Redlines equivalent to RP HPS
by Ivoidwarranties. 05/24/19 12:23 PM
6.0L powerstroke towing with 10w30
by mattd. 05/24/19 11:12 AM
Equinox 2.4L Oil change & questions.
by GaryPoe. 05/24/19 11:06 AM
Need a high zinc oil
by tutermoe. 05/24/19 10:50 AM
Help idtentify oil filter please
by 1978elcamino. 05/24/19 09:51 AM
Raptor liner/1995 Tahoe/Before & After
by Vladiator. 05/24/19 09:30 AM
Our Camry is back!
by tomcat27. 05/24/19 09:12 AM
Mobile dog grooming business ?
by Mr Nice. 05/24/19 08:00 AM
Tire balancer question
by supton. 05/24/19 07:56 AM
Ready for the Indy 500?
by shanneba. 05/24/19 05:31 AM
SKF grease with graphite
by PreludeDenarius. 05/24/19 03:42 AM
Quaker State Ultimate Durability 5W-30: $17.97 at WM
by The Critic. 05/24/19 01:31 AM
AT-205 Re-Seal for 1968 VW Bus?
by ZraHamilton. 05/24/19 01:22 AM
Can 5W-30 be Thicker than 10W-30?
by John344. 05/23/19 10:33 PM
Fastenal new policy-unhappy
by rekit. 05/23/19 10:23 PM
0w30 Showdown of European Oils
by Marco620. 05/23/19 10:12 PM
Tina70, tongboy1, PersonaPriusDad, MetricMike, Harps
68195 Registered Users
92 registered members (brages, aba4430, atikovi, 1978elcamino, chance, 4 invisible), 2,168 guests, and 20 spiders.
Topics289,336
Posts4,967,376
Members68,195
Most Online2,967
Mar 10th, 2019
Pennzoil Platinum D1G2 5w30 #4718932
04/06/18 09:39 PM
04/06/18 09:39 PM
Great White North.. eh
webfors Offline OP
webfors  Offline OP
They have added a little marketing fluff on the front of the bottle.
https://www.dropbox.com/s/3t361zv10i1ngyb/2018-04-06%2020.52.43.jpg?dl=0
Does anyone have a link to the new D1G2 PP spec sheet?
17 Cadillac ATS 2.0T, Edge D1G2 5w30, Champion COS10590
17 Dodge GC, VWB 5w30, Mopar MO-349
15 DL650, Valvoline Dino 20w50, Suzuki OEM OF
Small engines; RT5 10w30
Re: Pennzoil Platinum D1G2 5w30 [Re: webfors] #4718958
04/06/18 10:14 PM
04/06/18 10:14 PM
webfors Offline OP
webfors  Offline OP
Re: Pennzoil Platinum D1G2 5w30 [Re: webfors] #4718979
04/06/18 10:49 PM
04/06/18 10:49 PM
webfors Offline OP
webfors  Offline OP
What's with the drop in flash, decrease in hot viscosity, but worse cold pumping numbers?
http://www.pennzoil.com/en_us/products/f...c-Motor-Oil.pdf
http://www.shell-livedocs.com/data/published/en/c18eb3e5-7a5f-4471-88a5-1291276dea89.pdf
I'm looking forward to seeing PP D1G2 UOAs.
Re: Pennzoil Platinum D1G2 5w30 [Re: webfors] #4718993
04/06/18 11:19 PM
04/06/18 11:19 PM
Los Angeles, California
Gokhan Offline
Gokhan  Offline
I've just calculated the A_Harman index. (See calculation of the A_Harman index.) Closer to 1.000 is better. 1.000 means no VII.
PPPP 5W-30 assuming HTHSV = 3.1 cP: A_Harman index = 0.931
PPPP 5W-30 dexos 1 Gen 2 assuming HTHSV = 3.1 cP: A_Harman index = 0.975
Both are solid oils with little VII but PPPP dexos1 Gen 2 seems exceptional. Even if I assume HTHSV = 3.0 cP, I get A_Harman index = 0.944, larger than the non-dexos1-Gen-2 formulation.
dexos1 Gen 2 requires thicker base oil for protection of the timing chain in TGDI engines. (See Do you think that's thick oil? Think again?) So, they used a thicker base oil (larger CCS) and less VII to achieve similar KV100 viscosity for the blended oil for similar protection of the bearings but greater protection of the valvetrain, timing chain, rings, and so on.
1985 Toyota Corolla LE, 4A-LC engine, ~ 274,000 M
Mobil 1 Extended Performance 0W-20 SN PLUS (PAO-and-AN-based)
Fram Ultra XG3600 filter (full synthetic), 90430-12031 drain gasket (rubber on aluminum)
Re: Pennzoil Platinum D1G2 5w30 [Re: Gokhan] #4719135
04/07/18 06:39 AM
04/07/18 06:39 AM
webfors Offline OP
webfors  Offline OP
Interesting! I haven't spent much time catching up on the latest knowledge trends at BITOG.
