NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
105 registered members (advocate, 69Torino, 4WD, 53' Stude, 69GTX, A310, 14 invisible), 1,779 guests, and 38 spiders.
Topics296,896
Posts4,961,146
Members66,997
Most Online2,688
Jan 19th, 2019
Briggs 24HP surging, but only #4715728
04/04/18 01:47 AM
04/04/18 01:47 AM
Central Washington
Colt45ws Offline OP
Colt45ws  Offline OP
Central Washington
...after running for a few minutes.
At first start, fires right up, run like a champ. After about 5 minutes at full throttle (much less if you clutch the mower deck in; lots of load) it begins to surge. It eventually gets to the point that it stalls. I can fire it right back up, no problem but it will surge bad and stall out again very quickly; maybe 30 seconds or less and often backfires when it does.
Since it runs fine at first, its making me think its less a carb problem and more a fuel delivery problem. Like maybe I have a pinched line or the liner inside the fuel line has collapsed somewhere and is blocking fuel flow. I was thinking about running new line from the tank all the way up.
This motor also has the plastic "pulse" fuel pump connected to one of the valve covers. I was gonna take the line off and see if it squirts when I roll the motor over. Is that a good test?
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: Briggs 24HP surging, but only [Re: Colt45ws] #4715734
04/04/18 02:03 AM
04/04/18 02:03 AM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Gas tank vent might not be working right, and after running awhile creates a slight vacuum and cuts fuel delivery? Try removing the gas tank cap and see if it makes a difference.
Re: Briggs 24HP surging, but only [Re: ZeeOSix] #4715736
04/04/18 02:09 AM
04/04/18 02:09 AM
Central Washington
Colt45ws Offline OP
Colt45ws  Offline OP
Central Washington
Nope I topped off the tank while it was running and it made no difference.
-Colton
Re: Briggs 24HP surging, but only [Re: Colt45ws] #4715738
04/04/18 02:22 AM
04/04/18 02:22 AM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
You could have a fuel delivery problem like you say, but you could also have a fuel metering problem which is far more likely. Carburetors need clean fuel all the time. And since the passageways and channels inside a carburetor are so small, it doesn't take a very large particle do block the flow of fuel. We're talking microns. The symptom of surging is almost always caused by a fuel metering problem. We're talking nine times out of ten. Does the engine idle smooth out by setting the choke half way on?
Re: Briggs 24HP surging, but only [Re: Colt45ws] #4715747
04/04/18 03:18 AM
04/04/18 03:18 AM
Mississippi
TheLawnRanger Offline
Mississippi
'99 Cavalier 5w 30 SuperTech conventional
'11 Impala 5w 30 Magnatec full synthetic
'12 Colorado 5w 30 Magnatec full synthetic
*regular Wix oil filters for all
Re: Briggs 24HP surging, but only [Re: TheLawnRanger] #4715752
04/04/18 04:05 AM
04/04/18 04:05 AM
Central Washington
Colt45ws Offline OP
Colt45ws  Offline OP
Central Washington
Yes, but not for very long...
Originally Posted By: TheLawnRanger
Thank you!!! That sounds like my issue. This engine is at least 10 years old. Im sure my orings look like the ones in the video. Ill order the oring kit.
-Colton
Re: Briggs 24HP surging, but only [Re: Colt45ws] #4715866
04/04/18 07:39 AM
04/04/18 07:39 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Harbor Freight has green and black o-rings in kits .
Wyr
God bless
Re: Briggs 24HP surging, but only [Re: TheLawnRanger] #4715876
04/04/18 07:46 AM
04/04/18 07:46 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
All that cause E87 corn gas was left in the engine without stabilization. Carb and its bowl gooped up with varnish. Why its important to either drain or use a fuel stabilizer like Sta-bil. Or.. This is what Seafoam was actually created for. Use that year round. Or.. my fave Gumout Multi-Stytem Tune up. Which is a Seafoam/techron brew. That might be abble to clean things up just running it in the gas rather than tear the engine apart. While it could be an oring, my hunch is the cleanup that comes with the replacement has more to do with the fix than anything else.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 152k ST HM 10w30
Re: Briggs 24HP surging, but only [Re: Colt45ws] #4716024
04/04/18 09:24 AM
04/04/18 09:24 AM
USA
mk378 Offline
mk378  Offline
USA
Oh boy another meth fueled shakey camera disorganized repair video.
If people follow only one rule to make these videos better:
Video should always start with the machine completely assembled before repair.
Video should always end with the machine completely assembled and working.
Re: Briggs 24HP surging, but only [Re: Colt45ws] #4716162
04/04/18 11:38 AM
04/04/18 11:38 AM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
How old is the fuel filter?
I have an oversized one give some restriction
after five years.
Fram G1.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Briggs 24HP surging, but only [Re: dwendt44] #4716213
04/04/18 12:25 PM
04/04/18 12:25 PM
Central Washington
Colt45ws Offline OP
Colt45ws  Offline OP
Central Washington
Yeah but there is an odd shaped one. Looks like two "B"s molded together. I went to the place that was linked in the video, and in the ebay recommened was a whole carb rebuild kit, with all the orings plus gaskets, for the same price. No brainer.
Actually it had E0 in it. smile
Right? Maybe I should make a new one. Put my copy of Adobe Premier Pro to use.
after five years.
Fram G1.
One year.
-Colton
Re: Briggs 24HP surging, but only [Re: Colt45ws] #4754428
05/11/18 05:24 PM
05/11/18 05:24 PM
Central Washington
Colt45ws Offline OP
Colt45ws  Offline OP
Central Washington
To update. I bought the carb kit and tore the carb down. It was pristine inside. No goo or clogged jets. The fuel bowl had a hint of corrosion in the bottom but nothing else was effected.
However the fuel plunger oring was split and barely hanging on to the plunger. It was also smooshed on one part. I replaced all the orings and put the engine back together.
It ran great! For about 20 minutes then surged and died again.
I couldnt figure out why it ran great for so long, so I checked the fuel, as I had been running it for awhile to tune the engine governor to Briggs spec.
When I loosened the fuel cap, I got the sucking noise of a vacuum being released. So the cap had gone bad too. I left the fuel cap loose and had no more problems. I was able to complete a one hour 30 mow cycle with no further issues.
I ordered a new cap and that fixed the issue without risking fuel contaimination.
So I had two problems I guess. But the oring would starve it of fuel before it was able to put a vacuum on the tank enough that it couldnt pull fuel.
-Colton
Re: Briggs 24HP surging, but only [Re: mk378] #4755743
05/13/18 09:04 AM
05/13/18 09:04 AM
WV
bchannell Offline
bchannell  Offline
WV
And I thought I was the only one that, that drove me crazy. Not everyone is cut out to be a YT star!!!
