Weird Electrical Issue.
by George7941
04/21/18 09:35 AM
Ever puchase movies from cable provider?
by ZZman
04/21/18 09:31 AM
Mann HU 711/51 X oil filter for Mini’s $6.50 Amzn
by 1JZ_E46
04/21/18 09:30 AM
M1 Oil For My Trucks Engine
by BlueOvalFitter
04/21/18 09:30 AM
Toyota SofTex upholstery
by CincyDavid
04/21/18 09:09 AM
Castrol Dexron VI $5 QT at AA
by The_Cams
04/21/18 08:41 AM
Liqui moly engine flush
by gallydif
04/21/18 08:27 AM
Uneasy about Bosch Cartridge Filter
by tc1446
04/21/18 07:36 AM
Harvest King 0w20 Full Synthetic
by oilstudent24
04/21/18 07:22 AM
oil spec.
by ernied
04/21/18 07:03 AM
Great dog story to start your day!
by AZjeff
04/21/18 06:51 AM
BITOGers in the wild west
by Shannow
04/21/18 03:54 AM
'10 Wrangler 5,350 Miles Cam2 5w30 Synavex
by montero1
04/21/18 03:31 AM
Jack Horner Ted Talks - Dinosaurs - good fun watch
by Shannow
04/21/18 02:00 AM
PP life span in engine
by barber613
04/21/18 01:58 AM
Ford Focus parts clearout! 2000-2007
by Lolvoguy
04/21/18 01:48 AM
Bad O2 sensor?
by Spetz
04/21/18 01:13 AM
Let's talk Renault
by dishdude
04/21/18 01:05 AM
Ipad covers
by daves87rs
04/21/18 12:11 AM
Did I screw myself...
by NoNameJoe
04/20/18 10:15 PM
mowermon, Slashdotfx, Dilly, Amersham, Irene
64801 Registered Users
78 registered (1JZ_E46, ABursell, amh, A310, 2004tdigls, 9 invisible), 1612 Guests and 41 Spiders online.
64801 Members
68 Forums
282059 Topics
Page 1 of 2 1 2 >
#4725120 - 04/12/18 08:29 PM Quieting Hemi Tick with Redline Oil
CC1981 Offline
Loc: MA
First thing, if your Hemi powered car/truck is still under warranty, I recommend taking it to the dealer. Hopefully they will fix it for you but if they don't, at the very least it will be documented. If they essentially blow you off like they did to
me, continue reading.
For a lot if not most people, the 5.7 Hemi is a nice smooth running engine with any oil thats put in it. For others the 5.7 Hemi has a pretty loud tick either on startup or after its completely warmed up. Not to be confused with a broken exhaust manifold bolt(s),
this is a metal on metal tick that comes from the internals of the engine, most likely from the lifters although thats never
been proven 100%.
My 2013 Ram 1500 developed a loud tick at a fully wamrmed up idle around 2500 miles when I drained out the PYB 5w20 that was in
it and put in PP 5w20. The motor sounded absolutely horrible, you literally could hear all the metal componants hitting against
each other. Now I believe PP is a fantastic oil, it just didn't agree with my Hemi. Because it got was such a drastic change
right after an oil change, over the next few years I tried many different oils including PYB 5w20, PUP 5w20, Amsoil OE 5w20,
Amsoil SS 5w20 and 5w30, Redline 5w20/5w30/0w30, Mopar 5w20 from the dealer which is either PYB or PG. The only two oils that
made a difference in how it sounded were PYB 5w20 which minorly quieted it up. For a complete list of the oil changes I did up
until the summer of 2017 check this post out:
Oils used and Mileage
After taking my truck to the dealer 3 times and 3 times being told it was "normal Hemi noise" I had given up. It was
either live with it ticking like it was going to grenade or find my own answers. After spending many hours researching different oils, I
figured I'd give Redline oil a shot because there were claims that it quiets Hemi's as well as many different engines. I figured
there was nothing to lose except some money.
First I tried Redline 5w20. It helped but the tick was still there. Then I tried Redline 0w30 because at the time I was nervous about
running a 30 weight oil in an engine that was spec-ed by the manufacturer for 5w20. It was also winter so I went with a 0w. 5w20 vs 5w30 in a 5.7 Hemi is a whole other discussion, long story short, you can run a Xw30 oil in a 5.7 Hemi with absolutely no MDS problems and no codes thrown. This has been proven many times. Anyways Redline 0w30 made it quieter than Redline 5w20, but the ticking was still there to a point at hot idle.
