Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
32 registered members (Bailes1992, 2015Corolla, 4WD, billt460, 5 invisible), 523 guests, and 58 spiders.
Topics286,442
Posts4,908,266
Members67,622
Most Online2,967
Mar 10th, 2019
Oil filter gasket vs. valve cover gasket #4724844
04/12/18 03:03 PM
04/12/18 03:03 PM
Canada
camrydriver111 Offline OP
Canada
Why is it that when you install a screw-on oil filter they tell you to lube the gasket with oil, and when you install a valve cover gasket they tell you the gasket surface has to be free from oil?
BITOG or: How I Learned to Stop Worrying and Love the Extended OCI
Re: Oil filter gasket vs. valve cover gasket [Re: camrydriver111] #4724848
04/12/18 03:10 PM
04/12/18 03:10 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Lubing the filter gasket makes it easier to unscrew later, on cartridge filer caps it allows easier seating of the cap .
Re: Oil filter gasket vs. valve cover gasket [Re: camrydriver111] #4724849
04/12/18 03:12 PM
04/12/18 03:12 PM
Modesto,CA
mehullica Offline
mehullica  Offline
Modesto,CA
Be use the filter seal needs oil to lube the seal as itís scrubbing against the oil filter sealing area while itís turning to be tightened.
The valve cover gasket doesnít need oil because it being tightened down in one direction
Re: Oil filter gasket vs. valve cover gasket [Re: camrydriver111] #4724872
04/12/18 03:54 PM
04/12/18 03:54 PM
Ruidoso, NM USA
ammolab Offline
ammolab  Offline
Ruidoso, NM USA
It has been my experience that sooner or later...valve cover gaskets oil themselves!
2009 Honda CR-V
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: Oil filter gasket vs. valve cover gasket [Re: camrydriver111] #4724874
04/12/18 03:55 PM
04/12/18 03:55 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Because your not spinning the valvecover 3/4 turn after the seal contacts the base.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Oil filter gasket vs. valve cover gasket [Re: camrydriver111] #4725008
04/12/18 06:58 PM
04/12/18 06:58 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Where is there more friction?
When a dog simply sits down or when he drags his butt across the floor?
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Oil filter gasket vs. valve cover gasket [Re: camrydriver111] #4725058
04/12/18 07:52 PM
04/12/18 07:52 PM
Canada
Canada
Why does the valve cover need to be clean of oil if the filter seals with oil on it?
Lets say we don't need to apply any silicone when replacing it. Which they generally don't at the factory anyways.
Re: Oil filter gasket vs. valve cover gasket [Re: camrydriver111] #4725157
04/12/18 09:01 PM
04/12/18 09:01 PM
War Eagle
toneydoc Offline
toneydoc  Offline
War Eagle
That was funny dlundblad
1994 Jeep 162k Castrol Synblend 10w30
2014 Camry 38k Havoline 5w20
2018 Jeep Cherokee 5k FactFill
2014 HD Ultra 42k Mobil1 15w50
2012 Rav4 39k Mobil 1 0w20
Re: Oil filter gasket vs. valve cover gasket [Re: camrydriver111] #4725162
04/12/18 09:05 PM
04/12/18 09:05 PM
Ontario Canada
cjcride Offline
cjcride  Offline
Ontario Canada
Oil filter is torqued somewhat tighter.
