Changed the oil in my Tundra today and for whatever reason, I just realized I over torqued the cartridge filter housing. From everything I've read the housing is supposed to be torqued to 20 lb-ft. I looked at the oil drain plug torque and went to 30 lb-ft. Should I:
a Not worry about it and fix it in 6 months when I change again
b Try loosening the housing and torque to spec, or;
c Remove the cartridge housing, replace the o-ring and torque to proper spec?
Thanks for the advice in advance.