Then I tried Redline 5w30. On paper it looks fantastic compared to their 0w30, mainly a high HTHS of 3.7 for a 30wt oil. Each time I ran a Redline oil I gave it a good 500+ miles for the high moly in Redline oil to plate to all high contact surfaces in the engine. Here's a
video documenting how quiet my truck is on Redline 5w30. Pay particular attention from 39 seconds to 1:03.
https://youtu.be/89_9ZDBdmss
After confirming an oil alone can quiet my Hemi, I decided to try the new formula Amsoil SS 5w30 since it now has 225+ ppm of
moly. It can be had cheaper than Redline so if it worked like Redline I can save some money. 500 miles into new formula SS 5w30,
it started developing the hot idle tick again shown in this video:
https://youtu.be/CjMDKz1yZLI
This is what it sounded like when I put PP 5w20 in it, except with PP it was easily twice as loud. If I went through a drive
thru I would have to shut the truck off to be able to hear anything. It was that bad. I ended up draining out the SS 5w30 and
put Redline 5w30 back in. I only have about 100 miles on that oil so its still a little loud but not as loud as it was on SS
5w30.
https://youtu.be/L-eiCtFaYLo
Let me reiterate, I believe both PP and SS are great oils. Many people run them in 5.7s with great results. I currently run SS
0w20 in my wifes 2017 Jeep GC 3.6 and it runs very smooth and quiet.
A couple other oils that may quiet a Hemi are Schaefers and Motul. Both have high moly but keep in mind simply having an oil
with high moly such as new formula SS doesn't necessarily mean its going to quiet a Hemi. I believe PAO/Esters and a high HTHS
are also required. Maybe even the higher zinc in Redline has something to do with it.
So if you have a ticking Hemi give Redline 5w30 a shot. If you're worried about running a 5w30 in your 5.7, try Redline 5w20.
Redline 5w20 has worked for some, but didn't quiet mine up as much as Redline 5w30.
When I get 500+ miles on my current Redline 5w30 fill I will take another video.
Hope this helps someone out there quiet their noisy Hemi.
2013 Ram 1500 Crew Cab 5.7 Hemi
Redline 5w30 | Royal Purple 20-820
2017 Jeep Grand Cherokee 3.6L
Amsoil SS 0W-20 | Mopar 349
#4725129 - 04/12/18 08:41 PM Re: Quieting Hemi Tick with Redline Oil [Re: CC1981]
JeepWJ19 Offline
Loc: PENNSYLVANIA
Test out the HTHS and zinc theory with Rotella 5w30? Maybe that'll help narrow the choices down some more?
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 |
TG8A | 2.5" lift | 148k miles
Software Engineer :]
#4725130 - 04/12/18 08:41 PM Re: Quieting Hemi Tick with Redline Oil [Re: CC1981]
Brett776 Offline
Loc: Florida
I’ve heard people say redline time and time again to quiet the Hemi. My 2014 Ram has been on a steady diet of PUP for the past 20k miles, now at 41k miles. I have no tick at all, at least for now. I’ll keep redline in mind if I get that tick.
#4725135 - 04/12/18 08:45 PM Re: Quieting Hemi Tick with Redline Oil [Re: Brett776]
JohnnyJohnson Online   content
Loc: Wet side WA
But just think you could have spent almost twice as much for the Redline and still had no Hemi Tick. Then think how lucky you'd be!
2004 Toyota Corolla 119625
Out: QSUD 5W-30 Purolator One 5030 mile OIC
In: 2-8-18 Valvoline ML 5w-30 Fram TG4967 117530
2006 Duramax 73752
#4725147 - 04/12/18 08:55 PM Re: Quieting Hemi Tick with Redline Oil [Re: CC1981]
OVERKILL Online   content
Loc: Ontario, Canada
There was an entire thread on this already, I'll see if I can dig up the link.
2016 Durango Limited
2016 Grand Cherokee SRT
#4725151 - 04/12/18 08:58 PM Re: Quieting Hemi Tick with Redline Oil [Re: CC1981]
Here it is, the thread by burla:
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4499626/1
And you participated in it, LOL
#4725160 - 04/12/18 09:04 PM Re: Quieting Hemi Tick with Redline Oil [Re: CC1981]
CC1981 Offline
Loc: MA
Yep I'm aware of that, I did link to it afterall lol. However since I now have some videos documenting, I figured it was new thread worthy.
