so many counterfeits on Ebay and Amazon. No way a genuine Delphi is $15 or $18 when the normally go for $75.
Not showing the actual box is a big clue it's fake. Decided on this Standard one for $33 that's also cheaper but looks like the seller bought and never used. Also has much better feedback and isn't selling thousands of parts.
Not if it is a positive back pressure EGR valve. GM began using positive and negative back pressure EGR valves back when still using carburetors to control EGR flow. Does it have an N or P at the beginning or end of the part number on the top side of the valve?
The one I ordered above, has the N.
Now since it's mounted on the intake manifold, and the exhaust manifold is on the other side of the engine, is there a passage inside the head between the two? If so, how to clean without taking the exhaust manifold off?
Exhaust passage through the head, apparently. I've never had a Duke/Tech VI. A coat hanger and a vacuum if the ports are blocked. I've only seen them clog on the intake side myself.
Get a bike brake cable, they're like four bucks if you don't have a junk bike. Fray the end, put the other end in the drill. Don't laugh, it works wonderfully.
Stuff it in there, run the drill. With the valve removed, run the car. If you did what you meant to do, the exhaust will be loud and the idle will be high, or it will otherwise show signs of a vacuum leak. Any chunks of carbon you break loose won't hurt the motor, but if you're worried, stuff some tubing in the end of a shop vac, plug the rest of the hole with a rag and duct tape, and vacuum the stuff out.
So it worked, LOL. The surface area of that pintle hole is like half a square cm. You know you're not obstructed.
  • Like
Reactions: wlk
