B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Winter finally arrived
by StevieC. 01/20/19 10:27 AM
Octane rating of UL94 avgas
by Altydoc. 01/20/19 09:55 AM
Any bowlers out there?
by 53' Stude. 01/20/19 08:10 AM
Future of subcompact cars?
by Char Baby. 01/20/19 07:15 AM
Are u a roller coaster fan?
by ZZman. 01/20/19 07:03 AM
DUST - a couple of short Sci Fi films
by Shannow. 01/20/19 05:46 AM
5W30 Synthetic Oils With HTHS of 3.5 ?
by ChrisD46. 01/20/19 04:02 AM
White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
Rob_from_Madison, SubieSTI, ebersvc, junk1020, fairparts99
66987 Registered Users
105 registered members (aquariuscsm, 53' Stude, 240_Ed, AdditiveOCD, 11 invisible), 2,310 guests, and 41 spiders.
Topics296,878
Posts4,960,710
Members66,987
Most Online2,688
Jan 19th, 2019
‘09 2500 Chevy 6.0 gas—coding bad O2 sensors? #4720069
04/07/18 10:04 PM
04/07/18 10:04 PM
IL
lukejo Online content OP
lukejo  Online Content OP
IL
Engine light came on this week. No change in how the truck runs or gas mileage as far as I can tell so far.
Just had time to run to AZ to have them check the code...it gave multiple codes...showing 2 of the O2 sensors as bad for bank 1 and bank 2 in multiple places.
(I have not disconnected the battery to reset, but it has been off and on at least 10 times since the check engine light first came on...also, gas cap was appropriately tight. 95k miles.)
So could I have two O2 sensors that went bad at the same time?
Could this be indicative of anything else going on?
If this is the case, and I have it repaired, what’s it going to cost me?
Re: ‘09 2500 Chevy 6.0 gas—coding bad O2 sensors? [Re: lukejo] #4720077
04/07/18 10:32 PM
04/07/18 10:32 PM
IL
IL
Never mind...researching online, I see that I need the exact codes to even start diagnosing and even then, could be a wide range of possibilities.
Re: ‘09 2500 Chevy 6.0 gas—coding bad O2 sensors? [Re: lukejo] #4720350
04/08/18 08:30 AM
04/08/18 08:30 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
A few wild guesses . I think most O2 sensors now have electric heaters .
I would first check the fuses & see if any are blown . If so , visually check the wiring for damage . If damaged , I would unplug all of them , replace fuse / fuses U see if the fuses held . If so , I would check voltage at the connector of 1 & if voltage ( on the larger 2 wires ) is good , plug it back in . See if it blows the fuse again . Repeat for all of the sensors .
If no fuses have blown , I would clear codes and drive it .
Or , go to YouTube and look up South Main Auto channel . Look for a video of Eric O. testing O2 sensors .
Wyr
God bless
