64829 Members
68 Forums
282238 Topics
#4718980 - 04/06/18 10:49 PM
Pennzoil Platinum and Ultra Platinum NOACK values
Loc: Los Angeles, California
Shell removed the NOACK information from their GTL-based PurePlus oils shortly after they published their PDS's. I've found this info on some blog and I'm posting them for reference purposes here: PP: Old Pennzoil Platinum PUP: Old Penzoil Ultra PPPP: New Penzpoil Platinum with PurePlus PUPPP: New Pennzoil Ultra Platinum with PurePlus All are API SN (not SN Plus). NOACK values (%)PP 0W-20: 14.0% PP 5W-20: 13.2% PP 5W-30: 12.5% PP 10W-30: 9.7% PUP 5W-30: 6.6% PUP 10W-30: 4.8% PPPP 0W-20: 10.8% PPPP 5W-20: 8.6% PPPP 5W-30: 10.1% PPPP 10W-30: 4.7% PUPPP 5W-20: 10+% PUPPP 5W-30: 11.5% PUPPP 10W-30: 5.7% SVT Performance blogAdditions and corrections are welcome.
1985 Toyota Corolla LE, 4A-LC engine, ~ 269,000 M Toyota (TGMO) 0W-20 SN synthetic Mobil 1 EP M1-103 filter, 90430-12031 drain gasket
#4718981 - 04/06/18 10:52 PM
Re: Pennzoil Platinum and Ultra Platinum NOACK values
[Re: Gokhan]
Loc: Great White North.. eh
This makes me want PPPP 10w30 for summer!
17 Cadillac ATS 2.0T, Bulk D1G2 5w30, UPF64R 17 Dodge GC, VWB 5w30, Fram DL11665 15 DL650, RT6 5w40, Suzuki 16510-07j00 Small engines; RT5 10w30
#4718986 - 04/06/18 11:10 PM
[Re: Gokhan]
Loc: Texas/International
Source is 2014 SVT site and additions and corrections are welcome?
The volatility number for Shell GTL is the number 5 … as in 5th … lots of eggs in that basket …
2017 Tahoe 5.3L 4WD 2014 Fusion Hybrid 2013 Cruze RS 1.4T 2010 Canyon 5.3L 4WD
#4718996 - 04/06/18 11:25 PM
[Re: 4WD]
The volatility number for Shell GTL is the number 5 … as in 5th … lots of eggs in that basket … I'm not sure what you mean. As I said Shell removed the NOACK info shortly after publishing them in 2014 but these guys were kind enough to copy and paste them on their blog before that happened. New dexos1 Gen 2 and SN Plus formulations are appearing and the values will change again very soon.
#4719001 - 04/06/18 11:30 PM
[Re: webfors]
This makes me want PPPP 10w30 for summer! Or if you live in the South or Southwest, you can use it year-round.
#4719005 - 04/06/18 11:39 PM
[Re: webfors]
Loc: Waco, TX
This makes me want PPPP 10w30 for summer! If you have a good cooling system... it won't matter.
"The evidence demands a verdict". (Re:VOA)"it's nearly impossible to actually know the particular additives that are in there at what concentrations."
#4719006 - 04/06/18 11:40 PM
[Re: Gokhan]
So was that before or after the plant shut down? … these are real questions when you have all your eggs in one basket … and for us that basket must move from the Persian Gulf to the Gulf of Mexico …
#4719012 - 04/06/18 11:50 PM
[Re: Gokhan]
So the PP 5w30 euro and 0w40 Euro were in the clearance aisle again … I got some PP euro 30 ... that’s the “gap” in my stash ! When did those come out ? After 2014?
I’m holding a fair amount of 40’s … but Valvoline 5w40 MST for $3/quart was harder to pass over …
#4719016 - 04/07/18 12:01 AM
[Re: 4WD]
So was that before or after the plant shut down? … these are real questions when you have all your eggs in one basket … and for us that basket must move from the Persian Gulf to the Gulf of Mexico … Shell had to reduce the output of the Qatar Pearl GTL plant for maintenance about a year ago and then resumed full operation a few months later. There wasn't a full shutdown as far as I know.
#4719019 - 04/07/18 12:04 AM
[Re: 4WD]
I’m holding a fair amount of 40’s … but Valvoline 5w40 MST for $3/quart was harder to pass over … Shell's GTL-based oils should say PurePlus on the bottle. Although, in the past they used surplus GTL base oil even in Pennzoil yellow bottles etc.
#4719031 - 04/07/18 12:31 AM
[Re: Gokhan]
Yes … they attempt to conduct planned shut downs one train at a time … (regardless of GTL, LNG, or Chardonnay) … this is how planned “shuts” go (outside of single point failures) and unplanned get more “interesting” (let’s say) when you engineer such dependency and an asset ages … geopolitics mission creeps etc … Transportation is also a unique risk to go all in like this … (5th) … we’ll see …
#4719053 - 04/07/18 01:59 AM
[Re: Gokhan]
Loc: San Antonio, TX
Shell has certainly taken an "In for a penny, in for a pound" philosophy to the extreme in the Pearl facility. Who knows if it will ever show a positive return over the typical 20 year depreciation life used for such assets.
I'm still not convinced excess GTL base stock was used in non-premium Shell products, as no one has ever explained where the XHVI base stock displaced by GTL production wound up, especially the low NOACK stuff used to formulate PU.
"He who does not value the teacher, Or greatly care for the material, Is greatly deluded although he may be learned." - Lao-Tzu
#4719111 - 04/07/18 05:32 AM
[Re: Gokhan]
Loc: Florida
This makes me want PPPP 10w30 for summer! Or if you live in the South or Southwest, you can use it year-round. I've had PPPP 10w-30 in single digits F temps. Nothing to report. Cold engine acted normal. Delo 15w-30 also ran fine in low teens.
2013 F150 5.0, Pennzoil Ultra 10W-30, Wix 2010 Camry 2.5, GTX 5W-20, Fram Ultra XG9972
#4719146 - 04/07/18 06:57 AM
[Re: Gokhan]
Loc: NY
I'm confused, I got up early. The source is from 2014? If so how do we know the current numbers are still in play in 2018? For real, not opinions as to if they are or aren't the same now?
God Bless Our Troops