So there should be less focus on KV100 viscosity, and more focus on base oil viscosity, with a desire for less VII. I recall a day when oil with very high VI were the jewel of BITOG. Times are a changing...
Re: Pennzoil Platinum D1G2 5w30 [Re: webfors] #4719267
04/07/18 08:59 AM
04/07/18 08:59 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
The oil seems to be on the thin side of the 30 wt
2015 F150 2.7
2018 F350 6.2
Re: Pennzoil Platinum D1G2 5w30 [Re: webfors] #4720026
04/07/18 10:04 PM
04/07/18 10:04 PM
GA.
ChrisD46 Offline
ChrisD46  Offline
GA.
*I'm almost 4,000 miles in on my last change of PPPP 5W30 DEXOS 1 Gen 2 in my 2017 non - turbo 2.4 L GDI Sonata . I'm not sure how much extra protection I get since I have non - turbo GDI ? I will say it runs smooth with zero consumption (low NOACK ?) as compared to factory fill and syn blend the dealer put in (now have 14K miles on the vehicle). I believe this new Pennzoil has to be as good (or better) than any other WM bought oils .
2017 Hyundai Sonata 2.4L GDI 4 cylinder
2010 Hyundai Elantra 2.0L 4 cylinder
2007 Kia Sedona 3.8L 6 cylinder
Re: Pennzoil Platinum D1G2 5w30 [Re: ChrisD46] #4720103
04/08/18 12:19 AM
04/08/18 12:19 AM
WA
OilUzer Offline
OilUzer  Offline
WA
Originally Posted By: ChrisD46
*I'm almost 4,000 miles in on my last change of PPPP 5W30 DEXOS 1 Gen 2 in my 2017 non - turbo 2.4 L GDI Sonata ...
I use the same oil in our 2.4 L DI Tuscon (same engine I think) and its running quiet according to my wife. I think I had to add a little oil maybe 6 fl oz or less in almost 6K miles. I didn't have to add oil since the oil was just a little from top mark but I like to keep it full ... the car has 60K + on it.
Re: Pennzoil Platinum D1G2 5w30 [Re: webfors] #4720161
04/08/18 04:38 AM
04/08/18 04:38 AM
WA
OilUzer Offline
OilUzer  Offline
WA
when I searched for 10W-30 I could only find the 2014 document (pdf). yours is 2017 ...
I went to your site above to get the 10W-30 info and it wants me to sign in and there is no option to create an account!
can you provide the link for 10W-30 also.
Thanks
Re: Pennzoil Platinum D1G2 5w30 [Re: webfors] #4720164
04/08/18 04:47 AM
04/08/18 04:47 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
It's also still Euro ACEA A5/B5 rated, which is a good spec and not all oils carry it.
It's KV100 at 9.8 cSt is so close to the 20 grade / 30 grade border that I would be tempted to use it in both 5W30 and 5W20 applications. Even 0W20 if not super cold.
Castrol Edge 10W30 A5/B5 + Wesfil-Cooper Z154
Re: Pennzoil Platinum D1G2 5w30 [Re: webfors] #4720167
04/08/18 04:52 AM
04/08/18 04:52 AM
WA
OilUzer Offline
OilUzer  Offline
WA
There is no NOACK in the datasheet. I have the old (2014?) NOACK from another thread.
Does anyone have the 2017 or 2018 NOACK for the 5W-30 and 10W-30?
Re: Pennzoil Platinum D1G2 5w30 [Re: OilUzer] #4720286
04/08/18 08:23 AM
04/08/18 08:23 AM
webfors Offline OP
webfors  Offline OP
Not sure anyone knows for sure. It's definitely not published by Shell.
Re: Pennzoil Platinum D1G2 5w30 [Re: OilUzer] #4721124
04/09/18 02:51 AM
04/09/18 02:51 AM
Pennsylbammyvania
dailydriver Offline
dailydriver  Offline
Pennsylbammyvania
I'd also like to know this info, as well as the starting TBN. wink
2016 Ford Fiesta ST 17K miles
Ravenol DXG 5W-30
Amsoil Ea15K51 filter
Ravenol MTF-2 in the IB6 transaxle
Re: Pennzoil Platinum D1G2 5w30 [Re: dailydriver] #4721214
04/09/18 06:59 AM
04/09/18 06:59 AM
New England
Virtus_Probi Offline
New England
I believe that SOPUS told us that their NOACK loss test methodology is so poor that they're ashamed to give us the results.
OK, I stretched the truth slightly there...
2014 Forester XT, 100000 miles
Last Change;
M1 10W30 HM SN+
Tokyo Roki 15208AA170 filter
Re: Pennzoil Platinum D1G2 5w30 [Re: OilUzer] #4721245
04/09/18 07:48 AM
04/09/18 07:48 AM
GA.
ChrisD46 Offline
ChrisD46  Offline
GA.
5K miles on an OCI is about all I would want to drive on any oil (even preferred synthetic) with a DI engine (5K OCI is my limit in mixed driving) ...