#4725166 - 04/12/18 09:08 PM Re: Quieting Hemi Tick with Redline Oil [Re: CC1981]
Ahhh, OK, I didn't click that link because of the name on it, I assumed it wasn't the same thread (title is quite different).
I'd argue that the videos might have been more helpful in the other thread, given its length and depth of delving into this topic, but I do understand why you created this new one.
#4725174 - 04/12/18 09:13 PM Re: Quieting Hemi Tick with Redline Oil [Re: CC1981]
Snagglefoot Online   content
Loc: Alberta
Thanks, that was well explained and will help a lot. Anyone who has the same problem should follow your instructions and report back. smile
#4725182 - 04/12/18 09:16 PM Re: Quieting Hemi Tick with Redline Oil [Re: CC1981]
jeepman3071 Offline
Loc: Storrs, Connecticut
Interesting.
My father has a 2013 Grand Cherokee with the 5.7L. It just passed 110k miles and is pretty quiet. I run Pennzoil Platinum, but I've been running 5w30 since around 30,000 miles or so.
2000 Jeep Cherokee Sport 4.0L (179k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
#4725196 - 04/12/18 09:27 PM Re: Quieting Hemi Tick with Redline Oil [Re: CC1981]
SEMI_287 Online   sleepy
Loc: Up State NY
My 300C has a tick but it doesn't sound like that. Just a tiny tick just a tad louder than the injectors, not like you're hitting the block with a pall peen hammer.
I thought they got all that figure out with the redesign.
2005 BMW 325xi- Castrol Edge 0w40, STP
2008 Mitsubishi Galant- Parts Master 5w30, Wix
#4725200 - 04/12/18 09:32 PM Re: Quieting Hemi Tick with Redline Oil [Re: CC1981]
Hammehead Offline
Loc: Right there
Is it the polyolester, not he moly, that quiets the Hemy tick down?
ToYota Corolla XEI 2010 1zzfe
Kawasaki Ninja ZX9R B4
Taurus GL Vulcan
Citroen C5 phase I
I used to use syn, now whatever is on sale and never had problems. This noob knows stuff.
#4725208 - 04/12/18 09:47 PM Re: Quieting Hemi Tick with Redline Oil [Re: CC1981]
deven Offline
Loc: Massachusetts
Try adding a can of BG MOA and you'll really quiet the hemi tick. Know so many people who run Royal purple HPS 5w30 and love it because it really quiets the tick down as well..
Proud user of ROYAL PURPLE products!
2016 Acura RLX Sports Hybrid(Royal Purple HPS 5w30 + RP 10-2808 oil filter)
#4725285 - 04/12/18 11:43 PM Re: Quieting Hemi Tick with Redline Oil [Re: CC1981]
07hemi Offline
Loc: NE
My hemi use to tick bad. First few years I used Mobil 1 in both 5w20 and 5w30 but it would tick bad on idle. Current oil I'm running is redline 5w20 and it made a huge difference but it still has a slight tick. I just found a local dealer who got me 5w30 schaeffers for 6 dollars a quart so I'll be trying that here in a few weeks. I figured it's worth a try as I paid around 11 dollars a quart for the redline.
2016 Dodge Dart GT 2.4 Schaeffer's 0w20 (mine)
2015 Chrysler 200 AWD 3.6 Castrol Magnatec 5w20 (wife's)
2007 Dodge Ram 1500 5.7 Redline 5w20 (mine)
#4725366 - 04/13/18 06:21 AM Re: Quieting Hemi Tick with Redline Oil [Re: CC1981]
edyvw Offline
Loc: Colorado Springs
Try oils like Castrol 0W30 ACEA A3/b3 B4, or Castrol 5W30 ACEA A3/B3 B4. Especially 0W30 is known as smooth oil, it is "heavy" W30 oil made for Euro cars with HTHS of 3.5cp.
Considering that you already used Redline with HTHS 3.7, I would also check Castrol 0W40 (same base as 0W30) in Walmart for $27 for 5qt. It has HTHS also 3.7cp.
13' BMW X5 35d (Mobil1 5W30 ESP+OEM filter)
11' VW Tiguan 2.0T (Castrol 0W40+OEM filter)
Page 1 of 2 1 2 >
