Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
new tire 4 years old
by 1978elcamino. 04/19/19 08:51 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
91 registered members (ammolab, 2009Edge, 2015_PSD, bbhero, ArrestMeRedZ, 13 invisible), 2,141 guests, and 31 spiders.
Topics287,749
Posts4,933,806
Members67,850
Most Online2,967
Mar 10th, 2019
Fram XG10575 #4717330
04/05/18 03:35 PM
04/05/18 03:35 PM
Bucks, PA
zfasts03 Offline OP
zfasts03  Offline OP
Bucks, PA
So I am learning the bypass valve setting is too low for the L83 in my `16 Suburban 5.3. The bypass setting is supposed to be 22 psi and the Fram is about 1/2 of that. I have 5 of these filters in stock. What do I do? Use them or return them? If I return them what do I run?
I am reluctant to run the PF63E, due to being an ecore.
I guess I am waiting for the WIX WL10255 to become available for my next change.
Life isn't as simple as it used to be!
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: Fram XG10575 [Re: zfasts03] #4717338
04/05/18 03:40 PM
04/05/18 03:40 PM
Hammehead Offline
Hammehead  Offline
Maybe with 1/2 psi activating bypass, you will get less or no filtration while warmingup.
ToYota Corolla XEI 2010 1zzfe
Kawasaki Ninja ZX9R B4
Taurus GL Vulcan
Citroen C5 phase I
I used to use syn, now whatever is on sale and never had problems. This noob knows stuff.
Re: Fram XG10575 [Re: zfasts03] #4717355
04/05/18 04:07 PM
04/05/18 04:07 PM
The land of USA-made Subies!
SubieRubyRoo Offline
If it is specced for your vehicle by Fram, it will perform as needed. They wouldn't do something that would expose them to a huge, yuuuge lawsuit over something as silly as that. Fram XGs are among the best motor vehicle filters available. Use them with confidence. The synthetic media will flow more than a paper media that the PF63E runs, which results in a lower PSID.
Re: Fram XG10575 [Re: zfasts03] #4717357
04/05/18 04:08 PM
04/05/18 04:08 PM
Cincinnati, OH, USA
bullwinkle Online confused
bullwinkle  Online Confused
Cincinnati, OH, USA
If you use them in warmer weather, and are easy on the throttle until the engine (& oil) reach operating temperature, you should be OK. Hopefully Wix starts making the 22 PSI bypass ones by the time it gets cold again!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Fram XG10575 [Re: zfasts03] #4717358
04/05/18 04:08 PM
04/05/18 04:08 PM
Houston, Texas
WellOiled Offline
WellOiled  Offline
Houston, Texas
Run the Frams during the warm seasons when the oil viscosity is lower. Run a filter with the 22 psi bypass spec during the winter run. The dealer can not decline a warranty claim for using the correct cross reference (Magnuson–Moss Warranty Act).
2004 Ford Ranger 4.0L V6
Valvoline Advanced Full Synthetic HM 5W30 + WIX 51372
Re: Fram XG10575 [Re: zfasts03] #4717364
04/05/18 04:12 PM
04/05/18 04:12 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Here's what a search of your truck brings up. I would not worry about it.
FRAM ULTRA® SPIN-ON OIL FILTER
XG10575
PRODUCT DESCRIPTION
Designed for use with full synthetic oil.
PRODUCT SPECS
Height 4.06
Inside Diameter 22mmx1.5mm Th'd
Outside Diameter 2.984
Anti-Drainback Valve YES
By-Pass Valve Setting 9-15
Style 1
Turning Specification 3/4-1
Base Gasket I.D. 2.454
Base Gasket O.D. 2.756
If you want the job done right......do it yourself.
Re: Fram XG10575 [Re: zfasts03] #4717385
04/05/18 04:28 PM
04/05/18 04:28 PM
Missouri
Oily_Thing Offline
Oily_Thing  Offline
Missouri
What's wrong with the E-core if it is the one spec'ed for your vehicle?
2013 Cadillac XTS4 3.6
2015 Dodge Durango Limited 3.6
2011 Kawasaki Vulcan Voyager 1700
Re: Fram XG10575 [Re: zfasts03] #4717386
04/05/18 04:29 PM
04/05/18 04:29 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
This whole 22 PSI bypass valve thing from GM seems to have some peopole confused. Give Fram a call and ask if they realize they are specifying a filter with a lower bypass valve setting for a GM vehicle where GM says the filter "should have a 22 psi bypass valve".
If Fram (or any other aftermarket filter maker) has done their homework during filter specification to vehicles, they have determined that the delta-p across their filter isn't high enough to require a higher bypass valve setting than what they are using.
Re: Fram XG10575 [Re: zfasts03] #4717396
04/05/18 04:39 PM
04/05/18 04:39 PM
Texas
GM4LIFE Offline
GM4LIFE  Offline
Texas
I got 12 of the classic AC Delco PF63 non-ecore in my garage that I won't be using. Want them?
Re: Fram XG10575 [Re: ZeeOSix] #4717425
04/05/18 05:25 PM
04/05/18 05:25 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: ZeeOSix
The delta-p across their filter isn't high enough to require a higher bypass valve setting than what they are using.
There .................. I fixed it for you
TRUTH.
I wish the stupid GM spec would just die already.
Too many people think the sky is falling because their oil filter doesn't have a (ridiculous and unnecessary) 22 PSI bypass valve.
Re: Fram XG10575 [Re: Linctex] #4717456
04/05/18 06:03 PM
04/05/18 06:03 PM
Great White North.. eh
webfors Offline
webfors  Offline
TRUTH.
Maybe not necessary in TX. Up north... maybe eh.
17 Cadillac ATS 2.0T, Edge D1G2 5w30, XG10575
17 Dodge GC, VWB 5w30, Mopar MO-349
15 DL650, Rotella T6 5w40, KN-138
Small engines; RT5 10w30
Re: Fram XG10575 [Re: zfasts03] #4717470
04/05/18 06:24 PM
04/05/18 06:24 PM
Shippensburg, PA
novadude Offline
novadude  Offline
Shippensburg, PA
I've been running e-core PF63Es on my wife 3.6L V6 since new. I'm up to 5 filter changes so far (5-6k mile OCIs), and I've not seen a problem with any E-core I've removed. It's a quality filter, just like all AC Delco filters.
Re: Fram XG10575 [Re: zfasts03] #4717565
04/05/18 07:27 PM
04/05/18 07:27 PM
usa
miteclipse Offline
miteclipse  Offline
usa
Purolator is 22 psi
Re: Fram XG10575 [Re: zfasts03] #4717572
04/05/18 07:29 PM
04/05/18 07:29 PM
Bucks, PA
zfasts03 Offline OP
zfasts03  Offline OP
Bucks, PA
If the WIX WL10255 isn't available at the time of my next change I guess I will get the PF63E.
- 03 Corvette Z06
Amsoil 5w-30 SS
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Re: Fram XG10575 [Re: zfasts03] #4717878
04/06/18 03:27 AM
04/06/18 03:27 AM
KS
FordBroncoVWJeta Online content
FordBroncoVWJeta  Online Content
KS
On my 17 VW Jetta the Fram is specd at 12PSI ADBV. While the OEM is 36PSI. crazy
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
